rechigo 367 Posted January 2, 2020 Posted January 2, 2020 After I was trying to get some information on an audio track today, it reminded me of something that's been missing from Emby: a "stats for nerds" for audio tracks (or just some way to view the data that I could get by running ffprobe on an audio track). As of now, I don't see any way to get information regarding an audio track (bitrate, channels, etc). Is there a way to do this that I just completely skipped over? 3 1
Luke 42147 Posted January 2, 2020 Posted January 2, 2020 Hi, there's currently no way, but it's not a bad idea. 1
mostynL 8 Posted September 3, 2022 Posted September 3, 2022 I kind of assume if you enable direct play on Emby for audio, then you are a nerd. In the web audio play, would love to see "FLAC" replaced with a one liner wtih more of that 'nerd stat'. Aren't we all nerds? Alright, wishful thinking. THanks.
Luke 42147 Posted September 3, 2022 Posted September 3, 2022 Hi, yes we could probably fit a little more there. Thanks for the feedback.
FrostByte 5428 Posted September 3, 2022 Posted September 3, 2022 (edited) I'm sure this has been asked before, but my ninja search skills aren't working right now. I would add bit depth 16/24 next to Hz in SFN for those with HD audio and replace the mbps which is there 3 times for some reason. Edited September 3, 2022 by FrostByte 1 4 1
Daniel_Yee 7 Posted October 12, 2025 Posted October 12, 2025 Adding the audio basic info on the front of player will be perfect like file format, bitrate, bit depth and sample rate (eg. FLAC - 1592kbps 24bit/44.1khz). 2 2
