magootoo 0 Posted January 2, 2020 Posted January 2, 2020 Hello, Please help me, I'm new to this and would love to get things working as I think they should. I have the HDhomerun setup and working perfect;y but for the life of me cannot get any channels on the /digibit r1. Do i add it as a M3u tuner? I have tried this but no channels show up!!!! I have searched the forums but can't seem to find any advice. I'd really appreciate some assistance. @@cayars
Carlo 4561 Posted January 2, 2020 Posted January 2, 2020 If you're talking about the Digibit Sat receiver you can't use that directly within Emby. There are a few Emby plugins however that can be used. Have you explored any of them yet? Being in the USA I don't have access to Sats like you guys do but the Emby Plugins worth taking a look at might include: DVBLink, DVBViewer, TVMosaic & TVHeadEnd. Each of these acts like a middle man between the appropriately named server and Emby. If the Sat receiver can work over IPTV protocol then you might be able to skip the middle man approach and setup and install it as an IPTV source.
sub3 64 Posted January 3, 2020 Posted January 3, 2020 NextPVR supports SAT>IP devices, like the Digibit R1, so you can set it up in there, and use the Emby NextPVR plugin. 1
magootoo 0 Posted January 6, 2020 Author Posted January 6, 2020 HI, I got it up and running with TVHeadend (steep learning curve), many thanks for that. NOt sure if I should open a new query but, I have to restart emby server every time I want to use Live TV. ANy thoughts? Thanks in advance!!
Carlo 4561 Posted January 6, 2020 Posted January 6, 2020 That doesn't sound good. Can you access TVHeadend ok outside of Emby? You may want to give NextPVR a test run as well. It's a very good product that works well with Emby. Never hurts to try a couple of different solutions! Carlo
magootoo 0 Posted January 6, 2020 Author Posted January 6, 2020 Yes, there's no problem accessing TVHeadend outside of Emby, and I can get live TV with kodi so it seems to be with Emby. Don't really want to have to set up another plugin if I can avoid it....but will take a look later
magootoo 0 Posted January 6, 2020 Author Posted January 6, 2020 Everythng looks ok until I try to play a program and then it's the activity indicator spinning away endlessly...Works fine if I restart the emby server!
Luke 42244 Posted January 6, 2020 Posted January 6, 2020 Ok, let's look at an example. Please attach the information requested in how to report a problem: https://emby.media/community/index.php?/topic/790-how-to-report-a-problem/?view=getnewpost Thanks.
magootoo 0 Posted January 17, 2020 Author Posted January 17, 2020 HI, So the set up is: TVheadend 4.2.8 running on synology NAS EMBY Server 4.3.1.0 running on synology NAS HDHomerun satellite Irish Channels (Saorview) Digibit R1 satellite Free to air channels (mostly UK) Clients are Firestick Tv So, after a restart of the Emby server, (this is in reference to live tv), I am able to play any of the channels provided through tvheadend, however after a couple of minutes use, I am unable to change channel gett ing the error 'Unable to tune to channel at this time'. It is then necessary to restart the emby server to be able to view live tv again. Please see log attached: Emby Log.rtf
Luke 42244 Posted January 18, 2020 Posted January 18, 2020 Does this happen if you play from the web app?
magootoo 0 Posted January 18, 2020 Author Posted January 18, 2020 HI Luke, I just get the spnning cirlce on the web app and also iOS app. Tks, Mark
magootoo 0 Posted January 22, 2020 Author Posted January 22, 2020 Any ideas guys? Would really lke to get his sorted if possible?
Luke 42244 Posted January 23, 2020 Posted January 23, 2020 @@magootoo how are you trying to change the channel?
magootoo 0 Posted January 23, 2020 Author Posted January 23, 2020 Have tried using the channel list and guide, same results. Why do you ask that?
Luke 42244 Posted February 6, 2020 Posted February 6, 2020 Can you provide an alternative log example, in it's original plain text format? If there was an ffmpeg log, please attach that too. Thanks.
magootoo 0 Posted February 10, 2020 Author Posted February 10, 2020 2020-02-10 00:00:00.106 Info App: Application version: 4.3.1.02020-02-10 00:00:00.107 Info App: Emby Command line: /volume1/@appstore/EmbyServer/releases/4.3.1.0/EmbyServer.dll -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/netcore/2.2.1/runtime/System.Private.CoreLib.dll Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.3.1.02020-02-10 00:00:00.107 Info App: Plugins: Bluray Folder Support 1.0.0.0 Cinema Intros 1.0.30.0 Dlna 1.0.33.0 Dvd Folder Support 1.0.0.0 Fanart.tv 1.0.5.0 Iso Mounter 1.0.4.0 MovieDb 1.2.9.0 MusicBrainz 1.0.11.0 Nfo Metadata 1.0.24.0 OMDb 1.0.8.0 Open Subtitles 1.0.22.0 Port Mapper 1.0.2.0 Sonos Controller 1.0.3.0 Studio Images 1.0.1.0 TheAudioDb 1.0.6.0 TheTVDB 1.0.28.0 Webhooks 1.0.9.02020-02-10 00:00:00.107 Info TaskManager: Rotate log file Completed after 0 minute(s) and 0 seconds2020-02-10 00:00:41.966 Info HttpServer: WS http://192.168.0.67:8096/embywebsocket?api_key=45603a0fc5fe4dfc8ed79ae5641cb7c0&deviceId=0769C5B6-4932-4C15-9429-67176CDA4ADC. UserAgent: Mozilla/5.0 (iPhone; CPU iPhone OS 13_3 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Mobile/15E148 2020-02-10 00:00:41.967 Debug HttpServer: Web socket connection allowed2020-02-10 00:00:50.362 Debug PortMapper: Found NAT device: uuid:A37351C5-8521-4c24-A43E-5467511EA7A7::urn:schemas-upnp-org:service:WANPPPConnection:12020-02-10 00:00:50.362 Debug PortMapper: Found device at: http://192.168.0.1:5000/rootDesc.xml2020-02-10 00:00:50.362 Debug HttpClient: GET http://192.168.0.1:5000/rootDesc.xml2020-02-10 00:00:50.363 Debug PortMapper: Found NAT device: uuid:A37351C5-8521-4c24-A43E-5467511EA7A7::urn:schemas-upnp-org:service:WANIPConnection:12020-02-10 00:00:50.363 Debug PortMapper: Found device at: http://192.168.0.1:5000/rootDesc.xml2020-02-10 00:00:50.363 Debug HttpClient: GET http://192.168.0.1:5000/rootDesc.xml2020-02-10 00:00:50.376 Debug PortMapper: 192.168.0.1:5000: Found upnp service urn:schemas-upnp-org:service:WANIPConnection:1 at /ctl/IPConn2020-02-10 00:00:50.376 Debug PortMapper: Creating port map on local port 8096 to public port 8096 with device 192.168.0.672020-02-10 00:00:50.376 Debug HttpClient: POST http://192.168.0.1:5000/ctl/IPConn2020-02-10 00:00:50.386 Debug PortMapper: 192.168.0.1:5000: Found upnp service urn:schemas-upnp-org:service:WANIPConnection:1 at /ctl/IPConn2020-02-10 00:00:50.394 Debug PortMapper: Creating port map on local port 8920 to public port 8920 with device 192.168.0.672020-02-10 00:00:50.395 Debug HttpClient: POST http://192.168.0.1:5000/ctl/IPConn2020-02-10 00:02:13.158 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/Users/df1ce6a7ded94d02938a20105689c49a. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:13.160 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 2ms. http://192.168.0.67:8096/emby/Users/df1ce6a7ded94d02938a20105689c49a2020-02-10 00:02:13.185 Debug App: SessionInfosWebSocketListener Begin transmitting over websocket to [::ffff:192.168.0.180]:576862020-02-10 00:02:13.186 Debug App: ScheduledTasksWebSocketListener Begin transmitting over websocket to [::ffff:192.168.0.180]:576862020-02-10 00:02:13.186 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/Sessions?ActiveWithinSeconds=900. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:13.187 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 2ms. http://192.168.0.67:8096/emby/Sessions?ActiveWithinSeconds=9002020-02-10 00:02:13.189 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:13.191 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 2ms. http://192.168.0.67:8096/emby/ScheduledTasks2020-02-10 00:02:13.192 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to [::ffff:192.168.0.180]:576862020-02-10 00:02:13.193 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:13.193 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/System/Info. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:13.194 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 2ms. http://192.168.0.67:8096/emby/System/Info2020-02-10 00:02:13.195 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 3ms. http://192.168.0.67:8096/emby/News/Product?StartIndex=0&Limit=42020-02-10 00:02:13.197 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to [::ffff:192.168.0.180]:576862020-02-10 00:02:13.197 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2020-02-09T00%3A02%3A13.193Z&hasUserId=true. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:13.199 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 2ms. http://192.168.0.67:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2020-02-09T00%3A02%3A13.193Z&hasUserId=true2020-02-10 00:02:13.202 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2020-02-03T00%3A02%3A13.195Z&hasUserId=false. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:13.202 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:13.202 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/LiveTv/Recordings?UserId=df1ce6a7ded94d02938a20105689c49a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:13.203 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 1ms. http://192.168.0.67:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true2020-02-10 00:02:13.204 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 2ms. http://192.168.0.67:8096/emby/LiveTv/Recordings?UserId=df1ce6a7ded94d02938a20105689c49a&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop2020-02-10 00:02:13.204 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 2ms. http://192.168.0.67:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=4&minDate=2020-02-03T00%3A02%3A13.195Z&hasUserId=false2020-02-10 00:02:16.798 Debug App: SessionInfosWebSocketListener stop transmitting over websocket to [::ffff:192.168.0.180]:576862020-02-10 00:02:16.798 Debug App: ScheduledTasksWebSocketListener stop transmitting over websocket to [::ffff:192.168.0.180]:576862020-02-10 00:02:16.826 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:16.828 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 2ms. http://192.168.0.67:8096/emby/System/Logs2020-02-10 00:02:16.829 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36 2020-02-10 00:02:16.830 Info HttpServer: HTTP Response 200 to 192.168.0.180. Time: 1ms. http://192.168.0.67:8096/emby/System/Configuration2020-02-10 00:02:19.393 Info HttpServer: HTTP GET http://192.168.0.67:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.87 Safari/537.36
magootoo 0 Posted February 10, 2020 Author Posted February 10, 2020 2020-02-07 13:03:33.393Emby Server version: 4.3.1.0App: AndroidTv 1.7.78aMark's 2nd Fire TV Stickhttp://192.168.0.67:8096/emby/videos/153451/live.m3u8?DeviceId=7e822a5deacdd343&MediaSourceId=3b661f099ca85ca93a037d40107cdff5&PlaySessionId=06197e199bea4319a23ceda174e3069d&api_key=222845b9598943fbbada93d9a03343c4&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3b661f099ca85ca93a037d40107cdff5&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac,mp3&VideoBitrate=79808000&AudioBitrate=192000&AudioStreamIndex=-1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=41&hevc-profile=Main&aac-audiochannels=8&mp3-audiochannels=8{"Protocol":"Http","Id":"3b661f099ca85ca93a037d40107cdff5","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/5e95dee707644a2482301981638def0f/stream.ts","Type":"Default","Container":"mpegts","IsRemote":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_3b661f099ca85ca93a037d40107cdff5","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"h264","ColorTransfer":"bt709","ColorPrimaries":"bt709","ColorSpace":"bt709","TimeBase":"1/90000","CodecTimeBase":"1/50","VideoRange":"SDR","DisplayTitle":"1080iH264","NalLengthSize":"0","IsInterlaced":true,"BitRate":20000000,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":25,"RealFrameRate":50,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"mp2","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","Level":0}],"Formats":[],"Bitrate":20192000,"RequiredHttpHeaders":{"User-Agent":"VLC/3.0.1"},"ReadAtNativeFramerate":false} User policy for Home: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True/var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -loglevel +timing -analyzeduration 3000000 -user_agent "VLC/3.0.1" -fflags +discardcorruptts+fillwallclockdts -f mpegts -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/5e95dee707644a2482301981638def0f/stream.ts"-map_metadata -1 -map_chapters -1 -threads 0 -sn -c:v:0 copy -vsync -1 -codec:a:0 aac -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_entry_prefix "hls/52431ec847100d8e5bb4ed5a05a6b0a6/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8" -y "/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6%d.ts" 13:03:33.441 ffmpeg version 4.3.0-emby_2019_11_09-20191126T231314UTC Copyright © 2000-2019 the FFmpeg developers and softworkz for Emby LLC13:03:33.441 built with gcc 7.3.0 (GCC)13:03:33.441 Execution Date: 2020-02-07 13:03:3313:03:33.457 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.457 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.457 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.458 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.458 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.458 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.458 [h264 @ 0x7d2080] decode_slice_header error13:03:33.458 [h264 @ 0x7d2080] no frame!13:03:33.458 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.460 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.460 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.460 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.460 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.460 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.460 [h264 @ 0x7d2080] decode_slice_header error13:03:33.460 [h264 @ 0x7d2080] no frame!13:03:33.463 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.463 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.463 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.463 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.463 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.463 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.463 [h264 @ 0x7d2080] decode_slice_header error13:03:33.463 [h264 @ 0x7d2080] no frame!13:03:33.463 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.463 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.463 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.463 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.463 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.463 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.463 [h264 @ 0x7d2080] decode_slice_header error13:03:33.463 [h264 @ 0x7d2080] no frame!13:03:33.463 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.463 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.463 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.463 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.463 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.463 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.463 [h264 @ 0x7d2080] decode_slice_header error13:03:33.463 [h264 @ 0x7d2080] no frame!13:03:33.463 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.463 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.463 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.463 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.464 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.464 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.464 [h264 @ 0x7d2080] decode_slice_header error13:03:33.464 [h264 @ 0x7d2080] no frame!13:03:33.465 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.465 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.466 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.466 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.466 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.468 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.468 [h264 @ 0x7d2080] decode_slice_header error13:03:33.468 [h264 @ 0x7d2080] no frame!13:03:33.469 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.469 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.469 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.469 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.469 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.469 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.469 [h264 @ 0x7d2080] decode_slice_header error13:03:33.469 [h264 @ 0x7d2080] no frame!13:03:33.469 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.469 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.470 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.470 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.470 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.470 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.470 [h264 @ 0x7d2080] decode_slice_header error13:03:33.470 [h264 @ 0x7d2080] no frame!13:03:33.470 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.470 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.470 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.470 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.470 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.470 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.470 [h264 @ 0x7d2080] decode_slice_header error13:03:33.470 [h264 @ 0x7d2080] no frame!13:03:33.471 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.471 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.471 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.471 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.471 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.471 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.471 [h264 @ 0x7d2080] decode_slice_header error13:03:33.471 [h264 @ 0x7d2080] no frame!13:03:33.471 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.471 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.471 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.471 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.471 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.471 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.471 [h264 @ 0x7d2080] decode_slice_header error13:03:33.471 [h264 @ 0x7d2080] no frame!13:03:33.471 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.471 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.471 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.471 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.471 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.471 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.471 [h264 @ 0x7d2080] decode_slice_header error13:03:33.471 [h264 @ 0x7d2080] no frame!13:03:33.471 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.471 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.471 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.471 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.471 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.471 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.471 [h264 @ 0x7d2080] decode_slice_header error13:03:33.471 [h264 @ 0x7d2080] no frame!13:03:33.472 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.472 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.472 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.472 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.472 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.472 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.472 [h264 @ 0x7d2080] decode_slice_header error13:03:33.472 [h264 @ 0x7d2080] no frame!13:03:33.472 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.472 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.472 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.472 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.472 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.473 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.473 [h264 @ 0x7d2080] decode_slice_header error13:03:33.473 [h264 @ 0x7d2080] no frame!13:03:33.473 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.473 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.473 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.473 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.473 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.473 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.473 [h264 @ 0x7d2080] decode_slice_header error13:03:33.473 [h264 @ 0x7d2080] no frame!13:03:33.473 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.473 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.473 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.473 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.473 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.473 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.473 [h264 @ 0x7d2080] decode_slice_header error13:03:33.473 [h264 @ 0x7d2080] no frame!13:03:33.473 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.473 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.473 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.473 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.473 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.473 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.474 [h264 @ 0x7d2080] decode_slice_header error13:03:33.474 [h264 @ 0x7d2080] no frame!13:03:33.474 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.474 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.474 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.474 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.474 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.474 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.474 [h264 @ 0x7d2080] decode_slice_header error13:03:33.474 [h264 @ 0x7d2080] no frame!13:03:33.474 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.474 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.474 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.474 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.474 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.474 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.474 [h264 @ 0x7d2080] decode_slice_header error13:03:33.474 [h264 @ 0x7d2080] no frame!13:03:33.474 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.474 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.474 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.474 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.474 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.474 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.474 [h264 @ 0x7d2080] decode_slice_header error13:03:33.474 [h264 @ 0x7d2080] no frame!13:03:33.474 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.474 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.475 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.475 [h264 @ 0x7d2080] non-existing SPS 0 referenced in buffering period13:03:33.475 [h264 @ 0x7d2080] SPS unavailable in decode_picture_timing13:03:33.475 [h264 @ 0x7d2080] non-existing PPS 0 referenced13:03:33.475 [h264 @ 0x7d2080] decode_slice_header error13:03:33.475 [h264 @ 0x7d2080] no frame!13:03:33.860 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/5e95dee707644a2482301981638def0f/stream.ts':13:03:33.860 Duration: N/A, start: 80983.649567, bitrate: N/A13:03:33.860 Program 2120013:03:33.860 Metadata:13:03:33.860 service_name : Channel 4 HD13:03:33.860 service_provider: BSkyB13:03:33.860 Stream #0:0[0x901]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [sAR 1:1 DAR 16:9], Level 40, 25 fps, 50 tbr, 90k tbn, 50 tbc, Start-Time 80984.610s13:03:33.861 Stream #0:1[0x903](NAR): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 192 kb/s, Start-Time 80983.699s13:03:33.861 Stream #0:2[0x905](eng): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006), 492x250, Start-Time 80983.650s13:03:33.861 Stream #0:3[0x904](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006), Start-Time 80986.950s13:03:33.861 Stream #0:4[0x902](eng): Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 384 kb/s, Start-Time 80983.733s13:03:33.862 Stream mapping:13:03:33.862 Stream #0:0 -> #0:0 (copy)13:03:33.862 Stream #0:1 -> #0:1 (mp2 (native) -> aac (native))13:03:33.862 Press [q] to stop, [?] for help13:03:33.865 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a60.ts.tmp' for writing13:03:33.866 Output #0, segment, to '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6%d.ts':13:03:33.866 Metadata:13:03:33.866 encoder : Lavf58.31.10413:03:33.866 Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [sAR 1:1 DAR 16:9], q=2-31, Level 40, 25 fps, 50 tbr, 90k tbn, 25 tbc13:03:33.866 Stream #0:1: Audio: aac (LC), 48000 Hz, stereo, fltp, 192 kb/s (default)13:03:33.866 Metadata:13:03:33.866 encoder : Lavc58.56.101 aac13:03:34.021 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:34.022 SegmentComplete=video:0 Index=0 Start=0.000000 End=3.810244 Duration=3.810244 offset_pts=0 start_pts=0 Frames=128 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a60.ts13:03:34.022 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a61.ts.tmp' for writing13:03:34.377 frame= 240 fps=0.0 q=-1.0 size= 4909kB time=00:00:05.95 bitrate=6758.5kbits/s throttle=off speed=11.6x13:03:34.877 frame= 267 fps=263 q=-1.0 size= 5497kB time=00:00:06.49 bitrate=6938.7kbits/s throttle=off speed=6.39x13:03:35.282 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:35.283 SegmentComplete=video:0 Index=1 Start=3.930244 End=5.890244 Duration=1.960000 offset_pts=0 start_pts=3930244 Frames=104 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a61.ts13:03:35.283 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a62.ts.tmp' for writing13:03:35.382 frame= 292 fps=192 q=-1.0 size= 6038kB time=00:00:06.99 bitrate=7076.0kbits/s throttle=off speed= 4.6x13:03:35.886 frame= 318 fps=157 q=-1.0 size= 6594kB time=00:00:07.51 bitrate=7193.0kbits/s throttle=off speed=3.71x13:03:36.389 frame= 332 fps=131 q=-1.0 size= 7132kB time=00:00:07.79 bitrate=7499.4kbits/s throttle=off speed=3.08x13:03:36.893 frame= 355 fps=117 q=-1.0 size= 7692kB time=00:00:08.25 bitrate=7637.6kbits/s throttle=off speed=2.72x13:03:37.456 frame= 371 fps=103 q=-1.0 size= 8013kB time=00:00:08.57 bitrate=7659.1kbits/s throttle=off speed=2.38x13:03:37.962 frame= 410 fps=100 q=-1.0 size= 8803kB time=00:00:09.35 bitrate=7712.9kbits/s throttle=off speed=2.28x13:03:38.465 frame= 437 fps= 95 q=-1.0 size= 9331kB time=00:00:09.89 bitrate=7729.0kbits/s throttle=off speed=2.15x13:03:38.966 frame= 464 fps= 91 q=-1.0 size= 9903kB time=00:00:10.43 bitrate=7778.2kbits/s throttle=off speed=2.04x13:03:39.469 frame= 489 fps= 87 q=-1.0 size= 10481kB time=00:00:10.93 bitrate=7855.6kbits/s throttle=off speed=1.95x13:03:39.474 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:39.475 SegmentComplete=video:0 Index=2 Start=6.010244 End=10.210244 Duration=4.200000 offset_pts=0 start_pts=6010244 Frames=216 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a62.ts13:03:39.475 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a63.ts.tmp' for writing13:03:39.974 frame= 512 fps= 84 q=-1.0 size= 10994kB time=00:00:11.39 bitrate=7907.2kbits/s throttle=off speed=1.86x13:03:40.477 frame= 535 fps= 81 q=-1.0 size= 11525kB time=00:00:11.85 bitrate=7967.4kbits/s throttle=off speed=1.79x13:03:40.979 frame= 554 fps= 78 q=-1.0 size= 12089kB time=00:00:12.23 bitrate=8097.3kbits/s throttle=off speed=1.72x13:03:41.285 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:41.286 SegmentComplete=video:0 Index=3 Start=10.330244 End=11.970244 Duration=1.640000 offset_pts=0 start_pts=10330244 Frames=88 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a63.ts13:03:41.286 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a64.ts.tmp' for writing13:03:41.481 frame= 579 fps= 76 q=-1.0 size= 12626kB time=00:00:12.73 bitrate=8125.1kbits/s throttle=off speed=1.67x13:03:41.985 frame= 607 fps= 75 q=-1.0 size= 13169kB time=00:00:13.29 bitrate=8117.2kbits/s throttle=off speed=1.64x13:03:42.487 frame= 633 fps= 73 q=-1.0 size= 13727kB time=00:00:13.81 bitrate=8142.4kbits/s throttle=off speed= 1.6x13:03:42.991 frame= 658 fps= 72 q=-1.0 size= 14254kB time=00:00:14.31 bitrate=8159.9kbits/s throttle=off speed=1.57x13:03:43.495 frame= 684 fps= 71 q=-1.0 size= 14780kB time=00:00:14.83 bitrate=8164.1kbits/s throttle=off speed=1.54x13:03:43.997 frame= 709 fps= 70 q=-1.0 size= 15353kB time=00:00:15.33 bitrate=8204.1kbits/s throttle=off speed=1.51x13:03:44.304 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:44.304 SegmentComplete=video:0 Index=4 Start=12.090244 End=15.010244 Duration=2.920000 offset_pts=0 start_pts=12090244 Frames=152 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a64.ts13:03:44.304 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a65.ts.tmp' for writing13:03:44.501 frame= 736 fps= 69 q=-1.0 size= 15876kB time=00:00:15.87 bitrate=8194.8kbits/s throttle=off speed=1.49x13:03:45.003 frame= 761 fps= 68 q=-1.0 size= 16426kB time=00:00:16.37 bitrate=8219.8kbits/s throttle=off speed=1.47x13:03:45.506 frame= 791 fps= 68 q=-1.0 size= 16977kB time=00:00:16.97 bitrate=8195.3kbits/s throttle=off speed=1.46x13:03:46.009 frame= 818 fps= 67 q=-1.0 size= 17533kB time=00:00:17.51 bitrate=8202.5kbits/s throttle=off speed=1.44x13:03:46.513 frame= 838 fps= 66 q=-1.0 size= 18062kB time=00:00:17.91 bitrate=8261.6kbits/s throttle=off speed=1.42x13:03:47.020 frame= 864 fps= 66 q=-1.0 size= 18606kB time=00:00:18.43 bitrate=8270.0kbits/s throttle=off speed= 1.4x13:03:47.124 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:47.125 SegmentComplete=video:0 Index=5 Start=15.130244 End=17.890244 Duration=2.760000 offset_pts=0 start_pts=15130244 Frames=144 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a65.ts13:03:47.125 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a66.ts.tmp' for writing13:03:47.520 frame= 889 fps= 65 q=-1.0 size= 19160kB time=00:00:18.93 bitrate=8291.3kbits/s throttle=off speed=1.39x13:03:48.025 frame= 912 fps= 64 q=-1.0 size= 19641kB time=00:00:19.39 bitrate=8298.0kbits/s throttle=off speed=1.37x13:03:48.527 frame= 935 fps= 64 q=-1.0 size= 20215kB time=00:00:19.85 bitrate=8342.7kbits/s throttle=off speed=1.35x13:03:49.029 frame= 961 fps= 63 q=-1.0 size= 20804kB time=00:00:20.37 bitrate=8366.4kbits/s throttle=off speed=1.34x13:03:49.533 frame= 991 fps= 63 q=-1.0 size= 21330kB time=00:00:20.97 bitrate=8332.7kbits/s throttle=off speed=1.34x13:03:50.037 frame= 1025 fps= 63 q=-1.0 size= 21870kB time=00:00:21.65 bitrate=8275.0kbits/s throttle=off speed=1.34x13:03:50.540 frame= 1050 fps= 63 q=-1.0 size= 22412kB time=00:00:22.15 bitrate=8288.8kbits/s throttle=off speed=1.33x13:03:51.044 frame= 1074 fps= 63 q=-1.0 size= 22933kB time=00:00:22.63 bitrate=8301.5kbits/s throttle=off speed=1.32x13:03:51.546 frame= 1100 fps= 62 q=-1.0 size= 23491kB time=00:00:23.15 bitrate=8312.6kbits/s throttle=off speed=1.31x13:03:51.953 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:51.954 SegmentComplete=video:0 Index=6 Start=18.010244 End=22.690244 Duration=4.680000 offset_pts=0 start_pts=18010244 Frames=240 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a66.ts13:03:51.954 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a67.ts.tmp' for writing13:03:52.048 frame= 1125 fps= 62 q=-1.0 size= 24031kB time=00:00:23.65 bitrate=8323.9kbits/s throttle=off speed= 1.3x13:03:52.550 frame= 1151 fps= 62 q=-1.0 size= 24592kB time=00:00:24.17 bitrate=8334.9kbits/s throttle=off speed=1.29x13:03:53.091 frame= 1176 fps= 61 q=-1.0 size= 25133kB time=00:00:24.67 bitrate=8345.8kbits/s throttle=off speed=1.28x13:03:53.591 frame= 1201 fps= 61 q=-1.0 size= 25742kB time=00:00:25.17 bitrate=8378.0kbits/s throttle=off speed=1.28x13:03:53.899 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:53.899 SegmentComplete=video:0 Index=7 Start=22.810244 End=24.610244 Duration=1.800000 offset_pts=0 start_pts=22810244 Frames=96 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a67.ts13:03:53.899 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a68.ts.tmp' for writing13:03:54.094 frame= 1218 fps= 60 q=-1.0 size= 26257kB time=00:00:25.51 bitrate=8431.8kbits/s throttle=off speed=1.26x13:03:54.597 frame= 1242 fps= 60 q=-1.0 size= 26796kB time=00:00:25.99 bitrate=8445.8kbits/s throttle=off speed=1.25x13:03:55.102 frame= 1263 fps= 59 q=-1.0 size= 27327kB time=00:00:26.41 bitrate=8476.5kbits/s throttle=off speed=1.24x13:03:55.608 frame= 1288 fps= 59 q=-1.0 size= 27831kB time=00:00:26.91 bitrate=8472.1kbits/s throttle=off speed=1.24x13:03:56.106 frame= 1315 fps= 59 q=-1.0 size= 28436kB time=00:00:27.45 bitrate=8486.1kbits/s throttle=off speed=1.23x13:03:56.610 frame= 1345 fps= 59 q=-1.0 size= 28993kB time=00:00:28.05 bitrate=8467.4kbits/s throttle=off speed=1.23x13:03:57.014 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:57.015 SegmentComplete=video:0 Index=8 Start=24.730244 End=27.650244 Duration=2.920000 offset_pts=0 start_pts=24730244 Frames=152 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a68.ts13:03:57.015 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a69.ts.tmp' for writing13:03:57.114 frame= 1368 fps= 59 q=-1.0 size= 29483kB time=00:00:28.51 bitrate=8471.5kbits/s throttle=off speed=1.23x13:03:57.616 frame= 1392 fps= 59 q=-1.0 size= 30021kB time=00:00:28.99 bitrate=8483.3kbits/s throttle=off speed=1.22x13:03:58.119 frame= 1415 fps= 58 q=-1.0 size= 30582kB time=00:00:29.45 bitrate=8506.7kbits/s throttle=off speed=1.21x13:03:58.621 frame= 1445 fps= 58 q=-1.0 size= 31156kB time=00:00:30.05 bitrate=8493.5kbits/s throttle=off speed=1.21x13:03:59.161 frame= 1473 fps= 58 q=-1.0 size= 31721kB time=00:00:30.61 bitrate=8489.2kbits/s throttle=off speed=1.21x13:03:59.676 frame= 1494 fps= 58 q=-1.0 size= 32260kB time=00:00:31.03 bitrate=8516.6kbits/s throttle=off speed= 1.2x13:03:59.680 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:03:59.681 SegmentComplete=video:0 Index=9 Start=27.770244 End=30.370244 Duration=2.600000 offset_pts=0 start_pts=27770244 Frames=136 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a69.ts13:03:59.681 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a610.ts.tmp' for writing13:04:00.179 frame= 1519 fps= 58 q=-1.0 size= 32829kB time=00:00:31.53 bitrate=8529.4kbits/s throttle=off speed= 1.2x13:04:00.682 frame= 1537 fps= 57 q=-1.0 size= 33394kB time=00:00:31.89 bitrate=8578.3kbits/s throttle=off speed=1.19x13:04:01.185 frame= 1566 fps= 57 q=-1.0 size= 33915kB time=00:00:32.47 bitrate=8556.5kbits/s throttle=off speed=1.19x13:04:01.688 frame= 1591 fps= 57 q=-1.0 size= 34449kB time=00:00:32.97 bitrate=8559.5kbits/s throttle=off speed=1.18x13:04:02.194 frame= 1617 fps= 57 q=-1.0 size= 34987kB time=00:00:33.49 bitrate=8558.1kbits/s throttle=off speed=1.18x13:04:02.696 frame= 1642 fps= 57 q=-1.0 size= 35553kB time=00:00:33.99 bitrate=8568.7kbits/s throttle=off speed=1.18x13:04:03.100 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:03.101 SegmentComplete=video:0 Index=10 Start=30.490244 End=33.730244 Duration=3.240000 offset_pts=0 start_pts=30490244 Frames=168 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a610.ts13:04:03.101 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a611.ts.tmp' for writing13:04:03.200 frame= 1670 fps= 57 q=-1.0 size= 36100kB time=00:00:34.55 bitrate=8559.6kbits/s throttle=off speed=1.18x13:04:03.703 frame= 1689 fps= 57 q=-1.0 size= 36632kB time=00:00:34.93 bitrate=8591.0kbits/s throttle=off speed=1.17x13:04:04.206 frame= 1716 fps= 57 q=-1.0 size= 37174kB time=00:00:35.47 bitrate=8585.5kbits/s throttle=off speed=1.17x13:04:04.710 frame= 1745 fps= 57 q=-1.0 size= 37722kB time=00:00:36.05 bitrate=8572.0kbits/s throttle=off speed=1.17x13:04:05.216 frame= 1772 fps= 57 q=-1.0 size= 38239kB time=00:00:36.59 bitrate=8561.1kbits/s throttle=off speed=1.17x13:04:05.720 frame= 1801 fps= 57 q=-1.0 size= 38854kB time=00:00:37.17 bitrate=8563.1kbits/s throttle=off speed=1.17x13:04:06.224 frame= 1824 fps= 56 q=-1.0 size= 39365kB time=00:00:37.63 bitrate=8569.6kbits/s throttle=off speed=1.16x13:04:06.228 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:06.229 SegmentComplete=video:0 Index=11 Start=33.850244 End=36.930244 Duration=3.080000 offset_pts=0 start_pts=33850244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a611.ts13:04:06.229 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a612.ts.tmp' for writing13:04:06.728 frame= 1849 fps= 56 q=-1.0 size= 39923kB time=00:00:38.13 bitrate=8577.2kbits/s throttle=off speed=1.16x13:04:07.233 frame= 1871 fps= 56 q=-1.0 size= 40410kB time=00:00:38.57 bitrate=8582.7kbits/s throttle=off speed=1.16x13:04:07.736 frame= 1896 fps= 56 q=-1.0 size= 40929kB time=00:00:39.07 bitrate=8581.8kbits/s throttle=off speed=1.15x13:04:08.238 frame= 1921 fps= 56 q=-1.0 size= 41546kB time=00:00:39.57 bitrate=8601.0kbits/s throttle=off speed=1.15x13:04:08.741 frame= 1947 fps= 56 q=-1.0 size= 42088kB time=00:00:40.09 bitrate=8600.3kbits/s throttle=off speed=1.15x13:04:08.843 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:08.844 SegmentComplete=video:0 Index=12 Start=37.050244 End=39.490244 Duration=2.440000 offset_pts=0 start_pts=37050244 Frames=128 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a612.ts13:04:08.844 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a613.ts.tmp' for writing13:04:09.245 frame= 1971 fps= 56 q=-1.0 size= 42646kB time=00:00:40.57 bitrate=8611.2kbits/s throttle=off speed=1.15x13:04:09.749 frame= 1998 fps= 56 q=-1.0 size= 43150kB time=00:00:41.11 bitrate=8598.5kbits/s throttle=off speed=1.15x13:04:11.729 frame= 2003 fps= 53 q=-1.0 size= 43289kB time=00:00:41.21 bitrate=8605.3kbits/s throttle=off speed=1.09x13:04:11.909 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:11.910 SegmentComplete=video:0 Index=13 Start=39.610244 End=42.210244 Duration=2.600000 offset_pts=0 start_pts=39610244 Frames=136 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a613.ts13:04:11.910 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a614.ts.tmp' for writing13:04:12.235 frame= 2123 fps= 55 q=-1.0 size= 45860kB time=00:00:43.61 bitrate=8614.6kbits/s throttle=off speed=1.14x13:04:12.738 frame= 2150 fps= 55 q=-1.0 size= 46391kB time=00:00:44.15 bitrate=8607.7kbits/s throttle=off speed=1.14x13:04:13.244 frame= 2174 fps= 55 q=-1.0 size= 46919kB time=00:00:44.63 bitrate=8612.1kbits/s throttle=off speed=1.13x13:04:13.746 frame= 2201 fps= 55 q=-1.0 size= 47516kB time=00:00:45.17 bitrate=8617.4kbits/s throttle=off speed=1.13x13:04:14.251 frame= 2218 fps= 55 q=-1.0 size= 48048kB time=00:00:45.51 bitrate=8648.8kbits/s throttle=off speed=1.13x13:04:14.756 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:14.758 SegmentComplete=video:0 Index=14 Start=42.330244 End=45.410244 Duration=3.080000 offset_pts=0 start_pts=42330244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a614.ts13:04:14.758 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a615.ts.tmp' for writing13:04:14.758 frame= 2247 fps= 55 q=-1.0 size= 48561kB time=00:00:46.09 bitrate=8631.1kbits/s throttle=off speed=1.13x13:04:15.260 frame= 2271 fps= 55 q=-1.0 size= 49096kB time=00:00:46.57 bitrate=8636.3kbits/s throttle=off speed=1.12x13:04:15.762 frame= 2300 fps= 55 q=-1.0 size= 49638kB time=00:00:47.15 bitrate=8624.1kbits/s throttle=off speed=1.13x13:04:16.266 frame= 2328 fps= 55 q=-1.0 size= 50178kB time=00:00:47.71 bitrate=8615.8kbits/s throttle=off speed=1.13x13:04:16.769 frame= 2347 fps= 55 q=-1.0 size= 50737kB time=00:00:48.09 bitrate=8642.8kbits/s throttle=off speed=1.12x13:04:17.273 frame= 2374 fps= 55 q=-1.0 size= 51292kB time=00:00:48.63 bitrate=8640.4kbits/s throttle=off speed=1.12x13:04:17.778 frame= 2399 fps= 55 q=-1.0 size= 51817kB time=00:00:49.13 bitrate=8640.0kbits/s throttle=off speed=1.12x13:04:18.182 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:18.183 SegmentComplete=video:0 Index=15 Start=45.530244 End=48.770244 Duration=3.240000 offset_pts=0 start_pts=45530244 Frames=168 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a615.ts13:04:18.183 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a616.ts.tmp' for writing13:04:18.282 frame= 2423 fps= 55 q=-1.0 size= 52345kB time=00:00:49.61 bitrate=8643.6kbits/s throttle=off speed=1.12x13:04:18.785 frame= 2452 fps= 55 q=-1.0 size= 52932kB time=00:00:50.19 bitrate=8639.6kbits/s throttle=off speed=1.12x13:04:19.288 frame= 2475 fps= 54 q=-1.0 size= 53468kB time=00:00:50.65 bitrate=8647.7kbits/s throttle=off speed=1.11x13:04:19.792 frame= 2503 fps= 54 q=-1.0 size= 54008kB time=00:00:51.21 bitrate=8639.6kbits/s throttle=off speed=1.11x13:04:20.297 frame= 2529 fps= 54 q=-1.0 size= 54563kB time=00:00:51.73 bitrate=8640.5kbits/s throttle=off speed=1.11x13:04:20.801 frame= 2553 fps= 54 q=-1.0 size= 55079kB time=00:00:52.21 bitrate=8642.2kbits/s throttle=off speed=1.11x13:04:21.305 frame= 2578 fps= 54 q=-1.0 size= 55640kB time=00:00:52.71 bitrate=8647.3kbits/s throttle=off speed=1.11x13:04:21.406 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:21.407 SegmentComplete=video:0 Index=16 Start=48.890244 End=51.970244 Duration=3.080000 offset_pts=0 start_pts=48890244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a616.ts13:04:21.407 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a617.ts.tmp' for writing13:04:21.808 frame= 2602 fps= 54 q=-1.0 size= 56173kB time=00:00:53.19 bitrate=8651.3kbits/s throttle=off speed=1.11x13:04:22.312 frame= 2628 fps= 54 q=-1.0 size= 56739kB time=00:00:53.71 bitrate=8654.0kbits/s throttle=off speed=1.11x13:04:22.816 frame= 2655 fps= 54 q=-1.0 size= 57275kB time=00:00:54.25 bitrate=8648.8kbits/s throttle=off speed=1.11x13:04:23.320 frame= 2675 fps= 54 q=-1.0 size= 57793kB time=00:00:54.65 bitrate=8663.1kbits/s throttle=off speed= 1.1x13:04:23.822 frame= 2702 fps= 54 q=-1.0 size= 58326kB time=00:00:55.19 bitrate=8657.5kbits/s throttle=off speed= 1.1x13:04:23.925 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:23.925 SegmentComplete=video:0 Index=17 Start=52.090244 End=54.530244 Duration=2.440000 offset_pts=0 start_pts=52090244 Frames=128 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a617.ts13:04:23.925 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a618.ts.tmp' for writing13:04:24.325 frame= 2729 fps= 54 q=-1.0 size= 58909kB time=00:00:55.73 bitrate=8659.3kbits/s throttle=off speed= 1.1x13:04:24.828 frame= 2746 fps= 54 q=-1.0 size= 59457kB time=00:00:56.07 bitrate=8686.8kbits/s throttle=off speed= 1.1x13:04:25.333 frame= 2775 fps= 54 q=-1.0 size= 59953kB time=00:00:56.65 bitrate=8669.6kbits/s throttle=off speed= 1.1x13:04:25.835 frame= 2800 fps= 54 q=-1.0 size= 60443kB time=00:00:57.15 bitrate=8664.1kbits/s throttle=off speed= 1.1x13:04:26.339 frame= 2825 fps= 54 q=-1.0 size= 61030kB time=00:00:57.65 bitrate=8672.2kbits/s throttle=off speed= 1.1x13:04:26.543 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:26.544 SegmentComplete=video:0 Index=18 Start=54.650244 End=57.250244 Duration=2.600000 offset_pts=0 start_pts=54650244 Frames=136 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a618.ts13:04:26.544 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a619.ts.tmp' for writing13:04:26.839 frame= 2854 fps= 54 q=-1.0 size= 61610kB time=00:00:58.23 bitrate=8667.4kbits/s throttle=off speed= 1.1x13:04:27.344 frame= 2881 fps= 54 q=-1.0 size= 62178kB time=00:00:58.77 bitrate=8667.0kbits/s throttle=off speed= 1.1x13:04:27.849 frame= 2903 fps= 54 q=-1.0 size= 62616kB time=00:00:59.21 bitrate=8663.2kbits/s throttle=off speed= 1.1x13:04:28.350 frame= 2929 fps= 54 q=-1.0 size= 63251kB time=00:00:59.73 bitrate=8674.8kbits/s throttle=off speed= 1.1x13:04:28.855 frame= 2953 fps= 54 q=-1.0 size= 63768kB time=00:01:00.21 bitrate=8676.1kbits/s throttle=off speed=1.09x13:04:29.357 frame= 2982 fps= 54 q=-1.0 size= 64344kB time=00:01:00.79 bitrate=8670.9kbits/s throttle=off speed= 1.1x13:04:29.860 frame= 3009 fps= 54 q=-1.0 size= 64903kB time=00:01:01.33 bitrate=8669.2kbits/s throttle=off speed= 1.1x13:04:30.062 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:30.062 SegmentComplete=video:0 Index=19 Start=57.370244 End=60.610244 Duration=3.240000 offset_pts=0 start_pts=57370244 Frames=168 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a619.ts13:04:30.063 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a620.ts.tmp' for writing13:04:30.364 frame= 3032 fps= 54 q=-1.0 size= 65360kB time=00:01:01.79 bitrate=8665.3kbits/s throttle=off speed=1.09x13:04:30.869 frame= 3056 fps= 54 q=-1.0 size= 65922kB time=00:01:02.27 bitrate=8672.4kbits/s throttle=off speed=1.09x13:04:31.371 frame= 3082 fps= 54 q=-1.0 size= 66535kB time=00:01:02.79 bitrate=8680.5kbits/s throttle=off speed=1.09x13:04:31.875 frame= 3105 fps= 54 q=-1.0 size= 67088kB time=00:01:03.25 bitrate=8689.1kbits/s throttle=off speed=1.09x13:04:32.378 frame= 3130 fps= 53 q=-1.0 size= 67613kB time=00:01:03.75 bitrate=8688.3kbits/s throttle=off speed=1.09x13:04:32.481 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:32.483 SegmentComplete=video:0 Index=20 Start=60.730244 End=63.170244 Duration=2.440000 offset_pts=0 start_pts=60730244 Frames=128 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a620.ts13:04:32.483 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a621.ts.tmp' for writing13:04:32.881 frame= 3157 fps= 53 q=-1.0 size= 68139kB time=00:01:04.29 bitrate=8682.4kbits/s throttle=off speed=1.09x13:04:33.385 frame= 3180 fps= 53 q=-1.0 size= 68684kB time=00:01:04.75 bitrate=8689.7kbits/s throttle=off speed=1.09x13:04:33.890 frame= 3207 fps= 53 q=-1.0 size= 69195kB time=00:01:05.29 bitrate=8682.0kbits/s throttle=off speed=1.09x13:04:34.391 frame= 3234 fps= 53 q=-1.0 size= 69806kB time=00:01:05.83 bitrate=8686.7kbits/s throttle=off speed=1.09x13:04:34.896 frame= 3248 fps= 53 q=-1.0 size= 70300kB time=00:01:06.11 bitrate=8711.2kbits/s throttle=off speed=1.08x13:04:35.398 frame= 3274 fps= 53 q=-1.0 size= 70857kB time=00:01:06.63 bitrate=8711.6kbits/s throttle=off speed=1.08x13:04:35.401 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:35.402 SegmentComplete=video:0 Index=21 Start=63.290244 End=66.050244 Duration=2.760000 offset_pts=0 start_pts=63290244 Frames=144 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a621.ts13:04:35.402 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a622.ts.tmp' for writing13:04:35.903 frame= 3304 fps= 53 q=-1.0 size= 71371kB time=00:01:07.23 bitrate=8696.5kbits/s throttle=off speed=1.08x13:04:36.406 frame= 3328 fps= 53 q=-1.0 size= 71871kB time=00:01:07.71 bitrate=8695.4kbits/s throttle=off speed=1.08x13:04:36.905 frame= 3358 fps= 53 q=-1.0 size= 72504kB time=00:01:08.31 bitrate=8694.9kbits/s throttle=off speed=1.08x13:04:37.410 frame= 3386 fps= 53 q=-1.0 size= 73044kB time=00:01:08.87 bitrate=8688.5kbits/s throttle=off speed=1.08x13:04:37.914 frame= 3412 fps= 53 q=-1.0 size= 73574kB time=00:01:09.39 bitrate=8686.0kbits/s throttle=off speed=1.08x13:04:38.421 frame= 3434 fps= 53 q=-1.0 size= 74098kB time=00:01:09.83 bitrate=8692.6kbits/s throttle=off speed=1.08x13:04:38.623 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:38.624 SegmentComplete=video:0 Index=22 Start=66.170244 End=69.250244 Duration=3.080000 offset_pts=0 start_pts=66170244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a622.ts13:04:38.624 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a623.ts.tmp' for writing13:04:38.925 frame= 3459 fps= 53 q=-1.0 size= 74654kB time=00:01:10.33 bitrate=8695.6kbits/s throttle=off speed=1.08x13:04:39.427 frame= 3484 fps= 53 q=-1.0 size= 75226kB time=00:01:10.83 bitrate=8700.4kbits/s throttle=off speed=1.08x13:04:39.931 frame= 3513 fps= 53 q=-1.0 size= 75773kB time=00:01:11.41 bitrate=8692.4kbits/s throttle=off speed=1.08x13:04:40.434 frame= 3538 fps= 53 q=-1.0 size= 76309kB time=00:01:11.91 bitrate=8693.1kbits/s throttle=off speed=1.08x13:04:41.235 frame= 3551 fps= 53 q=-1.0 size= 76555kB time=00:01:12.17 bitrate=8689.7kbits/s throttle=off speed=1.07x13:04:41.737 frame= 3598 fps= 53 q=-1.0 size= 77701kB time=00:01:13.11 bitrate=8706.4kbits/s throttle=off speed=1.08x13:04:42.143 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:42.144 SegmentComplete=video:0 Index=23 Start=69.370244 End=72.770244 Duration=3.400000 offset_pts=0 start_pts=69370244 Frames=176 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a623.ts13:04:42.144 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a624.ts.tmp' for writing13:04:42.242 frame= 3624 fps= 53 q=-1.0 size= 78239kB time=00:01:13.63 bitrate=8704.8kbits/s throttle=off speed=1.08x13:04:42.746 frame= 3651 fps= 53 q=-1.0 size= 78798kB time=00:01:14.17 bitrate=8703.2kbits/s throttle=off speed=1.08x13:04:43.250 frame= 3677 fps= 53 q=-1.0 size= 79320kB time=00:01:14.69 bitrate=8699.8kbits/s throttle=off speed=1.08x13:04:43.751 frame= 3703 fps= 53 q=-1.0 size= 79891kB time=00:01:15.21 bitrate=8701.9kbits/s throttle=off speed=1.08x13:04:44.255 frame= 3727 fps= 53 q=-1.0 size= 80425kB time=00:01:15.69 bitrate=8704.5kbits/s throttle=off speed=1.08x13:04:44.758 frame= 3753 fps= 53 q=-1.0 size= 80981kB time=00:01:16.21 bitrate=8704.8kbits/s throttle=off speed=1.07x13:04:45.261 frame= 3777 fps= 53 q=-1.0 size= 81514kB time=00:01:16.69 bitrate=8707.2kbits/s throttle=off speed=1.07x13:04:45.363 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:45.364 SegmentComplete=video:0 Index=24 Start=72.890244 End=75.970244 Duration=3.080000 offset_pts=0 start_pts=72890244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a624.ts13:04:45.364 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a625.ts.tmp' for writing13:04:45.766 frame= 3800 fps= 53 q=-1.0 size= 81978kB time=00:01:17.15 bitrate=8704.6kbits/s throttle=off speed=1.07x13:04:46.268 frame= 3827 fps= 53 q=-1.0 size= 82627kB time=00:01:17.69 bitrate=8712.5kbits/s throttle=off speed=1.07x13:04:46.771 frame= 3850 fps= 53 q=-1.0 size= 83170kB time=00:01:18.15 bitrate=8718.2kbits/s throttle=off speed=1.07x13:04:47.274 frame= 3874 fps= 53 q=-1.0 size= 83715kB time=00:01:18.63 bitrate=8721.7kbits/s throttle=off speed=1.07x13:04:47.480 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:47.481 SegmentComplete=video:0 Index=25 Start=76.090244 End=78.210244 Duration=2.120000 offset_pts=0 start_pts=76090244 Frames=112 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a625.ts13:04:47.481 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a626.ts.tmp' for writing13:04:47.777 frame= 3899 fps= 53 q=-1.0 size= 84245kB time=00:01:19.13 bitrate=8721.5kbits/s throttle=off speed=1.07x13:04:48.282 frame= 3924 fps= 53 q=-1.0 size= 84772kB time=00:01:19.63 bitrate=8721.0kbits/s throttle=off speed=1.07x13:04:48.789 frame= 3951 fps= 53 q=-1.0 size= 85305kB time=00:01:20.17 bitrate=8716.7kbits/s throttle=off speed=1.07x13:04:49.289 frame= 3962 fps= 53 q=-1.0 size= 85881kB time=00:01:20.39 bitrate=8751.5kbits/s throttle=off speed=1.07x13:04:49.793 frame= 3994 fps= 53 q=-1.0 size= 86417kB time=00:01:21.03 bitrate=8736.6kbits/s throttle=off speed=1.07x13:04:50.298 frame= 4024 fps= 53 q=-1.0 size= 86880kB time=00:01:21.63 bitrate=8718.8kbits/s throttle=off speed=1.07x13:04:50.802 frame= 4047 fps= 53 q=-1.0 size= 87407kB time=00:01:22.09 bitrate=8722.5kbits/s throttle=off speed=1.07x13:04:51.302 frame= 4074 fps= 53 q=-1.0 size= 88065kB time=00:01:22.63 bitrate=8730.8kbits/s throttle=off speed=1.07x13:04:51.508 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:51.509 SegmentComplete=video:0 Index=26 Start=78.330244 End=82.210244 Duration=3.880000 offset_pts=0 start_pts=78330244 Frames=200 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a626.ts13:04:51.510 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a627.ts.tmp' for writing13:04:51.805 frame= 4091 fps= 52 q=-1.0 size= 88599kB time=00:01:22.97 bitrate=8747.8kbits/s throttle=off speed=1.06x13:04:52.308 frame= 4123 fps= 53 q=-1.0 size= 89141kB time=00:01:23.61 bitrate=8733.9kbits/s throttle=off speed=1.07x13:04:52.811 frame= 4146 fps= 53 q=-1.0 size= 89666kB time=00:01:24.07 bitrate=8737.2kbits/s throttle=off speed=1.06x13:04:53.316 frame= 4176 fps= 53 q=-1.0 size= 90195kB time=00:01:24.67 bitrate=8726.5kbits/s throttle=off speed=1.07x13:04:53.422 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:53.423 SegmentComplete=video:0 Index=27 Start=82.330244 End=84.130244 Duration=1.800000 offset_pts=0 start_pts=82330244 Frames=96 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a627.ts13:04:53.423 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a628.ts.tmp' for writing13:04:53.818 frame= 4203 fps= 53 q=-1.0 size= 90768kB time=00:01:25.21 bitrate=8726.3kbits/s throttle=off speed=1.07x13:04:54.323 frame= 4225 fps= 53 q=-1.0 size= 91299kB time=00:01:25.65 bitrate=8732.3kbits/s throttle=off speed=1.06x13:04:54.826 frame= 4245 fps= 52 q=-1.0 size= 91851kB time=00:01:26.05 bitrate=8744.2kbits/s throttle=off speed=1.06x13:04:55.327 frame= 4275 fps= 52 q=-1.0 size= 92399kB time=00:01:26.65 bitrate=8735.5kbits/s throttle=off speed=1.06x13:04:55.837 frame= 4303 fps= 52 q=-1.0 size= 92877kB time=00:01:27.21 bitrate=8724.3kbits/s throttle=off speed=1.06x13:04:56.433 frame= 4332 fps= 52 q=-1.0 size= 93586kB time=00:01:27.79 bitrate=8732.8kbits/s throttle=off speed=1.06x13:04:56.638 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:56.639 SegmentComplete=video:0 Index=28 Start=84.250244 End=87.330244 Duration=3.080000 offset_pts=0 start_pts=84250244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a628.ts13:04:56.639 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a629.ts.tmp' for writing13:04:56.937 frame= 4361 fps= 52 q=-1.0 size= 94154kB time=00:01:28.37 bitrate=8728.2kbits/s throttle=off speed=1.06x13:04:57.439 frame= 4381 fps= 52 q=-1.0 size= 94672kB time=00:01:28.77 bitrate=8736.7kbits/s throttle=off speed=1.06x13:04:57.943 frame= 4409 fps= 52 q=-1.0 size= 95231kB time=00:01:29.33 bitrate=8733.1kbits/s throttle=off speed=1.06x13:04:58.449 frame= 4431 fps= 52 q=-1.0 size= 95658kB time=00:01:29.77 bitrate=8729.3kbits/s throttle=off speed=1.06x13:04:58.949 frame= 4457 fps= 52 q=-1.0 size= 96285kB time=00:01:30.29 bitrate=8735.9kbits/s throttle=off speed=1.06x13:04:59.156 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:04:59.157 SegmentComplete=video:0 Index=29 Start=87.450244 End=89.890244 Duration=2.440000 offset_pts=0 start_pts=87450244 Frames=128 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a629.ts13:04:59.157 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a630.ts.tmp' for writing13:04:59.455 frame= 4482 fps= 52 q=-1.0 size= 96819kB time=00:01:30.79 bitrate=8736.0kbits/s throttle=off speed=1.06x13:04:59.955 frame= 4506 fps= 52 q=-1.0 size= 97399kB time=00:01:31.27 bitrate=8742.1kbits/s throttle=off speed=1.06x13:05:00.472 frame= 4521 fps= 52 q=-1.0 size= 97692kB time=00:01:31.57 bitrate=8739.7kbits/s throttle=off speed=1.06x13:05:00.978 frame= 4559 fps= 52 q=-1.0 size= 98423kB time=00:01:32.33 bitrate=8732.6kbits/s throttle=off speed=1.06x13:05:01.581 frame= 4578 fps= 52 q=-1.0 size= 98955kB time=00:01:32.71 bitrate=8743.8kbits/s throttle=off speed=1.06x13:05:01.985 frame= 4602 fps= 52 q=-1.0 size= 99585kB time=00:01:33.19 bitrate=8754.1kbits/s throttle=off speed=1.06x13:05:02.289 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:02.290 SegmentComplete=video:0 Index=30 Start=90.010244 End=92.930244 Duration=2.920000 offset_pts=0 start_pts=90010244 Frames=152 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a630.ts13:05:02.290 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a631.ts.tmp' for writing13:05:02.488 frame= 4634 fps= 52 q=-1.0 size= 100150kB time=00:01:33.83 bitrate=8743.7kbits/s throttle=off speed=1.06x13:05:02.990 frame= 4654 fps= 52 q=-1.0 size= 100659kB time=00:01:34.23 bitrate=8750.9kbits/s throttle=off speed=1.06x13:05:03.493 frame= 4681 fps= 52 q=-1.0 size= 101210kB time=00:01:34.77 bitrate=8748.6kbits/s throttle=off speed=1.06x13:05:03.998 frame= 4712 fps= 52 q=-1.0 size= 101720kB time=00:01:35.39 bitrate=8735.6kbits/s throttle=off speed=1.06x13:05:04.501 frame= 4736 fps= 52 q=-1.0 size= 102183kB time=00:01:35.87 bitrate=8731.4kbits/s throttle=off speed=1.06x13:05:05.043 frame= 4767 fps= 52 q=-1.0 size= 102888kB time=00:01:36.49 bitrate=8735.2kbits/s throttle=off speed=1.06x13:05:05.546 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:05.547 SegmentComplete=video:0 Index=31 Start=93.050244 End=96.130244 Duration=3.080000 offset_pts=0 start_pts=93050244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a631.ts13:05:05.547 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a632.ts.tmp' for writing13:05:05.548 frame= 4785 fps= 52 q=-1.0 size= 103401kB time=00:01:36.85 bitrate=8746.1kbits/s throttle=off speed=1.06x13:05:06.050 frame= 4815 fps= 52 q=-1.0 size= 103963kB time=00:01:37.45 bitrate=8739.5kbits/s throttle=off speed=1.06x13:05:06.554 frame= 4840 fps= 52 q=-1.0 size= 104456kB time=00:01:37.95 bitrate=8736.1kbits/s throttle=off speed=1.06x13:05:07.056 frame= 4861 fps= 52 q=-1.0 size= 105055kB time=00:01:38.37 bitrate=8748.7kbits/s throttle=off speed=1.06x13:05:07.559 frame= 4888 fps= 52 q=-1.0 size= 105580kB time=00:01:38.91 bitrate=8744.4kbits/s throttle=off speed=1.06x13:05:08.063 frame= 4912 fps= 52 q=-1.0 size= 106135kB time=00:01:39.39 bitrate=8747.9kbits/s throttle=off speed=1.06x13:05:08.566 frame= 4943 fps= 52 q=-1.0 size= 106676kB time=00:01:40.01 bitrate=8738.0kbits/s throttle=off speed=1.06x13:05:08.671 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:08.672 SegmentComplete=video:0 Index=32 Start=96.250244 End=99.330244 Duration=3.080000 offset_pts=0 start_pts=96250244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a632.ts13:05:08.672 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a633.ts.tmp' for writing13:05:09.069 frame= 4958 fps= 52 q=-1.0 size= 107242kB time=00:01:40.31 bitrate=8758.1kbits/s throttle=off speed=1.05x13:05:09.572 frame= 4987 fps= 52 q=-1.0 size= 107782kB time=00:01:40.89 bitrate=8751.6kbits/s throttle=off speed=1.05x13:05:10.079 frame= 5015 fps= 52 q=-1.0 size= 108290kB time=00:01:41.45 bitrate=8744.3kbits/s throttle=off speed=1.05x13:05:10.580 frame= 5036 fps= 52 q=-1.0 size= 108870kB time=00:01:41.87 bitrate=8754.9kbits/s throttle=off speed=1.05x13:05:11.087 frame= 5063 fps= 52 q=-1.0 size= 109355kB time=00:01:42.41 bitrate=8747.5kbits/s throttle=off speed=1.05x13:05:11.590 frame= 5089 fps= 52 q=-1.0 size= 109970kB time=00:01:42.93 bitrate=8752.3kbits/s throttle=off speed=1.05x13:05:12.091 frame= 5113 fps= 52 q=-1.0 size= 110509kB time=00:01:43.41 bitrate=8754.3kbits/s throttle=off speed=1.05x13:05:12.192 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:12.193 SegmentComplete=video:0 Index=33 Start=99.450244 End=102.850244 Duration=3.400000 offset_pts=0 start_pts=99450244 Frames=176 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a633.ts13:05:12.193 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a634.ts.tmp' for writing13:05:12.593 frame= 5138 fps= 52 q=-1.0 size= 111054kB time=00:01:43.91 bitrate=8755.2kbits/s throttle=off speed=1.05x13:05:13.097 frame= 5166 fps= 52 q=-1.0 size= 111574kB time=00:01:44.47 bitrate=8749.1kbits/s throttle=off speed=1.05x13:05:13.602 frame= 5191 fps= 52 q=-1.0 size= 112094kB time=00:01:44.97 bitrate=8747.9kbits/s throttle=off speed=1.05x13:05:14.105 frame= 5216 fps= 52 q=-1.0 size= 112613kB time=00:01:45.47 bitrate=8746.8kbits/s throttle=off speed=1.05x13:05:14.607 frame= 5242 fps= 52 q=-1.0 size= 113226kB time=00:01:45.99 bitrate=8751.2kbits/s throttle=off speed=1.05x13:05:15.110 frame= 5260 fps= 52 q=-1.0 size= 113771kB time=00:01:46.35 bitrate=8763.6kbits/s throttle=off speed=1.05x13:05:15.417 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:15.418 SegmentComplete=video:0 Index=34 Start=102.970244 End=106.050244 Duration=3.080000 offset_pts=0 start_pts=102970244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a634.ts13:05:15.418 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a635.ts.tmp' for writing13:05:15.615 frame= 5287 fps= 52 q=-1.0 size= 114293kB time=00:01:46.89 bitrate=8759.3kbits/s throttle=off speed=1.05x13:05:16.118 frame= 5311 fps= 52 q=-1.0 size= 114724kB time=00:01:47.37 bitrate=8753.0kbits/s throttle=off speed=1.05x13:05:16.619 frame= 5332 fps= 52 q=-1.0 size= 115387kB time=00:01:47.79 bitrate=8769.4kbits/s throttle=off speed=1.05x13:05:17.125 frame= 5363 fps= 52 q=-1.0 size= 115949kB time=00:01:48.41 bitrate=8761.6kbits/s throttle=off speed=1.05x13:05:17.628 frame= 5392 fps= 52 q=-1.0 size= 116493kB time=00:01:48.99 bitrate=8755.9kbits/s throttle=off speed=1.05x13:05:18.132 frame= 5412 fps= 52 q=-1.0 size= 117033kB time=00:01:49.39 bitrate=8764.4kbits/s throttle=off speed=1.05x13:05:18.134 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:18.135 SegmentComplete=video:0 Index=35 Start=106.170244 End=108.770244 Duration=2.600000 offset_pts=0 start_pts=106170244 Frames=136 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a635.ts13:05:18.135 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a636.ts.tmp' for writing13:05:18.635 frame= 5438 fps= 52 q=-1.0 size= 117570kB time=00:01:49.91 bitrate=8762.9kbits/s throttle=off speed=1.05x13:05:19.143 frame= 5464 fps= 52 q=-1.0 size= 118049kB time=00:01:50.43 bitrate=8757.2kbits/s throttle=off speed=1.05x13:05:19.643 frame= 5495 fps= 52 q=-1.0 size= 118654kB time=00:01:51.05 bitrate=8752.9kbits/s throttle=off speed=1.05x13:05:20.147 frame= 5521 fps= 52 q=-1.0 size= 119240kB time=00:01:51.57 bitrate=8755.2kbits/s throttle=off speed=1.05x13:05:20.649 frame= 5546 fps= 52 q=-1.0 size= 119746kB time=00:01:52.07 bitrate=8753.0kbits/s throttle=off speed=1.05x13:05:20.653 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:20.654 SegmentComplete=video:0 Index=36 Start=108.890244 End=111.330244 Duration=2.440000 offset_pts=0 start_pts=108890244 Frames=128 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a636.ts13:05:20.654 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a637.ts.tmp' for writing13:05:21.154 frame= 5568 fps= 52 q=-1.0 size= 120174kB time=00:01:52.51 bitrate=8750.0kbits/s throttle=off speed=1.05x13:05:21.656 frame= 5593 fps= 52 q=-1.0 size= 120845kB time=00:01:53.01 bitrate=8759.9kbits/s throttle=off speed=1.05x13:05:22.160 frame= 5619 fps= 52 q=-1.0 size= 121401kB time=00:01:53.53 bitrate=8759.9kbits/s throttle=off speed=1.05x13:05:22.663 frame= 5648 fps= 52 q=-1.0 size= 121898kB time=00:01:54.11 bitrate=8751.1kbits/s throttle=off speed=1.05x13:05:23.165 frame= 5670 fps= 52 q=-1.0 size= 122468kB time=00:01:54.55 bitrate=8758.2kbits/s throttle=off speed=1.05x13:05:23.668 frame= 5696 fps= 52 q=-1.0 size= 122978kB time=00:01:55.07 bitrate=8755.0kbits/s throttle=off speed=1.05x13:05:23.871 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:23.872 SegmentComplete=video:0 Index=37 Start=111.450244 End=114.530244 Duration=3.080000 offset_pts=0 start_pts=111450244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a637.ts13:05:23.872 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a638.ts.tmp' for writing13:05:24.171 frame= 5722 fps= 52 q=-1.0 size= 123567kB time=00:01:55.59 bitrate=8757.3kbits/s throttle=off speed=1.05x13:05:24.775 frame= 5743 fps= 52 q=-1.0 size= 124090kB time=00:01:56.01 bitrate=8762.5kbits/s throttle=off speed=1.05x13:05:25.177 frame= 5761 fps= 52 q=-1.0 size= 124660kB time=00:01:56.37 bitrate=8775.6kbits/s throttle=off speed=1.05x13:05:25.679 frame= 5792 fps= 52 q=-1.0 size= 125176kB time=00:01:56.99 bitrate=8765.2kbits/s throttle=off speed=1.05x13:05:26.182 frame= 5818 fps= 52 q=-1.0 size= 125725kB time=00:01:57.51 bitrate=8764.7kbits/s throttle=off speed=1.05x13:05:26.688 frame= 5845 fps= 52 q=-1.0 size= 126251kB time=00:01:58.05 bitrate=8761.1kbits/s throttle=off speed=1.05x13:05:26.891 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:26.892 SegmentComplete=video:0 Index=38 Start=114.650244 End=117.570244 Duration=2.920000 offset_pts=0 start_pts=114650244 Frames=152 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a638.ts13:05:26.892 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a639.ts.tmp' for writing13:05:27.189 frame= 5874 fps= 52 q=-1.0 size= 126811kB time=00:01:58.63 bitrate=8756.9kbits/s throttle=off speed=1.05x13:05:27.692 frame= 5902 fps= 52 q=-1.0 size= 127355kB time=00:01:59.19 bitrate=8753.2kbits/s throttle=off speed=1.05x13:05:28.195 frame= 5918 fps= 52 q=-1.0 size= 127904kB time=00:01:59.51 bitrate=8767.3kbits/s throttle=off speed=1.05x13:05:28.697 frame= 5946 fps= 52 q=-1.0 size= 128436kB time=00:02:00.07 bitrate=8762.8kbits/s throttle=off speed=1.05x13:05:29.201 frame= 5968 fps= 52 q=-1.0 size= 128941kB time=00:02:00.51 bitrate=8765.1kbits/s throttle=off speed=1.04x13:05:29.703 frame= 5995 fps= 52 q=-1.0 size= 129534kB time=00:02:01.05 bitrate=8766.2kbits/s throttle=off speed=1.04x13:05:29.809 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:29.810 SegmentComplete=video:0 Index=39 Start=117.690244 End=120.450244 Duration=2.760000 offset_pts=0 start_pts=117690244 Frames=144 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a639.ts13:05:29.810 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a640.ts.tmp' for writing13:05:30.207 frame= 6019 fps= 52 q=-1.0 size= 130088kB time=00:02:01.53 bitrate=8768.9kbits/s throttle=off speed=1.04x13:05:30.710 frame= 6046 fps= 52 q=-1.0 size= 130618kB time=00:02:02.07 bitrate=8765.6kbits/s throttle=off speed=1.04x13:05:31.215 frame= 6071 fps= 52 q=-1.0 size= 131101kB time=00:02:02.57 bitrate=8762.1kbits/s throttle=off speed=1.04x13:05:31.718 frame= 6090 fps= 52 q=-1.0 size= 131693kB time=00:02:02.95 bitrate=8774.5kbits/s throttle=off speed=1.04x13:05:32.219 frame= 6118 fps= 52 q=-1.0 size= 132240kB time=00:02:03.51 bitrate=8771.0kbits/s throttle=off speed=1.04x13:05:32.723 frame= 6145 fps= 52 q=-1.0 size= 132793kB time=00:02:04.05 bitrate=8769.4kbits/s throttle=off speed=1.04x13:05:33.227 frame= 6173 fps= 52 q=-1.0 size= 133335kB time=00:02:04.61 bitrate=8765.6kbits/s throttle=off speed=1.04x13:05:33.531 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:33.532 SegmentComplete=video:0 Index=40 Start=120.570244 End=124.130244 Duration=3.560000 offset_pts=0 start_pts=120570244 Frames=184 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a640.ts13:05:33.532 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a641.ts.tmp' for writing13:05:33.732 frame= 6201 fps= 52 q=-1.0 size= 133882kB time=00:02:05.17 bitrate=8762.1kbits/s throttle=off speed=1.04x13:05:34.239 frame= 6220 fps= 52 q=-1.0 size= 134420kB time=00:02:05.55 bitrate=8770.8kbits/s throttle=off speed=1.04x13:05:34.745 frame= 6248 fps= 52 q=-1.0 size= 134970kB time=00:02:06.11 bitrate=8767.5kbits/s throttle=off speed=1.04x13:05:35.248 frame= 6273 fps= 52 q=-1.0 size= 135523kB time=00:02:06.61 bitrate=8768.6kbits/s throttle=off speed=1.04x13:05:35.351 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:35.352 SegmentComplete=video:0 Index=41 Start=124.250244 End=126.050244 Duration=1.800000 offset_pts=0 start_pts=124250244 Frames=96 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a641.ts13:05:35.352 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a642.ts.tmp' for writing13:05:35.752 frame= 6298 fps= 52 q=-1.0 size= 136078kB time=00:02:07.11 bitrate=8770.0kbits/s throttle=off speed=1.04x13:05:36.255 frame= 6322 fps= 52 q=-1.0 size= 136601kB time=00:02:07.59 bitrate=8770.5kbits/s throttle=off speed=1.04x13:05:36.760 frame= 6346 fps= 52 q=-1.0 size= 137131kB time=00:02:08.07 bitrate=8771.6kbits/s throttle=off speed=1.04x13:05:37.262 frame= 6377 fps= 52 q=-1.0 size= 137694kB time=00:02:08.69 bitrate=8765.2kbits/s throttle=off speed=1.04x13:05:37.765 frame= 6402 fps= 52 q=-1.0 size= 138241kB time=00:02:09.19 bitrate=8765.9kbits/s throttle=off speed=1.04x13:05:38.068[q] command received. Exiting.13:05:38.069 13:05:38.070 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:38.071 SegmentComplete=video:0 Index=42 Start=126.170244 End=129.250244 Duration=3.080000 offset_pts=0 start_pts=126170244 Frames=160 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a642.ts13:05:38.071 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a643.ts.tmp' for writing13:05:38.072 [segment @ 0x83aac0] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/52431ec847100d8e5bb4ed5a05a6b0a6.m3u8.tmp' for writing13:05:38.072 SegmentComplete=video:0 Index=43 Start=129.370244 End=129.570244 Duration=0.200000 offset_pts=0 start_pts=129370244 Frames=16 filename=hls/52431ec847100d8e5bb4ed5a05a6b0a6/52431ec847100d8e5bb4ed5a05a6b0a643.ts13:05:38.072 frame= 6416 fps= 52 q=-1.0 Lsize= 138540kB time=00:02:09.47 bitrate=8765.9kbits/s throttle=off speed=1.04x13:05:38.072 video:135515kB audio:3025kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%Last message repeated 1 times13:05:38.073 EXIT13:05:38.073 [aac @ 0x803640] Qavg: 2047.06813:05:38.073
magootoo 0 Posted February 10, 2020 Author Posted February 10, 2020 It will play the first channel I select in the web player but when I change channel I get the spooning circle and the new channel doesn’t play.
Luke 42244 Posted February 11, 2020 Posted February 11, 2020 How exactly are you trying to change channels? Are you coming to a full stop first, backing out, and then playing a different channel?
magootoo 0 Posted February 11, 2020 Author Posted February 11, 2020 HI Luke, Sorry but nothing is playing now, I've attached the most recent logs, I really appreciatte your help in getting this solved. Thanks, M embyhardware.txt embylog.txt
