IanoPachino 1 Posted December 31, 2019 Posted December 31, 2019 Hi, When I upload a bunch of movies from say for instance F/Movies/2019Movies or F/Movies/2018Movies everything is uplaoding and metadata is showing perfectly But when i'm uploading my collections from F/Movies/Boxsets/DieHardCollection no metedata shows for these movies. It's the same for all my collections i am trying to add. I left an image below. Is it the way i have them grouped on my hard drive that's causing this ? Thank You
Luke 42216 Posted December 31, 2019 Posted December 31, 2019 Hi, it's probably due to your file naming. Have you compared your file names to our recommended movie naming guidelines?
Solution IanoPachino 1 Posted December 31, 2019 Author Solution Posted December 31, 2019 Hi, it's probably due to your file naming. Have you compared your file names to our recommended movie naming guidelines? Yep it was the way i named my files, seems to be working OK now, thank you ! 1
