Tupsi 4 Posted December 31, 2019 Posted December 31, 2019 (edited) When you enable the statistics for nerds in the app the box shows you video and audio details and if the stream gets trancoded or is direct play. Now if you press down on the remote and select another audio in your stream this info does not get updated and still shows the audio info how you have started. Edited December 31, 2019 by Tupsi
Luke 42246 Posted December 31, 2019 Posted December 31, 2019 Hi, what if you close and reopen the stats feature?
ebr 16338 Posted December 31, 2019 Posted December 31, 2019 Hi. Yes, if direct playing, this information may not update. If direct streaming or transcoding, it will but it may take up to 10 seconds for you to see it. Thanks for the report.
Tupsi 4 Posted December 31, 2019 Author Posted December 31, 2019 Hi, what if you close and reopen the stats feature? does not change and stays at the original start info (so wrong). It does change to the correct info if I go down with my quality settings so low, that I force the server to switch to transcoding. Then it takes like 2seconds and boom it says transcoding with the reason and all the new audio/video stuff. But just switching audio streams, the box stays at the original info, so it seems it needs an update trigger somewhere in the code :-)
ebr 16338 Posted January 1, 2020 Posted January 1, 2020 As I mentioned above, this should only be an issue if direct playing an item. Can you please confirm that is what you are seeing as well? Thanks.
Tupsi 4 Posted January 2, 2020 Author Posted January 2, 2020 As I mentioned above, this should only be an issue if direct playing an item. Can you please confirm that is what you are seeing as well? Thanks. correct. If I force a transcode (by lowering quality for instance) it changes to the new infos just fine.
