tdiguy 99 Posted December 31, 2019 Posted December 31, 2019 (edited) This is not something I took notice of before but I am pretty sure it worked properly. It seems that setting the option to enable full speed conversion to checked or unchecked makes no difference in cpu usage. Both act as if checked. When i look at the priority in htop or top i see it is set for 0 either way. I would imagine it should be much lower with the box unchecked. Edited December 31, 2019 by tdiguy
tdiguy 99 Posted December 31, 2019 Author Posted December 31, 2019 It doesn't affect the process priority. Ahh ok, is there anything i can look at to see if it is working? It seems like my server runs about the same if it is checked or not.
Solution Luke 42246 Posted December 31, 2019 Solution Posted December 31, 2019 You can check for the -re command line param in the conversion log. 1
