ebr 16310 Posted September 29, 2020 Posted September 29, 2020 2 hours ago, vdatanet said: So it's remuxing as expected. What I find strange is what happens to me, a Shield connected to a TV that does not support DTS, and with both DTS and DTS-MA I get direct playback. And either stereo or software decoded PCM audio, correct?
vdatanet 1619 Posted September 29, 2020 Posted September 29, 2020 13 minutes ago, ebr said: And either stereo or software decoded PCM audio, correct? Yes, like the Android TV app when audio output is set to stereo,, shown as local downmix in SFN. Just a presumption, because this TV does not display information about the audio it receives and SFN simply displays DTS audio.
ebr 16310 Posted September 29, 2020 Posted September 29, 2020 1 minute ago, vdatanet said: Yes, like the Android TV app when audio output is set to stereo,, shown as local downmix in SFN. Just a presumption, because this TV does not display information about the audio it receives and SFN simply displays DTS audio. So you are losing high quality 5.1 audio in favor of direct playing. You can do the same thing in the TV app with that option.
vdatanet 1619 Posted September 29, 2020 Posted September 29, 2020 Just now, ebr said: So you are losing high quality 5.1 audio in favor of direct playing. You can do the same thing in the TV app with that option. Yes, that's OK for the TV. But what is discussed here is that when remux is required in some cases it shows green artifacts. Avoiding a remux is a workaround not a solution. For example, a 5.1 soundbar without DTS support, requires a DTS 5.1 to AC3 5.1 remux, local downmix is not acceptable, and then green artifacts are shown. I would bet this is a segmentation problem. The same thing happened in Plex but they have changed the segmentation to MKV containers and the problem was solved.
CBers 7542 Posted September 29, 2020 Posted September 29, 2020 24 minutes ago, vdatanet said: Yes, like the Android TV app when audio output is set to stereo,, shown as local downmix in SFN. Just a presumption, because this TV does not display information about the audio it receives and SFN simply displays DTS audio. Local downmix is being done by the client device, your Shield in this instance, rather than by the server.
arrbee99 1836 Posted September 30, 2020 Author Posted September 30, 2020 13 hours ago, vdatanet said: Can you share a little sample? These are the same files as mentioned back on page 1, post 12(ish) - https://1drv.ms/u/s!AmkRWNKmKxThiKFMrTzJthKR25_Cng?e=WcS44j https://1drv.ms/u/s!AmkRWNKmKxThiKFNHOItEBa76iOjxA?e=WtWsYB https://1drv.ms/u/s!AmkRWNKmKxThiKFO7wiQQQIFiy_E_Q?e=R5fWmy
vdatanet 1619 Posted September 30, 2020 Posted September 30, 2020 (edited) 6 hours ago, arrbee99 said: These are the same files as mentioned back on page 1, post 12(ish) - https://1drv.ms/u/s!AmkRWNKmKxThiKFMrTzJthKR25_Cng?e=WcS44j https://1drv.ms/u/s!AmkRWNKmKxThiKFNHOItEBa76iOjxA?e=WtWsYB https://1drv.ms/u/s!AmkRWNKmKxThiKFO7wiQQQIFiy_E_Q?e=R5fWmy Results are as I expected, there's nothing wrong with the rip: In a supported TrueHD 7.1 system, both Plex and Emby played the sample without glitching. In an unsupported TrueHD 7.1 system (remuxing was required). Both Emby for Android and Emby for Android TV showed glitching during playback Plex using MKV segments played the sample without glitching So, you know what to do. Review HLS segmentation while playing HEVC files Maybe this Topic should be pinned, or better this one, for me is a major bug: Edited September 30, 2020 by vdatanet
