TylerDurden_BS 1 Posted May 6, 2021 Posted May 6, 2021 Hello Montellese, yes it's the same thing for me like in the issue you describe. I use two profiles (named it Parents / Kids) both profiles sign to the same profile in Emby. Master profile (Parents) still working, all imported, all fine. Kids profile first use, my Emby server is added as active media import, have to delete it, recrate it with IP-Adress and Port, in settings the creds from my son, add import, inital sync all is fine. Then my son watch TV Show on FireTV+Kodi+emby-next-gen all sync to Emby server, i see this in Emby Webview. But in media import nothing changes, nor when I put new Shows in Emby folder ? I know that's obvisiouly nobody works with profiles in Kodi, but that's for me the best way to devide content for parents and kids. In german forum kodinerds sualfred says so several times that profile in kodi is broken, but that's the only way (for me). In Win10 or Linux you can work with users, but what's with FireTV and others ?
Montellese 11 Posted May 12, 2021 Posted May 12, 2021 @TylerDurden_BS I think I figured out what the problem is. I've prepared test builds. Can you verify if it solves your problem with multiple profiles? Windows x64: http://mirrors.kodi.tv/test-builds/windows/win64/KodiSetup-20210511-d4ef03b8-media_import_19.0-Matrix_profiles-x64.exe Android ARM v7a: http://mirrors.kodi.tv/test-builds/android/arm/kodi-20210511-d4ef03b8-media_import_19.0-Matrix_profiles-armeabi-v7a.apk Android ARM64 v8a: http://mirrors.kodi.tv/test-builds/android/arm64-v8a/kodi-20210511-d4ef03b8-media_import_19.0-Matrix_profiles-arm64-v8a.apk Thanks for your feedback.
TylerDurden_BS 1 Posted May 13, 2021 Posted May 13, 2021 Hello Montellese, first at all - Thanx a lot ! Did a fresh Install, Parents profile, all seems find. First new is that after activate MediaImport it auto detect my emby server. Kids profile, it detect it too and in settings it's empty. Did all sync fine, after reboot my Win10 machine, and on Emby Web sign an episode as watched it sync corrct with MediaImport. Will do more tests later. Thumbs up !
LongMan 116 Posted May 14, 2021 Author Posted May 14, 2021 New builds at https://github.com/Montellese/xbmc/wiki/Downloads. They are based on the latest Kodi v19.1 Matrix and include a fix for using media import with multiple separate profiles. @alscaldas Rockchip LibreELEC build attached LibreELEC-RK3399.arm-10.0-devel-20210514020711-0f2dcbe-rockpro64.img.gz
LongMan 116 Posted May 20, 2021 Author Posted May 20, 2021 A few days ago Montellese uploaded new test builds at Downloads / Changelog which can greatly improve the performance of retrieving and passing media items from Python-based media importers to Kodi. For the performance improvements to become visible you also need to update the media importer add-on to the latest version which was just released: mediaimporter.emby: v0.0.12 The performance improvement is very noticeable especially for the initial sync. Please provide feedback on your experience. @alscaldas The corresponding Rockchip build is attached. LibreELEC-RK3399.arm-10.0-devel-20210518023526-78a6331-rockpro64.img.gz 1
TylerDurden_BS 1 Posted May 20, 2021 Posted May 20, 2021 Hello LongMan, Download Links for x64 and Armv7a are broken ?
LongMan 116 Posted May 20, 2021 Author Posted May 20, 2021 @TylerDurden_BS They are working for me. Please try again.
TylerDurden_BS 1 Posted May 20, 2021 Posted May 20, 2021 Hey LongMan, hm...normally I use Chrome, no download, delete cache, no download. With MS Edge download is fine...
TylerDurden_BS 1 Posted May 20, 2021 Posted May 20, 2021 Ok, fresh install on my Win10 Test machine, with media.importer 0.0.12 seems first sync os faster than before. Maybe tomorrow give it a second chance on my old 1st Gen Amazon FireTV. Will report it.
alscaldas 0 Posted May 22, 2021 Posted May 22, 2021 @LongMan I hadn't seen your post... Thanks for making this new RockPro64 version available!
LongMan 116 Posted May 25, 2021 Author Posted May 25, 2021 @horstepipe Could you do a test run on these builds and provide some feedback. I know you have the capabilities to give a proper stress test. You feedback would be greatly appreciated. Cheers, LongMan 1
horstepipe 423 Posted May 26, 2021 Posted May 26, 2021 (edited) with recent version I can't establish a connection mhh. kodi.log Edited May 26, 2021 by horstepipe
Montellese 11 Posted May 26, 2021 Posted May 26, 2021 Unfortunately you ran into a known issue where something is wonky in Kodi's Python integration resulting in Python exceptions not being caught. Sometimes it happens sometimes it doesn't. You might have more luck trying again.
horstepipe 423 Posted May 26, 2021 Posted May 26, 2021 That error (with GUI message) you see in that log only happened once. I tried several times but it can’t connect. Are there issues about https with that build? I‘ll try without nginx later this week.
TylerDurden_BS 1 Posted May 26, 2021 Posted May 26, 2021 Hm, on both Test machines, Win10 und Amazon Fire TV I have to restart once, then it connect ?
Montellese 11 Posted May 27, 2021 Posted May 27, 2021 12 hours ago, horstepipe said: That error (with GUI message) you see in that log only happened once. I tried several times but it can’t connect. Are there issues about https with that build? I‘ll try without nginx later this week. I have never tested with HTTPS so I'm not sure whether it works or not. I can see warnings in the logs that the HTTPS requests are unverified. Furthermore it says that it cannot authenticate the user with the current settings. Could you enable debug logging so that I can see more details in the log? Thanks for the feedback. 11 hours ago, TylerDurden_BS said: Hm, on both Test machines, Win10 und Amazon Fire TV I have to restart once, then it connect ? That's odd. But I haven't run a clean build in a while so maybe I just didn't notice. I'll do that ASAP.
horstepipe 423 Posted June 1, 2021 Posted June 1, 2021 it is working now but I don't know why lol. Maybe I made some nonsense last time or it is because I updated Emby to beta. So it is syncing now for some minutes, the progress bar stays at 0%. From server logs it looks like it is currently only fetching local trailers (I have them locally to each movie). 2021-06-01 13:00:01.247 Info Server: http/1.1 GET http://domain/emby/Users/xxx/Items/1151/LocalTrailers.
horstepipe 423 Posted June 4, 2021 Posted June 4, 2021 15 hours ago, LongMan said: @horstepipeAny update? Sorry I forgot to post. mhh from what I see sync is even slower now than before, it took about an hour to sync my movies. With Emby for Kodi it takes half an hour. Maybe this is because of the trailers I mentioned in the post before?
LongMan 116 Posted June 4, 2021 Author Posted June 4, 2021 That's strange. It took 8 and half minutes to sync my libraries. That is by far the fastest sync I have ever seen. This includes Emby for Kodi and Emby Next Gen. Could you verify that the importer is at lest version 12 and you have the latest build
horstepipe 423 Posted June 4, 2021 Posted June 4, 2021 4 hours ago, LongMan said: That's strange. It took 8 and half minutes to sync my libraries. That is by far the fastest sync I have ever seen. This includes Emby for Kodi and Emby Next Gen. Could you verify that the importer is at lest version 12 and you have the latest build Do you have LOCAL trailers for your movies in Emby? I will verify again.
Montellese 11 Posted June 4, 2021 Posted June 4, 2021 1 hour ago, horstepipe said: Do you have LOCAL trailers for your movies in Emby? Unfortunately LOCAL trailers have to be retrieved manually for every item (or I haven't found another way) because they aren't provided as part of the main response. That certainly slows things down considerably because it will result in a lot more queries than necessary to just retrieve all media items. I could make it optional similar to retrieving collections so speed things up. But you obviously lose some information in Kodi as an Emby client. 1
LongMan 116 Posted June 29, 2021 Author Posted June 29, 2021 @alscaldas Updated Rock pro build attached. No change to MediaImport, the updates are for LibreELEC. Cheers, LongMan LibreELEC-RK3399.arm-10.0-devel-20210628221213-f904c2e-rockpro64.img.gz 1
Heinrich 1 Posted July 1, 2025 Posted July 1, 2025 If I understand correctly, if I want animated posters (which I had a few years back and still exist on my UNRAID Emby Database) they need to be local (per Kodi Wiki.) Is this the only way to GET them local? Or can I fake Kodi out somehow with path substitution?
