bflagg 2 Posted December 28, 2019 Posted December 28, 2019 Samsung UN65HU9000 (Tizen). Emby app prompts to either connect to server or sign in with emby connect. I choose emby connect. I enter the pin code on my phone browser, Pin accepted. Emby Restarts with the same screen. "Connect to Server" or "Sign in with Emby Connect". I've uninstalled the app and reinstalled it from the samsung "play" store. This worked just fine until I had to rebuild by MediaCenter. In the past after entering the pin and being accepted, the Emby Dashboard would load. I can connect to Emby from remote locations and locally. Is there a way to for you to look on your end on why this is happening? reset perhaps?
Luke 42242 Posted December 28, 2019 Posted December 28, 2019 Hi, this means you most likely don't have any servers associated with Emby Connect. Did you do this process here? https://github.com/MediaBrowser/Wiki/wiki/Emby-Connect#guide-for-administrators
bflagg 2 Posted February 25, 2020 Author Posted February 25, 2020 Hi Luke.. It's happened again. I click the link above and it goes to a blank git hub. Also, How do I go about changing the login name and email addresses for the accounts that I have with emby connect?
