pünktchen 1411 Posted December 31, 2023 Author Posted December 31, 2023 31 minutes ago, Dibbes said: about 3.2 million mediaitems in the database... How many channels do you have? How long does the guide refresh run? Everybody where it runs faster should be good then. 1
Junglejim 385 Posted December 31, 2023 Posted December 31, 2023 12 minutes ago, pünktchen said: How many channels do you have? How long does the guide refresh run? Everybody where it runs faster should be good then. I think most people/library's should be a little faster than @Dibbes.. That is huge.. I personally have like 15 channels at the mo and a guide refresh takes like 15 seconds..(movies=411, shows=162, ep=4080).
Dibbes 515 Posted December 31, 2023 Posted December 31, 2023 (edited) 3 hours ago, pünktchen said: How many channels do you have? How long does the guide refresh run? Everybody where it runs faster should be good then. The guide refresh is about 11 hours, down from about 34hrs. That includes about 800 TV channels from various countries as well. (My family has dispersed all over Europe) I'm still on the previous version, so with the old max of 30, with 3 disabled channels. At the moment I haven't found the energy yet, with all the Christmas travels and cheer, to note down all my channel settings and start from scratch on version 2. I have some ideas on those channels as there seem to be unlimited now, but I need to test and plan that Edited December 31, 2023 by Dibbes
pünktchen 1411 Posted December 31, 2023 Author Posted December 31, 2023 43 minutes ago, Dibbes said: The guide refresh is about 11 hours, down from about 34hrs. That includes about 800 TV channels from various countries as well. I'm curious about what alone the VirtualTV channels need of this time.
Dibbes 515 Posted December 31, 2023 Posted December 31, 2023 1 minute ago, pünktchen said: I'm curious about what alone the VirtualTV channels need of this time. The majority. At least over 10hrs. When I disabled the plugin a few months back by renaming the.dll, the refresh was about half an hour... I need to streamline this a little. I still have 30TB worth of archived stuff on slow, low cost storage... These populate 6 channels alone...
crusher11 1148 Posted January 1, 2024 Posted January 1, 2024 On 12/30/2023 at 1:02 AM, crusher11 said: What does "cache program data until TV guide runs empty" do? Still waiting on an answer for this one.
Luke 42253 Posted January 1, 2024 Posted January 1, 2024 2 hours ago, crusher11 said: Still waiting on an answer for this one. Have you tried the latest update? Maybe he improved the help text on it.
Dibbes 515 Posted January 1, 2024 Posted January 1, 2024 (edited) @pünktchenis there any way you can build some logging into this? I'd like to find out what the exact cause is this takes so long... is it just waiting for time-outs? is it scanning every single file for data? Nevermind, I just found the debug logging tickbox in V2 Edited January 1, 2024 by Dibbes
pünktchen 1411 Posted January 1, 2024 Author Posted January 1, 2024 3 minutes ago, Dibbes said: is it scanning every single file for data? More or less, yes. Every library item (not the real file) from the paths you've selected is examined for data in every single condition. In the new plugin there's an extra debug logging of the channel rules for a selected channel. But that will probably explode your log file. I will look into adding some time measurement. 1
pünktchen 1411 Posted January 1, 2024 Author Posted January 1, 2024 14 hours ago, crusher11 said: Still waiting on an answer for this one. And i'm still waiting for feedback on your bug report
Dibbes 515 Posted January 1, 2024 Posted January 1, 2024 5 minutes ago, pünktchen said: But that will probably explode your log file That's fine... the drive has enough space 1
Dibbes 515 Posted January 1, 2024 Posted January 1, 2024 (edited) @pünktchenIs there a possibility to add a criteria here that says "Include only these named movies or TV shows"? I've tried the below, but that does not give me anything on the channel. I suppose I could split out the library into separate shows, and then get these added on Emby level, but that seems to defy the purpose of libraries. Another option would be to make the folder selection more granular and display subfolders to select specific series, but I'm not sure if that is the best option. Edited January 1, 2024 by Dibbes
pünktchen 1411 Posted January 2, 2024 Author Posted January 2, 2024 2 hours ago, Dibbes said: Is there a possibility to add a criteria here that says "Include only these named movies or TV shows"? It should work like this without any other condition. 2 hours ago, Dibbes said: I've tried the below, but that does not give me anything on the channel. Because you are excluding everything with an asterisk. 1
Dibbes 515 Posted January 2, 2024 Posted January 2, 2024 9 hours ago, pünktchen said: It should work like this without any other condition. That's the point, I get more than just what's in that condition box 9 hours ago, pünktchen said: Because you are excluding everything with an asterisk. The way I thought that was going to work was that everything is excluded, except for what's in the "always" condition No worries, I'll find a way
pünktchen 1411 Posted January 2, 2024 Author Posted January 2, 2024 4 minutes ago, Dibbes said: That's the point, I get more than just what's in that condition box With which plugin version? I know it it wasn't working at some time, but i cannot replicate it anymore.
Dibbes 515 Posted January 2, 2024 Posted January 2, 2024 2 minutes ago, pünktchen said: With which plugin version? I know it it wasn't working at some time, but i cannot replicate it anymore. the latest from the plugin store 2.0.0.1
pünktchen 1411 Posted January 2, 2024 Author Posted January 2, 2024 @Dibbes"Free Documentary" and "FreeDocumentary", is this the same show but in different libraries? If so, do both may have a few identical episodes?
Dibbes 515 Posted January 2, 2024 Posted January 2, 2024 (edited) Yes, this is the same show in the same library in the same folder... these are Youtube downloads and the filenames are inconsistent. I tried with either "Free Documentary", "FreeDocumentary" and both (no quotes obviously). Same result though. Edited January 2, 2024 by Dibbes
pünktchen 1411 Posted January 2, 2024 Author Posted January 2, 2024 38 minutes ago, Dibbes said: "Free Documentary" Is this the show name or the folder name? Maybe you can also try the channel rule debugging?
Dibbes 515 Posted January 2, 2024 Posted January 2, 2024 36 minutes ago, pünktchen said: Is this the show name or the folder name? Maybe you can also try the channel rule debugging? Both
Dibbes 515 Posted January 2, 2024 Posted January 2, 2024 37 minutes ago, pünktchen said: Maybe you can also try the channel rule debugging? I'll give it a shot... however, the refresh has been hanging on 15% for the last 12hrs with a 20% CPU usage on the Emby process and not a thing in the log. Let's see when that finishes...
pünktchen 1411 Posted January 2, 2024 Author Posted January 2, 2024 15 minutes ago, Dibbes said: I'll give it a shot... however, the refresh has been hanging on 15% for the last 12hrs with a 20% CPU usage on the Emby process and not a thing in the log. Let's see when that finishes... You should have deactivated all other channels for a test case.
Dibbes 515 Posted January 2, 2024 Posted January 2, 2024 (edited) 37 minutes ago, pünktchen said: You should have deactivated all other channels for a test case. Agreed, but I only put in 12 (of which the other 11 have a populated guide) and I removed the other M3U TV sources... the channels from the previous plugin version have not deleted from the UI yet either... The DB seems locked as the log displays an open socket when opening a webpage, but the page takes 30min to load. One of these days I should setup a test environment... until that days comes, testing takes a lot of patience Edited January 2, 2024 by Dibbes
pünktchen 1411 Posted January 3, 2024 Author Posted January 3, 2024 @Dibbesdid you also upgrade your Emby installation to the latest beta just for the new plugin version? I did some testing: My production system is still on Emby 4.8.0.13. The guide refresh takes at average 15 seconds here. Then i created a copy of the Emby installation and upgraded it to 4.8.0.65. Now the guide refresh takes at average 70 seconds! That's 4.5 times longer than before! And my library is not that big. What is going on here @Luke?
Luke 42253 Posted January 3, 2024 Posted January 3, 2024 1 hour ago, pünktchen said: @Dibbesdid you also upgrade your Emby installation to the latest beta just for the new plugin version? I did some testing: My production system is still on Emby 4.8.0.13. The guide refresh takes at average 15 seconds here. Then i created a copy of the Emby installation and upgraded it to 4.8.0.65. Now the guide refresh takes at average 70 seconds! That's 4.5 times longer than before! And my library is not that big. What is going on here @Luke? Hi, let's look at an example: How to Report a Problem Thanks.
