badwhip 4 Posted August 8, 2023 Posted August 8, 2023 a while ago i asked if you had any plans to allow usthe holy grail of letting us pick exact day and time for tv shows and you had allot going on as it was still new etc. any plan for this in future? by the way your plug in is main reason im using emby over plex. love it.
hstamas 179 Posted August 11, 2023 Posted August 11, 2023 On 8/8/2023 at 4:12 PM, badwhip said: a while ago i asked if you had any plans to allow usthe holy grail of letting us pick exact day and time for tv shows and you had allot going on as it was still new etc. any plan for this in future? by the way your plug in is main reason im using emby over plex. love it. @badwhipAlthough not as nicely integrated or easy as the VirtualTV plugin is, EraszTV - https://ersatztv.org - will do what your looking for.
pünktchen 1411 Posted August 11, 2023 Author Posted August 11, 2023 Those on Emby beta should update to the new version 4.8.0.41 once its available. 1
Jack Burton 98 Posted August 16, 2023 Posted August 16, 2023 (edited) Hey, I just found this and love it! I've been trying to go through the comments for some answers but there's a lot, so hopefully I can just ask here. 1. How does exclusion work? I made a channel for just The Simpsons, but want to exclude season 0/specials. I've tried Season 0, Specials, s00, s0, Season0 but nothing seems to work. 2. If I set watched after percent to 0, will it never add the show/movie to Continue Watching on the home page? This is what I'm hoping. 3. New movies. So I can set a channel for new releases, can I set anything more specific than year? Ideally maybe quarterly, or even monthly? So far, these are the 3 I haven't figured out myself yet. I'll be playing with this for a while I'm sure haha, great job. I've been using Emby for years (Kodi before that) and suddenly popped into my head remembering PseudoTV and bam, here we are! Edit: Also, what is the difference in playback methods? Edited August 16, 2023 by Jack Burton
PuffyToesToo 348 Posted August 17, 2023 Posted August 17, 2023 I can help with your first one. In my SS below, I have Specials and the last 4 seasons of a particular show tagged with '!Skip'. That will exclude those items from populating in the channel for me. Using the same example, you can use- !Skip | Another Tag -to exclude items with either tag. Hope that helps. 1 1
Jack Burton 98 Posted August 17, 2023 Posted August 17, 2023 53 minutes ago, PuffyToesToo said: I can help with your first one. In my SS below, I have Specials and the last 4 seasons of a particular show tagged with '!Skip'. That will exclude those items from populating in the channel for me. Using the same example, you can use- !Skip | Another Tag -to exclude items with either tag. Hope that helps. Ok, so if I wanted to skip specials, I would type !Skip|Season 0 ?
pünktchen 1411 Posted August 17, 2023 Author Posted August 17, 2023 23 hours ago, Jack Burton said: 1. How does exclusion work? I made a channel for just The Simpsons, but want to exclude season 0/specials. I've tried Season 0, Specials, s00, s0, Season0 but nothing seems to work. You have to create tags (a single word or phrase) on season or episode level in Emby's metadata editor. The same tag you have to use then as exclude condition. 23 hours ago, Jack Burton said: 2. If I set watched after percent to 0, will it never add the show/movie to Continue Watching on the home page? This is what I'm hoping. In combination with the playback option to "Clear resume points" maybe. But that is unintentional from my side. What you want is "Remove shows from Continue Watching" under the plugins playback options, but currently the plugin will only remove shows from Continue Watching if the user has manually removed the show previously from Continue Watching. In other words, if the show was already hidden and only then, the plugin will keep it hidden. If it's a new show, you'll have to manually remove it from Continue Watching one time. I'm already reworking those options. 23 hours ago, Jack Burton said: 3. New movies. So I can set a channel for new releases, can I set anything more specific than year? Ideally maybe quarterly, or even monthly? No. 23 hours ago, Jack Burton said: Edit: Also, what is the difference in playback methods? See the thread start post! 1
Jack Burton 98 Posted August 17, 2023 Posted August 17, 2023 Quote You have to create tags (a single word or phrase) on season or episode level in Emby's metadata editor. The same tag you have to use then as exclude condition. Haha wow, I didn't even connect tags meant those tags. Still can't seem to get it to work but I'll keep playing. Quote In combination with the playback option to "Clear resume points" maybe. But that is unintentional from my side. What you want is "Remove shows from Continue Watching" under the plugins playback options, but currently the plugin will only remove shows from Continue Watching if the user has manually removed the show previously from Continue Watching. In other words, if the show was already hidden and only then, the plugin will keep it hidden. If it's a new show, you'll have to manually remove it from Continue Watching one time. I'm already reworking those options. I use Continue Watching all the time and hate clutter, but this seems pretty perfect for me. Seems to add it to Continue Watching as you're watching, but if you stop the show/movie it doesn't show up on it. Perfect. Quote See the thread start post! Yeah, I've been digging deep since I found this and totally forgot it was there. Great job btw, this is really cool.
PuffyToesToo 348 Posted August 18, 2023 Posted August 18, 2023 17 hours ago, Jack Burton said: Ok, so if I wanted to skip specials, I would type !Skip|Season 0 ? Yes, (only if that is the tag you use for that series/season). You can make the tag whatever you like. So if the show is Star Trek (for example), and you don't want Specials or seasons 5-6 to play, go to those seasons and add the tag you prefer to the metadata. Here is where you place your tag, and just make sure it matches in the exclude section posted above.
Jack Burton 98 Posted August 18, 2023 Posted August 18, 2023 15 minutes ago, PuffyToesToo said: Yes, (only if that is the tag you use for that series/season). You can make the tag whatever you like. So if the show is Star Trek (for example), and you don't want Specials or seasons 5-6 to play, go to those seasons and add the tag you prefer to the metadata. Here is where you place your tag, and just make sure it matches in the exclude section posted above. Hmmm, I don't understand what I'm doing wrong. I have a channel set for The Simpsons and want to exclude specials and season 1. I added !Skip as a tag for both seasons. I then put !Skip in the "But exclude tv show seasons or episodes by these tags:" bar. Now the channel is populated with episodes of The Twilight Zone, Masterclass, The Golden Girls, and Planet Earth. I have no idea what these shows have in common to even begin to troubleshoot.
PuffyToesToo 348 Posted August 18, 2023 Posted August 18, 2023 1 hour ago, Jack Burton said: Hmmm, I don't understand what I'm doing wrong. I have a channel set for The Simpsons and want to exclude specials and season 1. I added !Skip as a tag for both seasons. I then put !Skip in the "But exclude tv show seasons or episodes by these tags:" bar. Now the channel is populated with episodes of The Twilight Zone, Masterclass, The Golden Girls, and Planet Earth. I have no idea what these shows have in common to even begin to troubleshoot. Have you tried tagging the entire show? You should be able to do that at the top level for the series. Just be sure to give it a different tag than the one used for exclusion. Then be sure to put that tag in this field (that tells VirtualTV to require this tag for that channel). 1
Jack Burton 98 Posted August 18, 2023 Posted August 18, 2023 1 hour ago, PuffyToesToo said: Have you tried tagging the entire show? You should be able to do that at the top level for the series. Just be sure to give it a different tag than the one used for exclusion. Then be sure to put that tag in this field (that tells VirtualTV to require this tag for that channel). Thanks for the help, I got it working. I had The Simpsons in the channel by having it in the "Always include these named movies or tv shows:" only. I made a tag for the series, and added that to the tag bar. Leaving the previous !Skip tag on the exclusion excluded those 2 seasons. Thanks a lot, I appreciate it!
PuffyToesToo 348 Posted August 18, 2023 Posted August 18, 2023 Glad you got it working! You're welcome! 1 1
jdazzle44 7 Posted August 21, 2023 Posted August 21, 2023 (edited) Thanks for this amazing plugin! I'm having an issue exporting real live tv guide data. I tried both the URL and Folder option. The URL (http://10.1.100.39:8096/emby/virtualtv/guide?streamtype=universal) only contains my virtual tv guide data and the folder option seems to have all the program data but it's only showing the channels when I load the guide data in other apps. This show's up in the emby logs when I query the guide data URL. 2023-08-21 08:18:11.055 Info VirtualTV: ApiService > GetProgramGuide Edited August 21, 2023 by jdazzle44
pünktchen 1411 Posted August 22, 2023 Author Posted August 22, 2023 The export options in the plugin and the api endpoints are mostly independant of each other. On 8/21/2023 at 2:14 PM, jdazzle44 said: The URL (http://10.1.100.39:8096/emby/virtualtv/guide?streamtype=universal) only contains my virtual tv guide data Because it's missing the parameter RealLiveTv=true On 8/21/2023 at 2:14 PM, jdazzle44 said: the folder option seems to have all the program data Probably because you've enabled the option to export real live tv data. On 8/21/2023 at 2:14 PM, jdazzle44 said: but it's only showing the channels when I load the guide data in other apps What do mean by this?
jdazzle44 7 Posted August 22, 2023 Posted August 22, 2023 7 hours ago, pünktchen said: What do mean by this? If I open the xml file in notepad++, I can see the program data but it doesn't load the program data for the channels in any of the apps I tried. (jellyfin, xteve) I'm not sure if it's an formatting issue.
pünktchen 1411 Posted August 23, 2023 Author Posted August 23, 2023 Please send me the guide.xml file.
jdazzle44 7 Posted August 23, 2023 Posted August 23, 2023 20 hours ago, pünktchen said: Please send me the guide.xml file. Sent
MarkE2794 1 Posted September 20, 2023 Posted September 20, 2023 Hi I've set everything up and the channel shows but i am not getting any programs to show am i missing something, if i am please help if possible thank you
jordy 284 Posted September 21, 2023 Posted September 21, 2023 have you set up the tags on the shows you want to show up in the channel?
pünktchen 1411 Posted September 21, 2023 Author Posted September 21, 2023 22 hours ago, MarkE2794 said: Hi I've set everything up and the channel shows but i am not getting any programs to show am i missing something, if i am please help if possible thank you Have you set any channel rule other than choosing the libraries? That's a requirement!
MarkE2794 1 Posted September 22, 2023 Posted September 22, 2023 your talking about the options likes years, genres, tags, actors, etc, right i have, i have the years, all shows which are seperated the "|" , and 2 genres. Can you space between "|" or is it all just one word then seperated by "|" Like " LengendofZelda| or Legend of Zelda|"?
pünktchen 1411 Posted September 22, 2023 Author Posted September 22, 2023 2 hours ago, MarkE2794 said: your talking about the options likes years, genres, tags, actors, etc, right i have, i have the years, all shows which are seperated the "|" , and 2 genres. Can you space between "|" or is it all just one word then seperated by "|" Like " LengendofZelda| or Legend of Zelda|"? If the title has spaces you have to use them also in the input fields. What have you put into the genre condition? Side note: all videos need to have a runtime, so strm files are not really supported.
MarkE2794 1 Posted September 22, 2023 Posted September 22, 2023 (edited) this what i put for genre Anime&&Animation and do you use folder name or how it comes up in emby Edited September 22, 2023 by MarkE2794
