Oracle 86 Posted March 27, 2023 Posted March 27, 2023 Just now, pünktchen said: No, not really. There's always the chance of a bug that leads to an infinite loop, but with nearly 300 downloads it's a little bit unlikely. Yeah, super weird. I've been toying about with this for a little while. It's not like the channel has crazy criteria either. Just a specific library that looks for a specific tag. I don't know!
pünktchen 1411 Posted March 27, 2023 Author Posted March 27, 2023 On 3/22/2023 at 11:38 PM, JeremyG said: So I posted about Roku crashing a while back,, but then life got in the way of following up. Anyway I have a channel of videos all with encoding as shown in the screen shot. I'm only trying to use Playlist mode. On windows it works fine but Roku crashes immediately whether it's Live or Archive. No problem with same TV show viewed through Emby libraries. I'll get a Roku this week and can do some testing. Maybe i find something.
pünktchen 1411 Posted March 27, 2023 Author Posted March 27, 2023 5 minutes ago, Arly (Sprinkles) said: Yeah, super weird. I've been toying about with this for a little while. It's not like the channel has crazy criteria either. Just a specific library that looks for a specific tag. I don't know! Maybe pm me a debug log?
Oracle 86 Posted March 27, 2023 Posted March 27, 2023 Just now, pünktchen said: Maybe pm me a debug log? Sure thing. Let me pull one and I'll send it your way.
crusher11 1149 Posted April 4, 2023 Posted April 4, 2023 Is is possible to use one or more collections as a source for a channel?
Oracle 86 Posted April 4, 2023 Posted April 4, 2023 9 hours ago, crusher11 said: Is is possible to use one or more collections as a source for a channel? I don't believe so, no.
hstamas 179 Posted April 5, 2023 Posted April 5, 2023 @pünktchenI'm noticing lately that my channel icons when viewd in the guide are not listed correctly? Is this a VirtualTV thing or an Emby thing? VirtualTV config screen shows them correct. See attached. But when view in the guide they are mixed up after the first 2 channels. Again see attached. This carries over into Kodi as well when using the exported m3U/xmltv. Any ideas?
pünktchen 1411 Posted April 5, 2023 Author Posted April 5, 2023 Have you created new channels between existing ones or changed channel numbers?
hstamas 179 Posted April 5, 2023 Posted April 5, 2023 (edited) 48 minutes ago, pünktchen said: Have you created new channels between existing ones or changed channel numbers? Gosh I am not sure. My original install that Ive been using for years got corrupted so I started over. In setting things up there is a chance I set a channel number then changed it later on. I also so have 2 channels at number 815 and 816 that are not enabled if that could be causing issues? Any way to fix this short of starting over again? Edited April 5, 2023 by hstamas
crusher11 1149 Posted April 6, 2023 Posted April 6, 2023 @pünktchenany thought of adding collections as a source?
amateurgod 33 Posted April 15, 2023 Posted April 15, 2023 Is there any easy way to put in a studio that encompasses all studios with similiar names, so instead of doing something like Walt Disney Animation Studios | Pixar Animation Studios | Marvel Studios | Lucasfilm | Pixar | Disney+ | Disney XD | Disney Channel | Disney Television Animation | DisneyToon Studios | I could just do something like * disney * So it picks up all studios containing Disney?
amateurgod 33 Posted April 16, 2023 Posted April 16, 2023 Also it seems it doesn't recognise Anime as a Genre. However if I go Into my Anime library and look at Genres Anime is listed as a genre, however putting this into the genres section of virtual TV and refreshing guide data doesn't add any shows to that channel
Molboen 0 Posted April 16, 2023 Posted April 16, 2023 Hi. First of all, thank you for a wonderful plugin! My cable-provider canceled the 24/7 movie channels, so this is exactly what I need. It has been brought up before but not adressed. The plugin causes "too many streams" error on users with 1 stream limit. Best Regards
pünktchen 1411 Posted April 16, 2023 Author Posted April 16, 2023 On 4/15/2023 at 6:36 PM, amateurgod said: I could just do something like * disney * So it picks up all studios containing Disney Not yet, but it makes sense. At least for studios. 11 hours ago, amateurgod said: Also it seems it doesn't recognise Anime as a Genre. However if I go Into my Anime library and look at Genres Anime is listed as a genre, however putting this into the genres section of virtual TV and refreshing guide data doesn't add any shows to that channel The plugin itself doesn't know any genre. It just filters the available genres that are provided by quering the Emby library. There must be some other condition that prevents building your channel. 1
pünktchen 1411 Posted April 16, 2023 Author Posted April 16, 2023 1 hour ago, Molboen said: It has been brought up before but not adressed. The plugin causes "too many streams" error on users with 1 stream limit. Really? I don't know of any situation where the plugin is requesting multiple streams. I'll have to try it myself. If it doesn't work with stream limit 1 then it must be a bug in Emby.
pünktchen 1411 Posted April 16, 2023 Author Posted April 16, 2023 @Molboenonly did a quick test, but experienced no problems. Under what conditions does the issue arise?
Molboen 0 Posted April 16, 2023 Posted April 16, 2023 3 hours ago, pünktchen said: @Molboenonly did a quick test, but experienced no problems. Under what conditions does the issue arise? It seems to be exclusive to my Android boxes. I have a Chromecast with Google TV and 2x Nvidia Shield TV. All 3 with the same problem. Emby web on Chrome and Edge and the Windows app works without any issues.
Molboen 0 Posted April 17, 2023 Posted April 17, 2023 Here's the log when trying to play from Android: 2023-04-17 04:38:32.477 Info Server: http/1.1 POST http://192.168.0.8:8096/emby/Items/314597/PlaybackInfo?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 12; Chromecast Build/STTE.220920.016.H1) 2023-04-17 04:38:32.611 Info App: User policy for ****. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2023-04-17 04:38:32.700 Info Server: http/1.1 Response 200 to host2. Time: 223ms. http://192.168.0.8:8096/emby/Items/314597/PlaybackInfo?format=json 2023-04-17 04:38:32.841 Info Server: http/1.1 POST http://192.168.0.8:8096/emby/Sessions/Playing. UserAgent: Dalvik/2.1.0 (Linux; U; Android 12; Chromecast Build/STTE.220920.016.H1) 2023-04-17 04:38:32.880 Info SessionManager: Playback start reported by app AndroidTv 2.0.83g playing Pixar. Started at 0 ms 2023-04-17 04:38:32.885 Info Server: http/1.1 Response 204 to host2. Time: 44ms. http://192.168.0.8:8096/emby/Sessions/Playing 2023-04-17 04:38:32.912 Info VirtualTV: EventService > VirtualTV playback started for Channel: Pixar, Client: AndroidTv, Device: Stue Google TV 2023-04-17 04:38:32.912 Info VirtualTV: EventService > Add VirtualTV Channel User: VTV to SessionId: 499f70ae08db02d4889af0b8fb4e4d7a 2023-04-17 04:38:32.913 Info VirtualTV: EventService > Pushing playlist to SessionId: 499f70ae08db02d4889af0b8fb4e4d7a 2023-04-17 04:38:32.968 Info VirtualTV: StreamingService > PushRemotePlaylist: StartIndex: 0, StartOffset: 67 min, ItemIds: 46819|53446|53427|50484|45665|53426|39369|53442|44981|50486|53430|53996|41454|53435 2023-04-17 04:38:33.010 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/master.m3u8?DeviceId=21ff9c92c8acb241&MediaSourceId=VirtualTV1&PlaySessionId=e0339c74cc794f71965349e231ad85d3&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,aac,mp3&VideoBitrate=79997725&AudioBitrate=2275&MaxHeight=2160&AudioStreamIndex=1&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=gzip 2023-04-17 04:38:33.062 Info Server: http/1.1 Response 200 to host2. Time: 51ms. http://192.168.0.8:8096/emby/videos/314597/master.m3u8?DeviceId=21ff9c92c8acb241&MediaSourceId=VirtualTV1&PlaySessionId=e0339c74cc794f71965349e231ad85d3&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,aac,mp3&VideoBitrate=79997725&AudioBitrate=2275&MaxHeight=2160&AudioStreamIndex=1&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2023-04-17 04:38:33.077 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/main.m3u8?DeviceId=21ff9c92c8acb241&MediaSourceId=VirtualTV1&PlaySessionId=e0339c74cc794f71965349e231ad85d3&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,aac,mp3&VideoBitrate=79997725&AudioBitrate=2275&MaxHeight=2160&AudioStreamIndex=1&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=gzip 2023-04-17 04:38:33.084 Info Server: http/1.1 Response 200 to host2. Time: 7ms. http://192.168.0.8:8096/emby/videos/314597/main.m3u8?DeviceId=21ff9c92c8acb241&MediaSourceId=VirtualTV1&PlaySessionId=e0339c74cc794f71965349e231ad85d3&VideoCodec=h264,mpeg2video,hevc,h265&AudioCodec=aac_latm,mp4a_latm,aac,mp3&VideoBitrate=79997725&AudioBitrate=2275&MaxHeight=2160&AudioStreamIndex=1&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&AllowInterlacedVideoStreamCopy=True&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&hevc-profile=Main,Main10&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=DirectPlayError 2023-04-17 04:38:33.114 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/0.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.275 Info Server: http/1.1 POST http://192.168.0.8:8096/emby/Items/46819/PlaybackInfo?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 12; Chromecast Build/STTE.220920.016.H1) 2023-04-17 04:38:33.287 Info Server: http/1.1 Response 200 to host2. Time: 12ms. http://192.168.0.8:8096/emby/Items/46819/PlaybackInfo?format=json 2023-04-17 04:38:33.516 Info App: ProcessRun 'StreamTranscode 6893bb' Execute: /opt/emby-server/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/var/lib/emby/logs/ffmpeg-directstream-6893bb43-f7ae-4bcd-9b0f-830e0722a66d_1graph.txt" -copyts -start_at_zero -f mp4 -noaccurate_seek -c:v:0 h264 -i "/var/lib/emby/cache/virtualtv/VirtualTVIntro.mp4" -map 0:0 -map 0:1 -sn -c:v:0 copy -bsf:v:0 h264_mp4toannexb -c:a:0 copy -disposition:a:0 default -copypriorss:a:0 0 -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/home/jeppo/hdd2/transcode/transcoding-temp/E35A5A/E35A5A.m3u8" -segment_list_type m3u8 -segment_time 00:00:06.000 -segment_start_number 0 -break_non_keyframes 1 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/home/jeppo/hdd2/transcode/transcoding-temp/E35A5A/E35A5A_%d.ts" 2023-04-17 04:38:33.582 Info Server: http/1.1 Response 200 to host2. Time: 467ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/0.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:33.659 Info App: AppendExtraLogData - Read graph file: /var/lib/emby/logs/ffmpeg-directstream-6893bb43-f7ae-4bcd-9b0f-830e0722a66d_1graph.txt 2023-04-17 04:38:33.665 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 27.000 bytes Graph Count: 0 2023-04-17 04:38:33.665 Info App: AppendExtraLogData - File Deleted 2023-04-17 04:38:33.712 Info App: ProcessRun 'StreamTranscode 6893bb' Process exited with code 0 - Succeeded 2023-04-17 04:38:33.719 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/1.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.721 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/1.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:33.764 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/2.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.765 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/2.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:33.841 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/3.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.842 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/3.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:33.878 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/4.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.879 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/4.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:33.901 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/5.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.902 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/5.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:33.924 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/6.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.925 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/6.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:33.950 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/7.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.951 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/7.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:33.968 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/8.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.969 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/8.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:33.988 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/9.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:33.989 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/9.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:34.007 Info Server: http/1.1 GET http://192.168.0.8:8096/emby/videos/314597/hls1/main/10.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3. Connection=keep-alive, Host=192.168.0.8:8096, User-Agent=Emby/2.0.83g (Linux;Android 12) ExoPlayerLib/2.16.1, Accept-Encoding=identity 2023-04-17 04:38:34.008 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://192.168.0.8:8096/emby/videos/314597/hls1/main/10.ts?PlaySessionId=e0339c74cc794f71965349e231ad85d3 2023-04-17 04:38:34.855 Info Server: http/1.1 POST http://192.168.0.8:8096/emby/LiveStreams/MediaInfo. UserAgent: Dalvik/2.1.0 (Linux; U; Android 12; Chromecast Build/STTE.220920.016.H1) 2023-04-17 04:38:34.856 Info Server: http/1.1 POST http://192.168.0.8:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 12; Chromecast Build/STTE.220920.016.H1) 2023-04-17 04:38:34.862 Info Server: http/1.1 Response 204 to host2. Time: 6ms. http://192.168.0.8:8096/emby/Sessions/Playing/Progress 2023-04-17 04:38:34.867 Error Server: Error processing request *** Error Report *** Version: 4.7.11.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.18.0-0.deb11.4-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'id') at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStreamInfo(String id, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.GetLiveStreamMediaInfo(String id, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.Post(GetLiveStreamMediaInfo request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2023-04-17 04:38:34.867 Info Server: http/1.1 Response 400 to host2. Time: 12ms. http://192.168.0.8:8096/emby/LiveStreams/MediaInfo 2023-04-17 04:38:42.894 Info Server: http/1.1 POST http://192.168.0.8:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 12; Chromecast Build/STTE.220920.016.H1) 2023-04-17 04:38:42.896 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://192.168.0.8:8096/emby/Sessions/Playing/Progress 2023-04-17 04:38:44.876 Info Server: http/1.1 POST http://192.168.0.8:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 12; Chromecast Build/STTE.220920.016.H1) 2023-04-17 04:38:44.877 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://192.168.0.8:8096/emby/Sessions/Playing/Progress 2023-04-17 04:38:46.037 Info Server: http/1.1 POST http://192.168.0.8:8096/emby/Sessions/Playing/Stopped. UserAgent: Dalvik/2.1.0 (Linux; U; Android 12; Chromecast Build/STTE.220920.016.H1) 2023-04-17 04:38:46.051 Info SessionManager: Playback stopped reported by app AndroidTv 2.0.83g playing Pixar. Stopped at 4060887 ms 2023-04-17 04:38:46.052 Info Server: http/1.1 Response 204 to host2. Time: 15ms. http://192.168.0.8:8096/emby/Sessions/Playing/Stopped
crusher11 1149 Posted April 17, 2023 Posted April 17, 2023 8 hours ago, pünktchen said: Really? I don't know of any situation where the plugin is requesting multiple streams. I'll have to try it myself. If it doesn't work with stream limit 1 then it must be a bug in Emby. When one episode finishes and a new episode begins, Emby doesn't dump the first until after requesting the second, which draws an error. I solved it by simply bumping the allowed streams to 2.
amateurgod 33 Posted April 17, 2023 Posted April 17, 2023 So I used this with 3 Channels at first and everything worked fine, then I added another 10 channels and now I've noticed that when the scheduled task for refresh guide data runs it freezes at 15% and won't progress from there, it's been at 15% for the past 2 hours now and it's made everything else load really slow, I tried to manually stop the task but that didn't do anything it just sat on "stopping" and in the end I had to restart emby, does anyone know what could be causing this?
amateurgod 33 Posted April 17, 2023 Posted April 17, 2023 Addition to my last, using the restart button in the emby dashboard after the issues with the guide doesn't seem to restart the server like it use to, it just makes you not able to connect to the server and it doesn't become available again, I had to manually restart the docker container. These issues only started happening after I added another 10 channels to the virtualTV totaling 13 channels in total
Molboen 0 Posted April 17, 2023 Posted April 17, 2023 Another issue: The plugin does not honor "Include Library Folders" when multiple versions of a movie is merged into one library item. A movie from my 4K folder is playing, but only my HD folder is selected.
pünktchen 1411 Posted April 17, 2023 Author Posted April 17, 2023 19 hours ago, Molboen said: It seems to be exclusive to my Android boxes. I have a Chromecast with Google TV and 2x Nvidia Shield TV. All 3 with the same problem. It's more likely the Emby Android TV app is the culprit. Nothing i can do about it. Time to switch to the other Emby Android app.
pünktchen 1411 Posted April 17, 2023 Author Posted April 17, 2023 10 hours ago, Molboen said: Another issue: The plugin does not honor "Include Library Folders" when multiple versions of a movie is merged into one library item. A movie from my 4K folder is playing, but only my HD folder is selected. In case of multiversion movies the client app decides what item to play. Both versions share the same library item id and that is what the plugin is requesting the client to play.
Molboen 0 Posted April 17, 2023 Posted April 17, 2023 2 hours ago, pünktchen said: ..Time to switch to the other Emby Android app. Too bad. What is this other app, you are talking about?
