egadgetkids 1 Posted March 7, 2023 Posted March 7, 2023 Thanks all. Glad it's working for some. I would encourage those who can to test a fresh installation to see if you develop the same issues I did. In the meantime, I have decided to retire my own efforts for now.
hstamas 179 Posted March 9, 2023 Posted March 9, 2023 @pünktchenif you ever feel like it’s time to expand the feature set of VirtualTV here’s a suggestion! I like to keep an instance of Plex running just to mess around with things and use ErsatzTV as my VirtualTV alternative. One really cool feature is alternate schedules. Basically you can use it to schedule programming or subsets of programming based on alternate days/weeks/months. In my case I use it to play episodes of House Hunters only on weekends. Pretty cool.
AaronClarke 3 Posted March 9, 2023 Posted March 9, 2023 13 hours ago, hstamas said: @pünktchenif you ever feel like it’s time to expand the feature set of VirtualTV here’s a suggestion! I like to keep an instance of Plex running just to mess around with things and use ErsatzTV as my VirtualTV alternative. One really cool feature is alternate schedules. Basically you can use it to schedule programming or subsets of programming based on alternate days/weeks/months. In my case I use it to play episodes of House Hunters only on weekends. Pretty cool. Another Feature I would like to see it to be able to dictate what time a channel starts showing content... i.e.. I had a Horror channel but the wife wasn't happy that the kids could view it on the main TV during the day. Would be hand to be able to tell a channel only to show programs between certain times... e.g 9pm - 3am
crusher11 1149 Posted March 11, 2023 Posted March 11, 2023 Not sure if this relates to the issues @egadgetkidsis having, but I just tried to set up two new channels and the library folders wouldn't populate:
crusher11 1149 Posted March 13, 2023 Posted March 13, 2023 On 3/11/2023 at 12:23 PM, crusher11 said: Not sure if this relates to the issues @egadgetkidsis having, but I just tried to set up two new channels and the library folders wouldn't populate: @pünktchennot sure if you've seen this? Library folders populate just fine for my existing channels, but don't appear when setting up new channels (or editing those new channels once set up).
roaku 842 Posted March 13, 2023 Posted March 13, 2023 28 minutes ago, crusher11 said: @pünktchennot sure if you've seen this? Library folders populate just fine for my existing channels, but don't appear when setting up new channels (or editing those new channels once set up). Sounds like this:
pünktchen 1411 Posted March 13, 2023 Author Posted March 13, 2023 2 hours ago, crusher11 said: @pünktchennot sure if you've seen this? Library folders populate just fine for my existing channels, but don't appear when setting up new channels (or editing those new channels once set up). I've seen this, but i don't have an answer. Have you ever successfully created new channels after installation of the last plugin version?
Psychoticinsane 7 Posted March 13, 2023 Posted March 13, 2023 (edited) Cant delete so this stays i guess Edited March 13, 2023 by psycoticinsane
crusher11 1149 Posted March 14, 2023 Posted March 14, 2023 9 hours ago, pünktchen said: I've seen this, but i don't have an answer. Have you ever successfully created new channels after installation of the last plugin version? @roakuwas right, it was the folder permissions issue. I realised I was using a different user to create the new channels from the user set up with the existing channels.
pünktchen 1411 Posted March 14, 2023 Author Posted March 14, 2023 3 hours ago, crusher11 said: @roakuwas right, it was the folder permissions issue. I realised I was using a different user to create the new channels from the user set up with the existing channels. What plugin version, because i've thought i've fixed that already?
pünktchen 1411 Posted March 14, 2023 Author Posted March 14, 2023 1 minute ago, crusher11 said: 1.1.2.0 Ah okay, that explains it. That still has that bug.
crusher11 1149 Posted March 14, 2023 Posted March 14, 2023 24 minutes ago, pünktchen said: Ah okay, that explains it. That still has that bug. There are no updates pending.
pünktchen 1411 Posted March 14, 2023 Author Posted March 14, 2023 2 hours ago, crusher11 said: There are no updates pending. How should they? The plugin is not in the catalogue. New versions are always in the start post and i always create a separate post to notify users about updates. But you should know this already after such a long time.
Ninko 78 Posted March 14, 2023 Posted March 14, 2023 Quick question, what's the difference between Live and Archive in playback method? Thanks
GrimReaper 4911 Posted March 14, 2023 Posted March 14, 2023 3 minutes ago, Ninko said: Quick question, what's the difference between Live and Archive in playback method? It is explained in the very first post: On 12/27/2019 at 6:33 PM, pünktchen said: you can also choose between "live", which behaves like real live tv or "archive", which plays the videos from the start.
Ninko 78 Posted March 14, 2023 Posted March 14, 2023 47 minutes ago, GrimReaper said: It is explained in the very first post: Ah, sorry, missed that bit. Thanks
JeremyG 30 Posted March 22, 2023 Posted March 22, 2023 So I posted about Roku crashing a while back,, but then life got in the way of following up. Anyway I have a channel of videos all with encoding as shown in the screen shot. I'm only trying to use Playlist mode. On windows it works fine but Roku crashes immediately whether it's Live or Archive. No problem with same TV show viewed through Emby libraries. Shouldnt this be ok?
hstamas 179 Posted March 23, 2023 Posted March 23, 2023 Whelp, ive gone and something as all my setup is missing on the VirtualTV plugin page. Also the setup page isn't allowing me to save any new info I input so something got hosed. I still have program data and the plugin is still working but I assume that will end at some point. I'd like to uninstall and start over. Can anyone tell me where the config files etc live on a Mac so I can do a clean setup?
PuffyToesToo 348 Posted March 24, 2023 Posted March 24, 2023 17 hours ago, hstamas said: Also the setup page isn't allowing me to save any new info I input so something got hosed. I'm not sure about the rest of it, but when this has happened to me a couple times before, generating a new API key has fixed this part of it.
hstamas 179 Posted March 24, 2023 Posted March 24, 2023 Thanks for the suggestion @PuffyToesToo. Unfortunately all I get when I hit enter after adding a new API key is Emmy's busy spinner. 1
Oracle 86 Posted March 27, 2023 Posted March 27, 2023 Hi, all. After creating a channel with criteria, my refresh guide freezes at ~15%. Any ideas?
pünktchen 1411 Posted March 27, 2023 Author Posted March 27, 2023 On 3/24/2023 at 3:17 PM, hstamas said: Thanks for the suggestion @PuffyToesToo. Unfortunately all I get when I hit enter after adding a new API key is Emmy's busy spinner. Sounds more like a browser caching problem. Anyway, the VirtualTV.xml settings file should be in the configurations subfolder of your plugin directory.
hstamas 179 Posted March 27, 2023 Posted March 27, 2023 Just now, pünktchen said: Sounds more like a browser caching problem. Anyway, the VirtualTV.xml settings file should be in the configurations subfolder of your plugin directory. Yeah - that was the first thing I tried. Clearing browser cache and trying different browsers on different machines but same results. Thanks for the info. My setup is not all that complicated so starting from scratch wont be too painful!
pünktchen 1411 Posted March 27, 2023 Author Posted March 27, 2023 6 minutes ago, Arly (Sprinkles) said: Hi, all. After creating a channel with criteria, my refresh guide freezes at ~15%. Any ideas? No, not really. There's always the chance of a bug that leads to an infinite loop, but with nearly 300 downloads it's a little bit unlikely.
