LakersFan 2 Posted January 2, 2023 Posted January 2, 2023 2 hours ago, pünktchen said: What's the plugin version? It's the latest version:
LakersFan 2 Posted January 2, 2023 Posted January 2, 2023 Here is the error for the failed message in Scheduled Tasks when trying to export the channels: 2023-01-02 08:20:47.315 Error TaskManager: Error *** Error Report *** Version: 4.7.11.0 Command line: /usr/lib/emby-server/EmbyServer.dll -programdata /config -ffdetect /usr/bin/ffdetect-emby -ffmpeg /usr/bin/ffmpeg-emby -ffprobe /usr/bin/ffprobe-emby -restartexitcode 3 Operating system: Linux version 5.19.17-Unraid (root@Develop) (gcc (GCC) 12.2.0, GNU ld version 2.39-slack151) #2 SMP PREEMPT_DYNAMIC Wed Nov 2 11:54:15 PDT 2022 Framework: .NET 6.0.12 OS/Process: x64/x64 Runtime: usr/share/dotnet/shared/Microsoft.NETCore.App/6.0.12/System.Private.CoreLib.dll Processor count: 12 Data path: /config Application path: /usr/lib/emby-server System.Net.WebException: System.Net.WebException: The remote server returned an error: (400) Bad Request. at System.Net.HttpWebRequest.GetResponse() at System.Net.WebClient.GetWebResponse(WebRequest request) at System.Net.WebClient.DownloadBits(WebRequest request, Stream writeStream) at System.Net.WebClient.DownloadFile(Uri address, String fileName) at System.Net.WebClient.DownloadFile(String address, String fileName) at VirtualTV.Services.ExportVirtualTVTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: System.Net.Requests TargetSite: System.Net.WebResponse GetResponse()
GrimReaper 4911 Posted January 2, 2023 Posted January 2, 2023 8 minutes ago, LakersFan said: Curious as from where plugin is picking 172 subnet; do you have double (or multi) NAT in your network? Multiple DHCP servers? You can try binding your server explicitly to 192.168.1.197 in Settings>Network tab>Local IP field, rerun task and see how does that compare?
pünktchen 1411 Posted January 2, 2023 Author Posted January 2, 2023 11 minutes ago, Flippz said: Isnt it the IP of the docker container? Correct! The internal one.
pünktchen 1411 Posted January 2, 2023 Author Posted January 2, 2023 1 hour ago, LakersFan said: Here is the error for the failed message in Scheduled Tasks when trying to export the channels: What exactly have you setup as "host adress override"?
LakersFan 2 Posted January 2, 2023 Posted January 2, 2023 31 minutes ago, pünktchen said: What exactly have you setup as "host adress override"? http://192.168.1.197:8096/
pünktchen 1411 Posted January 2, 2023 Author Posted January 2, 2023 1 minute ago, LakersFan said: http://192.168.1.197:8096/ But the docker internal host adress is: http://172.18.0.6:8096
LakersFan 2 Posted January 2, 2023 Posted January 2, 2023 1 hour ago, Flippz said: Isnt it the IP of the docker container? I’m not sure what you guys mean?
pünktchen 1411 Posted January 2, 2023 Author Posted January 2, 2023 Sorry, i was faster in writing then in thinking about it You were nearly right. Just remove the trailing slash. so it must be http://192.168.1.197:8096
LakersFan 2 Posted January 2, 2023 Posted January 2, 2023 2 minutes ago, pünktchen said: But the docker internal host adress is: http://172.18.0.6:8096 I’m probably overthinking it. I initially left it blank. Should I put that IP in the host address override?
LakersFan 2 Posted January 2, 2023 Posted January 2, 2023 Still getting a failure when trying to export.
pünktchen 1411 Posted January 2, 2023 Author Posted January 2, 2023 Try this in a browser, but change "TheEmbyUserName" to your needs: http://192.168.1.197:8096/emby/VirtualTV/Channels?StreamType=universal&CatchupType=shift&CatchupContainer=mpegts&User=TheEmbyUserName&Device=Tivimate
LakersFan 2 Posted January 2, 2023 Posted January 2, 2023 Doing that downloaded the channels.m3u file to my PC.
pünktchen 1411 Posted January 3, 2023 Author Posted January 3, 2023 8 minutes ago, LakersFan said: Doing that downloaded the channels.m3u file to my PC. And that is was the export task is doing. Please post a screenshot of your export settings. But hide the password!!!
pünktchen 1411 Posted January 3, 2023 Author Posted January 3, 2023 @LakersFan I really don't know what the problem is with the export task on your side, but instead of the exported files you can use the direct urls in Tivimate. Just leave "Export Folder", "Hostadress Override" and "Token" empty in the export settings and use the following in Tivimate. Guide: http://192.168.1.197:8096/emby/virtualtv/guide?streamtype=universal Channels: http://192.168.1.197:8096/emby/virtualtv/channels?streamtype=universal&catchuptype=flussonic&user=Home&device=Tivimate If playback of catchup streams failes, just append "&catchupcontainer=mpegts" to the channels url without quotes. If your Emby user needs a password even in your LAN, just append "&pass=TheEmbyUserPassword" to the channels url without quotes.
Guest Posted January 5, 2023 Posted January 5, 2023 @pünktchen Should the VirtualTV plugin work well with other TV sources? I attempted to add a m3u IPTV source to show up in the guide and got some strange behavior. Not sure if it's Emby, the other source, or expected when using the plugin.
pünktchen 1411 Posted January 5, 2023 Author Posted January 5, 2023 41 minutes ago, andrewds said: Should the VirtualTV plugin work well with other TV sources? Yes. Since i've started the project i've always had other tv sources active and never experienced any problem.
LakersFan 2 Posted January 6, 2023 Posted January 6, 2023 On 1/3/2023 at 7:10 AM, pünktchen said: @LakersFan I really don't know what the problem is with the export task on your side, but instead of the exported files you can use the direct urls in Tivimate. Just leave "Export Folder", "Hostadress Override" and "Token" empty in the export settings and use the following in Tivimate. Guide: http://192.168.1.197:8096/emby/virtualtv/guide?streamtype=universal Channels: http://192.168.1.197:8096/emby/virtualtv/channels?streamtype=universal&catchuptype=flussonic&user=Home&device=Tivimate If playback of catchup streams failes, just append "&catchupcontainer=mpegts" to the channels url without quotes. If your Emby user needs a password even in your LAN, just append "&pass=TheEmbyUserPassword" to the channels url without quotes. Unfortunately that didn't work either. I added the channels as you stated, then appended with the catch up container, then even tried the pass. The guide is accurate. It's just not playing.
pünktchen 1411 Posted January 6, 2023 Author Posted January 6, 2023 2 hours ago, LakersFan said: Unfortunately that didn't work either. I added the channels as you stated, then appended with the catch up container, then even tried the pass. The guide is accurate. It's just not playing. Please pm me your Emby log file of that failed playback attempt.
feerlessleadr 173 Posted January 13, 2023 Posted January 13, 2023 Hi - thanks for making this plugin. I'm trying to set this up so that I can play my channels on kodi, but am running into 2 problems. I have everything setup on the emby server, and the channels show up and play without issue. I setup the IPTV simple PVR addon in kodi to pull the channels and guide data using he following links (which I found from another post from you in this thread): http://192.168.1.16:8096/emby/VirtualTV/Channels?User=Kevin&StreamType=EmbyNextGen http://192.168.1.16:8096/emby/VirtualTV/Guide In kodi, I can see the channels show up, and I can see the guide data, however when I click on a channel to watch it, nothing happens. Here is a kodi log file of me trying to play a show in kodi using this method: https://paste.ubuntu.com/p/FmQtxSsRMt/
pünktchen 1411 Posted January 13, 2023 Author Posted January 13, 2023 Your guide url is missing the stream type. It has to be: http://192.168.1.16:8096/emby/VirtualTV/Guide?StreamType=EmbyNextGen
feerlessleadr 173 Posted January 13, 2023 Posted January 13, 2023 4 minutes ago, pünktchen said: Your guide url is missing the stream type. It has to be: http://192.168.1.16:8096/emby/VirtualTV/Guide?StreamType=EmbyNextGen Thanks, although nothing plays, even after I make that change in kodi. https://paste.ubuntu.com/p/ZQHKTXmtX8/ I also just tried following the steps in this post, and while that let's me play when clicking on anything to play, 9 times out of 10 it pops up that Playback Failed (1 out of 10 times the channel will play). See log of that here (3 errors and 1 successful playback): https://paste.ubuntu.com/p/Z8g4WFy5nY/
pünktchen 1411 Posted January 14, 2023 Author Posted January 14, 2023 @feerlessleadr I've asked the Kodi addon developer for some help. Maybe i need to adjust my plugin again to some changes in the Kodi addon or the Kodi addon is just broken. 1
Eigeplackter 92 Posted January 14, 2023 Posted January 14, 2023 Maybe a stupid question, but where can I find my created VirtualTV Channels ?
