Jbrock25 0 Posted November 21, 2022 Posted November 21, 2022 4 minutes ago, pünktchen said: If you don't have set any other condition, then this is the correct behaviour. In other words: without any condition - no guide data. Now I feel like a idiot, with that statement I realized that all I had to do was add a * to that field and it would recognize all the media in the selected folder.
jblaze12 8 Posted November 21, 2022 Posted November 21, 2022 34 minutes ago, Jbrock25 said: Now I feel like a idiot, with that statement I realized that all I had to do was add a * to that field and it would recognize all the media in the selected folder. Asked question, got simple answer, feel dumb but got a solution? Welcome to the club! This plugin is so great, I don't mind feeling dumb sometimes!
Admin5859 0 Posted November 21, 2022 Posted November 21, 2022 I'm still not loading the guide on Firestick, but it does load using the Emby web app. Does anyone else have this problem? I've noticed that Pluto TV will populate the live tv guide, but Samsung TV Plus does not, which is what I'd prefer to use, nor does VirtualTV. With both Samsung TV Plus and VirtualTV, the "On Now" section does display the currently running shows, but the actual guide is blank. Possibly this is all related to using the Firestick as the web app and my PC do correctly fill in the TV guide for everything.
pünktchen 1411 Posted November 21, 2022 Author Posted November 21, 2022 15 minutes ago, Admin5859 said: I'm still not loading the guide on Firestick Are you talking about the live tv guide inside the Emby app for Amazon devices or about the live tv guide of the Fire TV OS? If the latter, then that is not plugin related. The Emby app would have to support it to make it's own tv guide visible to the Fire TV OS. @ebr
EdBarnes 3 Posted November 25, 2022 Posted November 25, 2022 Can Virtual TV add references to Playlists, Collections, and/or allow selection by Genre, when selecting sources for tv shows? Also, bumpers selection should support the same references as well.
pünktchen 1411 Posted November 25, 2022 Author Posted November 25, 2022 @EdBarnes Quote It looks like I have to create a library with my holiday tv shows in it. (instead of just having all my TV shows together) Why do think that is necessary? Quote Also my Music Video's would have to be moved to my pictures directory ( That is what Virtual TV says) Where does it say that and what do you want to do with your music videos? Quote Can Virtual TV add references to Playlists, Collections ...? Some day maybe. Quote ... allow selection by Genre, when selecting sources for tv shows? A genre filter is already there! Quote Also, bumpers selection should support the same references as well. If you mean bumpers should have the same conditions like movies or tv shows, no that will not happen!
EdBarnes 3 Posted November 26, 2022 Posted November 26, 2022 Bumpers selection has that as a remark during selection 1
PaulE123 20 Posted December 5, 2022 Posted December 5, 2022 So I have this working perfectly for one channel, for a specific tv show. I wanted to add a second channel for the different tv show, so went ahead and copied all of the settings from channel 1, to channel 2 (changing the nexessary bits like the tag for what show to use etc)....and it works, sort of. The channel shows up alongside the existing working one, but there's no metadata, no tv show info, no artwork, no episode name, nothing....if I hit the play button, it'll play a random episode from the correct show, but I just can't get it to scrape and display metadata. I've refreshed the guide etc, restarted the emby docker too....nothing....
pünktchen 1411 Posted December 5, 2022 Author Posted December 5, 2022 Dumb question @PaulE123: the tv show in question has all the metadata in your library? If so, what client has the problem?
PaulE123 20 Posted December 6, 2022 Posted December 6, 2022 16 hours ago, pünktchen said: Dumb question @PaulE123: the tv show in question has all the metadata in your library? If so, what client has the problem? Yep, it's a TV show that's perfectly scraped in my TV library. I see the issue on both windows chrome and my nvidia shield
paiello209 0 Posted December 6, 2022 Posted December 6, 2022 (edited) Hey everyone. I am certain I am asking an old question but I can't find the answer anywhere and I have exhausted all of my other options, so here goes. I have been happily using the VirtualTV plugin for the last 2 years until this week. I have my Emby install on a Synology NAS and have had no problems with it. 2 days ago, I finally upgraded to the newest version of Emby 4.7.10 after being on one of the 4.6 builds for a while. Once I restarted VirtualTV did not work. I figured out that I had to update the VirtualTV dll to the new 1.1.3 version which works with Emby 4.7. I SSH'd into my server and went to the Emby plugin folder but now the folders permission is 0755 and I cannot change it to 0777 in order replace the old VirtualTV dll with the new one, because I do not have write permissions to do it. I cannot even change the write permissions. Am I doing something wrong? If so, does anyone know how I can change the permissions in order to allow me to replace the dll file and continue to enjoy VirtualTV? Any help would be greatly appreciated. Edited December 6, 2022 by paiello209
pünktchen 1411 Posted December 6, 2022 Author Posted December 6, 2022 @PaulE123 If you either enable debug logging in the plugin or for the whole Emby server and then do a guide refresh, the log file should list the series and episode names for every program that the plugin is generating. That is metadata from your library, not filenames. So please tell me if that is available in the log file. 1
paiello209 0 Posted December 7, 2022 Posted December 7, 2022 Forget my earlier post, I figured it out!
PaulE123 20 Posted December 8, 2022 Posted December 8, 2022 On 12/6/2022 at 11:32 PM, pünktchen said: @PaulE123 If you either enable debug logging in the plugin or for the whole Emby server and then do a guide refresh, the log file should list the series and episode names for every program that the plugin is generating. That is metadata from your library, not filenames. So please tell me if that is available in the log file. Ok I've followed those steps, I think I see the data you mention in the logs... 2022-12-08 10:23:28.165 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 10:23:28.759 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 10:23:28.769 Info SqliteItemRepository: Removing 19 old programs from channel 244025 The Inbetweeners ... 2022-12-08 11:05:27.971 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:05:28.485 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:05:28.490 Info SqliteItemRepository: Removing 17 old programs from channel 244025 The Inbetweeners 2022-12-08 11:06:53.897 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:06:53.897 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:08:34.988 Info Server: http/1.1 POST http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:08:35.008 Info Server: http/1.1 Response 204 to host2. Time: 20ms. http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:08:44.341 Info Server: http/1.1 POST http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:08:44.342 Info Server: http/1.1 Response 204 to host2. Time: 0ms. http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:08:44.346 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:08:44.347 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:08:44.881 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:08:44.927 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:08:45.072 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:08:45.591 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:08:45.595 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:09:23.302 Info Server: http/1.1 POST http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:09:23.315 Info Server: http/1.1 Response 200 to host2. Time: 13ms. http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:09:23.320 Info Server: http/1.1 POST http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:09:23.321 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:09:23.322 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:09:23.819 Info Server: http/1.1 Response 204 to host2. Time: 499ms. http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:09:23.892 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:09:23.939 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:09:24.034 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:09:24.553 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:09:24.558 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:09:27.714 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:09:27.714 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:09:37.660 Info Server: http/1.1 POST http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:09:37.661 Info Server: http/1.1 Response 204 to host2. Time: 0ms. http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:09:37.665 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:09:37.665 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:09:38.195 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:09:38.241 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:09:38.396 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:09:38.912 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:09:38.916 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:10:10.966 Info Server: http/1.1 POST http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:10:10.968 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:10:10.972 Info Server: http/1.1 POST http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:10:10.974 Info Server: http/1.1 Response 204 to host2. Time: 3ms. http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:10:10.975 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:10:10.975 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:10:11.509 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:10:11.554 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:10:11.646 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:10:12.159 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:10:12.165 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:10:55.037 Info Server: http/1.1 POST http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:10:55.038 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:10:55.042 Info Server: http/1.1 POST http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:10:55.043 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:10:55.043 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:10:55.045 Info Server: http/1.1 Response 204 to host2. Time: 3ms. http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:10:55.608 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:10:55.653 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:10:55.800 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:10:56.307 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:10:56.311 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:11:13.907 Info Server: http/1.1 POST http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:11:13.911 Info Server: http/1.1 Response 204 to host2. Time: 4ms. http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json ... 022-12-08 11:11:21.949 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.1), ProviderIds: [vtvp, 96492], Start: 12/8/2022 12:00:00 AM +00:00, End: 12/8/2022 12:21:54 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.4), ProviderIds: [vtvp, 96501], Start: 12/8/2022 12:21:54 AM +00:00, End: 12/8/2022 12:45:56 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.6), ProviderIds: [vtvp, 96497], Start: 12/8/2022 12:45:56 AM +00:00, End: 12/8/2022 1:09:39 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.6), ProviderIds: [vtvp, 96503], Start: 12/8/2022 1:09:39 AM +00:00, End: 12/8/2022 1:35:07 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.5), ProviderIds: [vtvp, 96496], Start: 12/8/2022 1:35:07 AM +00:00, End: 12/8/2022 1:57:45 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.3), ProviderIds: [vtvp, 96500], Start: 12/8/2022 1:57:45 AM +00:00, End: 12/8/2022 2:22:34 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.1), ProviderIds: [vtvp, 96504], Start: 12/8/2022 2:22:34 AM +00:00, End: 12/8/2022 2:47:46 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.2), ProviderIds: [vtvp, 96499], Start: 12/8/2022 2:47:46 AM +00:00, End: 12/8/2022 3:12:40 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (0.38), ProviderIds: [vtvp, 96510], Start: 12/8/2022 3:12:40 AM +00:00, End: 12/8/2022 4:45:22 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.5), ProviderIds: [vtvp, 96502], Start: 12/8/2022 4:45:22 AM +00:00, End: 12/8/2022 5:09:54 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.4), ProviderIds: [vtvp, 96495], Start: 12/8/2022 5:09:54 AM +00:00, End: 12/8/2022 5:33:40 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.3), ProviderIds: [vtvp, 96506], Start: 12/8/2022 5:33:40 AM +00:00, End: 12/8/2022 5:58:00 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.4), ProviderIds: [vtvp, 96507], Start: 12/8/2022 5:58:00 AM +00:00, End: 12/8/2022 6:22:35 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.6), ProviderIds: [vtvp, 96509], Start: 12/8/2022 6:22:35 AM +00:00, End: 12/8/2022 6:49:03 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.2), ProviderIds: [vtvp, 96505], Start: 12/8/2022 6:49:03 AM +00:00, End: 12/8/2022 7:14:10 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.1), ProviderIds: [vtvp, 96498], Start: 12/8/2022 7:14:10 AM +00:00, End: 12/8/2022 7:39:15 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.2), ProviderIds: [vtvp, 96493], Start: 12/8/2022 7:39:15 AM +00:00, End: 12/8/2022 8:03:19 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.3), ProviderIds: [vtvp, 96494], Start: 12/8/2022 8:03:19 AM +00:00, End: 12/8/2022 8:25:49 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.5), ProviderIds: [vtvp, 96508], Start: 12/8/2022 8:25:49 AM +00:00, End: 12/8/2022 8:50:20 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:11:22.464 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:11:22.506 Info VirtualTV: EventService > Cleared all cached library items ... 2022-12-08 11:12:26.984 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:12:27.494 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.3), ProviderIds: [vtvp, 96500], Start: 12/8/2022 12:00:00 AM +00:00, End: 12/8/2022 12:24:49 AM +00:00 2022-12-08 11:12:27.494 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.1), ProviderIds: [vtvp, 96498], Start: 12/8/2022 12:24:49 AM +00:00, End: 12/8/2022 12:49:54 AM +00:00 2022-12-08 11:12:27.494 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.5), ProviderIds: [vtvp, 96508], Start: 12/8/2022 12:49:54 AM +00:00, End: 12/8/2022 1:14:25 AM +00:00 2022-12-08 11:12:27.494 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.5), ProviderIds: [vtvp, 96496], Start: 12/8/2022 1:14:25 AM +00:00, End: 12/8/2022 1:37:03 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (0.38), ProviderIds: [vtvp, 96510], Start: 12/8/2022 1:37:03 AM +00:00, End: 12/8/2022 3:09:45 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.2), ProviderIds: [vtvp, 96505], Start: 12/8/2022 3:09:45 AM +00:00, End: 12/8/2022 3:34:52 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.4), ProviderIds: [vtvp, 96501], Start: 12/8/2022 3:34:52 AM +00:00, End: 12/8/2022 3:58:54 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.1), ProviderIds: [vtvp, 96504], Start: 12/8/2022 3:58:54 AM +00:00, End: 12/8/2022 4:24:06 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.3), ProviderIds: [vtvp, 96506], Start: 12/8/2022 4:24:06 AM +00:00, End: 12/8/2022 4:48:26 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.2), ProviderIds: [vtvp, 96493], Start: 12/8/2022 4:48:26 AM +00:00, End: 12/8/2022 5:12:30 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.4), ProviderIds: [vtvp, 96495], Start: 12/8/2022 5:12:30 AM +00:00, End: 12/8/2022 5:36:16 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.6), ProviderIds: [vtvp, 96509], Start: 12/8/2022 5:36:16 AM +00:00, End: 12/8/2022 6:02:44 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.5), ProviderIds: [vtvp, 96502], Start: 12/8/2022 6:02:44 AM +00:00, End: 12/8/2022 6:27:16 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.3), ProviderIds: [vtvp, 96494], Start: 12/8/2022 6:27:16 AM +00:00, End: 12/8/2022 6:49:46 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.2), ProviderIds: [vtvp, 96499], Start: 12/8/2022 6:49:46 AM +00:00, End: 12/8/2022 7:14:40 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.6), ProviderIds: [vtvp, 96497], Start: 12/8/2022 7:14:40 AM +00:00, End: 12/8/2022 7:38:23 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.1), ProviderIds: [vtvp, 96492], Start: 12/8/2022 7:38:23 AM +00:00, End: 12/8/2022 8:00:17 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.6), ProviderIds: [vtvp, 96503], Start: 12/8/2022 8:00:17 AM +00:00, End: 12/8/2022 8:25:45 AM +00:00 2022-12-08 11:12:27.497 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.4), ProviderIds: [vtvp, 96507], Start: 12/8/2022 8:25:45 AM +00:00, End: 12/8/2022 8:50:20 AM +00:00 2022-12-08 11:12:27.497 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:12:27.500 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners ... 2022-12-08 11:15:52.636 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:15:53.147 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.1), ProviderIds: [vtvp, 96498], Start: 12/8/2022 12:00:00 AM +00:00, End: 12/8/2022 12:25:05 AM +00:00 2022-12-08 11:15:53.147 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.2), ProviderIds: [vtvp, 96499], Start: 12/8/2022 12:25:05 AM +00:00, End: 12/8/2022 12:49:59 AM +00:00 2022-12-08 11:15:53.147 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.2), ProviderIds: [vtvp, 96493], Start: 12/8/2022 12:49:59 AM +00:00, End: 12/8/2022 1:14:03 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.5), ProviderIds: [vtvp, 96502], Start: 12/8/2022 1:14:03 AM +00:00, End: 12/8/2022 1:38:35 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.4), ProviderIds: [vtvp, 96501], Start: 12/8/2022 1:38:35 AM +00:00, End: 12/8/2022 2:02:38 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.3), ProviderIds: [vtvp, 96494], Start: 12/8/2022 2:02:38 AM +00:00, End: 12/8/2022 2:25:07 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.2), ProviderIds: [vtvp, 96505], Start: 12/8/2022 2:25:07 AM +00:00, End: 12/8/2022 2:50:14 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.4), ProviderIds: [vtvp, 96507], Start: 12/8/2022 2:50:14 AM +00:00, End: 12/8/2022 3:14:49 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.5), ProviderIds: [vtvp, 96508], Start: 12/8/2022 3:14:49 AM +00:00, End: 12/8/2022 3:39:20 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.3), ProviderIds: [vtvp, 96506], Start: 12/8/2022 3:39:20 AM +00:00, End: 12/8/2022 4:03:40 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.5), ProviderIds: [vtvp, 96496], Start: 12/8/2022 4:03:40 AM +00:00, End: 12/8/2022 4:26:18 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.3), ProviderIds: [vtvp, 96500], Start: 12/8/2022 4:26:18 AM +00:00, End: 12/8/2022 4:51:07 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.4), ProviderIds: [vtvp, 96495], Start: 12/8/2022 4:51:07 AM +00:00, End: 12/8/2022 5:14:53 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.6), ProviderIds: [vtvp, 96503], Start: 12/8/2022 5:14:53 AM +00:00, End: 12/8/2022 5:40:21 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (0.38), ProviderIds: [vtvp, 96510], Start: 12/8/2022 5:40:21 AM +00:00, End: 12/8/2022 7:13:03 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.1), ProviderIds: [vtvp, 96492], Start: 12/8/2022 7:13:03 AM +00:00, End: 12/8/2022 7:34:57 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.6), ProviderIds: [vtvp, 96497], Start: 12/8/2022 7:34:57 AM +00:00, End: 12/8/2022 7:58:40 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.1), ProviderIds: [vtvp, 96504], Start: 12/8/2022 7:58:40 AM +00:00, End: 12/8/2022 8:23:52 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.6), ProviderIds: [vtvp, 96509], Start: 12/8/2022 8:23:52 AM +00:00, End: 12/8/2022 8:50:20 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:15:53.153 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:15:53.193 Info VirtualTV: EventService > Cleared all cached library items ... 2022-12-08 11:26:15.629 Info App: ProcessRun 'StreamTranscode 9f8636' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-9f863663-1b00-4a81-9ceb-b55d78238fd2_1graph.txt" -copyts -start_at_zero -init_hw_device "qsv=vad:hw_any,child_device=/dev/dri/renderD128" -filter_hw_device vad -f matroska,webm -c:v:0 mpeg2_qsv -hwaccel:v:0 qsv -i "/TV (Misc.)/The Inbetweeners/Season 1/The Inbetweeners - 1x01 - First Day.mkv" -map 0:0 -map 0:1 -sn -c:v:0 h264_qsv -b:v:0 5213002 -g:v:0 75 -maxrate:v:0 5213002 -bufsize:v:0 10426004 -level:v:0 30 -keyint_min:v:0 75 -r:v:0 25 -profile:v:0 high -aud:v:0 1 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/Transcoding/transcoding-temp/14029C/14029C.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/Transcoding/transcoding-temp/14029C/14029C_%d.ts" 2022-12-08 11:26:15.834 Info Server: http/1.1 Response 200 to host2. Time: 222ms. http://host1:8096/emby/videos/96492/hls1/main/0.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:15.881 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/1.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:15.907 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:26:15.908 Info SessionManager: Playback start reported by app Emby Web 4.7.10.0 playing First Day. Started at 0 ms 2022-12-08 11:26:15.909 Info Server: http/1.1 Response 204 to host2. Time: 2ms. http://host1:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:26:15.984 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/1.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.048 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/2.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.050 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/2.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.092 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/3.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.126 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:26:16.127 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://host1:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:26:16.194 Info Server: http/1.1 Response 200 to host2. Time: 102ms. http://host1:8096/emby/videos/96492/hls1/main/3.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.228 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/4.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.330 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/4.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.377 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/5.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.380 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/5.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.416 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/6.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.519 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/6.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.545 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/7.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.648 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/7.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.687 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/8.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.690 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/8.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.739 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/9.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.841 Info Server: http/1.1 Response 200 to host2. Time: 102ms. http://host1:8096/emby/videos/96492/hls1/main/9.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.873 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/10.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.875 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/10.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.915 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/11.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:17.018 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/11.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:17.050 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/12.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:17.152 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/12.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:17.190 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/13.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:17.192 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/13.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:17.228 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/14.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:17.331 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/14.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:17.383 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:26:17.384 Info App: ProcessRun 'StreamTranscode 9f8636': Stopping ffmpeg process with q command for /Transcoding/transcoding-temp/14029C/14029C_0.ts 2022-12-08 11:26:17.408 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-transcode-9f863663-1b00-4a81-9ceb-b55d78238fd2_1graph.txt 2022-12-08 11:26:17.409 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 15,724.000 bytes Graph Count: 2 2022-12-08 11:26:17.409 Info App: AppendExtraLogData - File Deleted 2022-12-08 11:26:17.410 Info App: ProcessRun 'StreamTranscode 9f8636' Process exited with code 0 - Succeeded 2022-12-08 11:26:17.410 Info SessionManager: Playback stopped reported by app Emby Web 4.7.10.0 playing First Day. Stopped at 1223 ms 2022-12-08 11:26:17.410 Info Server: http/1.1 Response 204 to host2. Time: 27ms. http://host1:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:26:17.912 Info VirtualTV: EventService > SetPlaystatePlaylist: Save playback progress for SessionId: 43de01cf710b392340fed2fd6a64e7bc, User: Paul, Item: The Inbetweeners - S1E1 First Day, PlaybackPositionTicks: 0(12238540), Watched: False 2022-12-08 11:27:00.032 Info Server: http/1.1 POST http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:27:00.034 Info Server: http/1.1 Response 204 to host2. Time: 3ms. http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:27:10.382 Info Server: http/1.1 POST http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:27:10.385 Info Server: http/1.1 Response 204 to host2. Time: 2ms. http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:27:12.531 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:27:12.531 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:27:19.377 Info Server: http/1.1 POST http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:27:19.377 Info Server: http/1.1 Response 204 to host2. Time: 0ms. http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:27:19.385 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:27:19.386 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:27:19.910 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:27:19.952 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:27:20.047 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:27:20.584 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:27:20.587 Info SqliteItemRepository: Removing 18 old programs from channel 264595 The Inbetweeners 2022-12-08 11:28:03.040 Info Server: http/1.1 POST http://host1:8096/emby/Users/38bdd6dc0c844bf1bc75c9a3b7592cd6?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:28:03.064 Info Server: http/1.1 Response 204 to host2. Time: 24ms. http://host1:8096/emby/Users/38bdd6dc0c844bf1bc75c9a3b7592cd6?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:28:03.069 Info Server: http/1.1 POST http://host1:8096/emby/Users/38bdd6dc0c844bf1bc75c9a3b7592cd6/Policy?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:28:03.084 Info Server: http/1.1 Response 204 to host2. Time: 15ms. http://host1:8096/emby/Users/38bdd6dc0c844bf1bc75c9a3b7592cd6/Policy?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:28:08.832 Info Server: http/1.1 POST http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:28:08.833 Info Server: http/1.1 Response 204 to host2. Time: 0ms. http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4- ^^ Not sure how much of that is relevant, but there's more mentioned in the log that refers to the show name etc. I've since added x2 more channels, bringing me up to a total of x4 channels. Two of them are working, x2 of them aren't, the logs above refer to one that isn't. All created the same way etc.
PaulE123 20 Posted December 9, 2022 Posted December 9, 2022 21 hours ago, PaulE123 said: Ok I've followed those steps, I think I see the data you mention in the logs... 2022-12-08 10:23:28.165 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 10:23:28.759 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 10:23:28.769 Info SqliteItemRepository: Removing 19 old programs from channel 244025 The Inbetweeners ... 2022-12-08 11:05:27.971 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:05:28.485 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:05:28.490 Info SqliteItemRepository: Removing 17 old programs from channel 244025 The Inbetweeners 2022-12-08 11:06:53.897 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:06:53.897 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:08:34.988 Info Server: http/1.1 POST http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:08:35.008 Info Server: http/1.1 Response 204 to host2. Time: 20ms. http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:08:44.341 Info Server: http/1.1 POST http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:08:44.342 Info Server: http/1.1 Response 204 to host2. Time: 0ms. http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:08:44.346 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:08:44.347 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:08:44.881 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:08:44.927 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:08:45.072 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:08:45.591 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:08:45.595 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:09:23.302 Info Server: http/1.1 POST http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:09:23.315 Info Server: http/1.1 Response 200 to host2. Time: 13ms. http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:09:23.320 Info Server: http/1.1 POST http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:09:23.321 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:09:23.322 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:09:23.819 Info Server: http/1.1 Response 204 to host2. Time: 499ms. http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:09:23.892 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:09:23.939 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:09:24.034 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:09:24.553 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:09:24.558 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:09:27.714 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:09:27.714 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:09:37.660 Info Server: http/1.1 POST http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:09:37.661 Info Server: http/1.1 Response 204 to host2. Time: 0ms. http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:09:37.665 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:09:37.665 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:09:38.195 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:09:38.241 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:09:38.396 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:09:38.912 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:09:38.916 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:10:10.966 Info Server: http/1.1 POST http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:10:10.968 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:10:10.972 Info Server: http/1.1 POST http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:10:10.974 Info Server: http/1.1 Response 204 to host2. Time: 3ms. http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:10:10.975 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:10:10.975 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:10:11.509 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:10:11.554 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:10:11.646 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:10:12.159 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:10:12.165 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:10:55.037 Info Server: http/1.1 POST http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:10:55.038 Info Server: http/1.1 Response 200 to host2. Time: 1ms. http://host1:8096/emby/LiveTv/ChannelMappings?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:10:55.042 Info Server: http/1.1 POST http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:10:55.043 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:10:55.043 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:10:55.045 Info Server: http/1.1 Response 204 to host2. Time: 3ms. http://host1:8096/emby/Items/244025?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:10:55.608 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:10:55.653 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:10:55.800 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:10:56.307 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:10:56.311 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:11:13.907 Info Server: http/1.1 POST http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:11:13.911 Info Server: http/1.1 Response 204 to host2. Time: 4ms. http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json ... 022-12-08 11:11:21.949 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.1), ProviderIds: [vtvp, 96492], Start: 12/8/2022 12:00:00 AM +00:00, End: 12/8/2022 12:21:54 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.4), ProviderIds: [vtvp, 96501], Start: 12/8/2022 12:21:54 AM +00:00, End: 12/8/2022 12:45:56 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.6), ProviderIds: [vtvp, 96497], Start: 12/8/2022 12:45:56 AM +00:00, End: 12/8/2022 1:09:39 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.6), ProviderIds: [vtvp, 96503], Start: 12/8/2022 1:09:39 AM +00:00, End: 12/8/2022 1:35:07 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.5), ProviderIds: [vtvp, 96496], Start: 12/8/2022 1:35:07 AM +00:00, End: 12/8/2022 1:57:45 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.3), ProviderIds: [vtvp, 96500], Start: 12/8/2022 1:57:45 AM +00:00, End: 12/8/2022 2:22:34 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.1), ProviderIds: [vtvp, 96504], Start: 12/8/2022 2:22:34 AM +00:00, End: 12/8/2022 2:47:46 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.2), ProviderIds: [vtvp, 96499], Start: 12/8/2022 2:47:46 AM +00:00, End: 12/8/2022 3:12:40 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (0.38), ProviderIds: [vtvp, 96510], Start: 12/8/2022 3:12:40 AM +00:00, End: 12/8/2022 4:45:22 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.5), ProviderIds: [vtvp, 96502], Start: 12/8/2022 4:45:22 AM +00:00, End: 12/8/2022 5:09:54 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.4), ProviderIds: [vtvp, 96495], Start: 12/8/2022 5:09:54 AM +00:00, End: 12/8/2022 5:33:40 AM +00:00 2022-12-08 11:11:22.459 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.3), ProviderIds: [vtvp, 96506], Start: 12/8/2022 5:33:40 AM +00:00, End: 12/8/2022 5:58:00 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.4), ProviderIds: [vtvp, 96507], Start: 12/8/2022 5:58:00 AM +00:00, End: 12/8/2022 6:22:35 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.6), ProviderIds: [vtvp, 96509], Start: 12/8/2022 6:22:35 AM +00:00, End: 12/8/2022 6:49:03 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.2), ProviderIds: [vtvp, 96505], Start: 12/8/2022 6:49:03 AM +00:00, End: 12/8/2022 7:14:10 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.1), ProviderIds: [vtvp, 96498], Start: 12/8/2022 7:14:10 AM +00:00, End: 12/8/2022 7:39:15 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.2), ProviderIds: [vtvp, 96493], Start: 12/8/2022 7:39:15 AM +00:00, End: 12/8/2022 8:03:19 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.3), ProviderIds: [vtvp, 96494], Start: 12/8/2022 8:03:19 AM +00:00, End: 12/8/2022 8:25:49 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.5), ProviderIds: [vtvp, 96508], Start: 12/8/2022 8:25:49 AM +00:00, End: 12/8/2022 8:50:20 AM +00:00 2022-12-08 11:11:22.460 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:11:22.464 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:11:22.506 Info VirtualTV: EventService > Cleared all cached library items ... 2022-12-08 11:12:26.984 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:12:27.494 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.3), ProviderIds: [vtvp, 96500], Start: 12/8/2022 12:00:00 AM +00:00, End: 12/8/2022 12:24:49 AM +00:00 2022-12-08 11:12:27.494 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.1), ProviderIds: [vtvp, 96498], Start: 12/8/2022 12:24:49 AM +00:00, End: 12/8/2022 12:49:54 AM +00:00 2022-12-08 11:12:27.494 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.5), ProviderIds: [vtvp, 96508], Start: 12/8/2022 12:49:54 AM +00:00, End: 12/8/2022 1:14:25 AM +00:00 2022-12-08 11:12:27.494 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.5), ProviderIds: [vtvp, 96496], Start: 12/8/2022 1:14:25 AM +00:00, End: 12/8/2022 1:37:03 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (0.38), ProviderIds: [vtvp, 96510], Start: 12/8/2022 1:37:03 AM +00:00, End: 12/8/2022 3:09:45 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.2), ProviderIds: [vtvp, 96505], Start: 12/8/2022 3:09:45 AM +00:00, End: 12/8/2022 3:34:52 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.4), ProviderIds: [vtvp, 96501], Start: 12/8/2022 3:34:52 AM +00:00, End: 12/8/2022 3:58:54 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.1), ProviderIds: [vtvp, 96504], Start: 12/8/2022 3:58:54 AM +00:00, End: 12/8/2022 4:24:06 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.3), ProviderIds: [vtvp, 96506], Start: 12/8/2022 4:24:06 AM +00:00, End: 12/8/2022 4:48:26 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.2), ProviderIds: [vtvp, 96493], Start: 12/8/2022 4:48:26 AM +00:00, End: 12/8/2022 5:12:30 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.4), ProviderIds: [vtvp, 96495], Start: 12/8/2022 5:12:30 AM +00:00, End: 12/8/2022 5:36:16 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.6), ProviderIds: [vtvp, 96509], Start: 12/8/2022 5:36:16 AM +00:00, End: 12/8/2022 6:02:44 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.5), ProviderIds: [vtvp, 96502], Start: 12/8/2022 6:02:44 AM +00:00, End: 12/8/2022 6:27:16 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.3), ProviderIds: [vtvp, 96494], Start: 12/8/2022 6:27:16 AM +00:00, End: 12/8/2022 6:49:46 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.2), ProviderIds: [vtvp, 96499], Start: 12/8/2022 6:49:46 AM +00:00, End: 12/8/2022 7:14:40 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.6), ProviderIds: [vtvp, 96497], Start: 12/8/2022 7:14:40 AM +00:00, End: 12/8/2022 7:38:23 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.1), ProviderIds: [vtvp, 96492], Start: 12/8/2022 7:38:23 AM +00:00, End: 12/8/2022 8:00:17 AM +00:00 2022-12-08 11:12:27.495 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.6), ProviderIds: [vtvp, 96503], Start: 12/8/2022 8:00:17 AM +00:00, End: 12/8/2022 8:25:45 AM +00:00 2022-12-08 11:12:27.497 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.4), ProviderIds: [vtvp, 96507], Start: 12/8/2022 8:25:45 AM +00:00, End: 12/8/2022 8:50:20 AM +00:00 2022-12-08 11:12:27.497 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:12:27.500 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners ... 2022-12-08 11:15:52.636 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:15:53.147 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.1), ProviderIds: [vtvp, 96498], Start: 12/8/2022 12:00:00 AM +00:00, End: 12/8/2022 12:25:05 AM +00:00 2022-12-08 11:15:53.147 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.2), ProviderIds: [vtvp, 96499], Start: 12/8/2022 12:25:05 AM +00:00, End: 12/8/2022 12:49:59 AM +00:00 2022-12-08 11:15:53.147 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.2), ProviderIds: [vtvp, 96493], Start: 12/8/2022 12:49:59 AM +00:00, End: 12/8/2022 1:14:03 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.5), ProviderIds: [vtvp, 96502], Start: 12/8/2022 1:14:03 AM +00:00, End: 12/8/2022 1:38:35 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.4), ProviderIds: [vtvp, 96501], Start: 12/8/2022 1:38:35 AM +00:00, End: 12/8/2022 2:02:38 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.3), ProviderIds: [vtvp, 96494], Start: 12/8/2022 2:02:38 AM +00:00, End: 12/8/2022 2:25:07 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.2), ProviderIds: [vtvp, 96505], Start: 12/8/2022 2:25:07 AM +00:00, End: 12/8/2022 2:50:14 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.4), ProviderIds: [vtvp, 96507], Start: 12/8/2022 2:50:14 AM +00:00, End: 12/8/2022 3:14:49 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.5), ProviderIds: [vtvp, 96508], Start: 12/8/2022 3:14:49 AM +00:00, End: 12/8/2022 3:39:20 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.3), ProviderIds: [vtvp, 96506], Start: 12/8/2022 3:39:20 AM +00:00, End: 12/8/2022 4:03:40 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.5), ProviderIds: [vtvp, 96496], Start: 12/8/2022 4:03:40 AM +00:00, End: 12/8/2022 4:26:18 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.3), ProviderIds: [vtvp, 96500], Start: 12/8/2022 4:26:18 AM +00:00, End: 12/8/2022 4:51:07 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.4), ProviderIds: [vtvp, 96495], Start: 12/8/2022 4:51:07 AM +00:00, End: 12/8/2022 5:14:53 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (2.6), ProviderIds: [vtvp, 96503], Start: 12/8/2022 5:14:53 AM +00:00, End: 12/8/2022 5:40:21 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (0.38), ProviderIds: [vtvp, 96510], Start: 12/8/2022 5:40:21 AM +00:00, End: 12/8/2022 7:13:03 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.1), ProviderIds: [vtvp, 96492], Start: 12/8/2022 7:13:03 AM +00:00, End: 12/8/2022 7:34:57 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (1.6), ProviderIds: [vtvp, 96497], Start: 12/8/2022 7:34:57 AM +00:00, End: 12/8/2022 7:58:40 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.1), ProviderIds: [vtvp, 96504], Start: 12/8/2022 7:58:40 AM +00:00, End: 12/8/2022 8:23:52 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Found Program The Inbetweeners (3.6), ProviderIds: [vtvp, 96509], Start: 12/8/2022 8:23:52 AM +00:00, End: 12/8/2022 8:50:20 AM +00:00 2022-12-08 11:15:53.148 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:15:53.153 Info SqliteItemRepository: Removing 18 old programs from channel 244025 The Inbetweeners 2022-12-08 11:15:53.193 Info VirtualTV: EventService > Cleared all cached library items ... 2022-12-08 11:26:15.629 Info App: ProcessRun 'StreamTranscode 9f8636' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-9f863663-1b00-4a81-9ceb-b55d78238fd2_1graph.txt" -copyts -start_at_zero -init_hw_device "qsv=vad:hw_any,child_device=/dev/dri/renderD128" -filter_hw_device vad -f matroska,webm -c:v:0 mpeg2_qsv -hwaccel:v:0 qsv -i "/TV (Misc.)/The Inbetweeners/Season 1/The Inbetweeners - 1x01 - First Day.mkv" -map 0:0 -map 0:1 -sn -c:v:0 h264_qsv -b:v:0 5213002 -g:v:0 75 -maxrate:v:0 5213002 -bufsize:v:0 10426004 -level:v:0 30 -keyint_min:v:0 75 -r:v:0 25 -profile:v:0 high -aud:v:0 1 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/Transcoding/transcoding-temp/14029C/14029C.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/Transcoding/transcoding-temp/14029C/14029C_%d.ts" 2022-12-08 11:26:15.834 Info Server: http/1.1 Response 200 to host2. Time: 222ms. http://host1:8096/emby/videos/96492/hls1/main/0.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:15.881 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/1.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:15.907 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:26:15.908 Info SessionManager: Playback start reported by app Emby Web 4.7.10.0 playing First Day. Started at 0 ms 2022-12-08 11:26:15.909 Info Server: http/1.1 Response 204 to host2. Time: 2ms. http://host1:8096/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:26:15.984 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/1.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.048 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/2.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.050 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/2.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.092 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/3.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.126 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:26:16.127 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://host1:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:26:16.194 Info Server: http/1.1 Response 200 to host2. Time: 102ms. http://host1:8096/emby/videos/96492/hls1/main/3.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.228 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/4.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.330 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/4.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.377 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/5.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.380 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/5.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.416 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/6.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.519 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/6.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.545 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/7.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.648 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/7.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.687 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/8.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.690 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/8.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.739 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/9.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.841 Info Server: http/1.1 Response 200 to host2. Time: 102ms. http://host1:8096/emby/videos/96492/hls1/main/9.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.873 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/10.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:16.875 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/10.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:16.915 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/11.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:17.018 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/11.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:17.050 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/12.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:17.152 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/12.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:17.190 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/13.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:17.192 Info Server: http/1.1 Response 200 to host2. Time: 2ms. http://host1:8096/emby/videos/96492/hls1/main/13.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:17.228 Info Server: http/1.1 GET http://host1:8096/emby/videos/96492/hls1/main/14.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f. Accept=*/*, Connection=keep-alive, Host=192.168.0.2:8096, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36, Accept-Encoding=gzip, deflate, Accept-Language=en-US,en;q=0.9,en-GB;q=0.8, Referer=http://192.168.0.2:8096/web/index.html, DNT=1 2022-12-08 11:26:17.331 Info Server: http/1.1 Response 200 to host2. Time: 103ms. http://host1:8096/emby/videos/96492/hls1/main/14.ts?PlaySessionId=86b2327f26ca404b9be3e9e5d143473f 2022-12-08 11:26:17.383 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:26:17.384 Info App: ProcessRun 'StreamTranscode 9f8636': Stopping ffmpeg process with q command for /Transcoding/transcoding-temp/14029C/14029C_0.ts 2022-12-08 11:26:17.408 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-transcode-9f863663-1b00-4a81-9ceb-b55d78238fd2_1graph.txt 2022-12-08 11:26:17.409 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 15,724.000 bytes Graph Count: 2 2022-12-08 11:26:17.409 Info App: AppendExtraLogData - File Deleted 2022-12-08 11:26:17.410 Info App: ProcessRun 'StreamTranscode 9f8636' Process exited with code 0 - Succeeded 2022-12-08 11:26:17.410 Info SessionManager: Playback stopped reported by app Emby Web 4.7.10.0 playing First Day. Stopped at 1223 ms 2022-12-08 11:26:17.410 Info Server: http/1.1 Response 204 to host2. Time: 27ms. http://host1:8096/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:26:17.912 Info VirtualTV: EventService > SetPlaystatePlaylist: Save playback progress for SessionId: 43de01cf710b392340fed2fd6a64e7bc, User: Paul, Item: The Inbetweeners - S1E1 First Day, PlaybackPositionTicks: 0(12238540), Watched: False 2022-12-08 11:27:00.032 Info Server: http/1.1 POST http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:27:00.034 Info Server: http/1.1 Response 204 to host2. Time: 3ms. http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:27:10.382 Info Server: http/1.1 POST http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:27:10.385 Info Server: http/1.1 Response 204 to host2. Time: 2ms. http://host1:8096/emby/Plugins/2313AD5A-91E9-42E1-BEC4-E1861FA0CDC4/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:27:12.531 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:27:12.531 Info Server: http/1.1 Response 204 to host2. Time: 1ms. http://host1:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:27:19.377 Info Server: http/1.1 POST http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:27:19.377 Info Server: http/1.1 Response 204 to host2. Time: 0ms. http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0 2022-12-08 11:27:19.385 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-08 11:27:19.386 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Querying Library for TVShows 2022-12-08 11:27:19.910 Info VirtualTV: TVService > GetPrograms: Channel: Friends, ChannelId: VirtualTV0, Returning 234 TVShows 2022-12-08 11:27:19.952 Info SqliteItemRepository: Removing 233 old programs from channel 98646 Friends 2022-12-08 11:27:20.047 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Querying Library for TVShows 2022-12-08 11:27:20.584 Info VirtualTV: TVService > GetPrograms: Channel: The Inbetweeners, ChannelId: VirtualTV1, Returning 19 TVShows 2022-12-08 11:27:20.587 Info SqliteItemRepository: Removing 18 old programs from channel 264595 The Inbetweeners 2022-12-08 11:28:03.040 Info Server: http/1.1 POST http://host1:8096/emby/Users/38bdd6dc0c844bf1bc75c9a3b7592cd6?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:28:03.064 Info Server: http/1.1 Response 204 to host2. Time: 24ms. http://host1:8096/emby/Users/38bdd6dc0c844bf1bc75c9a3b7592cd6?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:28:03.069 Info Server: http/1.1 POST http://host1:8096/emby/Users/38bdd6dc0c844bf1bc75c9a3b7592cd6/Policy?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:28:03.084 Info Server: http/1.1 Response 204 to host2. Time: 15ms. http://host1:8096/emby/Users/38bdd6dc0c844bf1bc75c9a3b7592cd6/Policy?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0&reqformat=json 2022-12-08 11:28:08.832 Info Server: http/1.1 POST http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4-003d3e9d57c5&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-08 11:28:08.833 Info Server: http/1.1 Response 204 to host2. Time: 0ms. http://host1:8096/emby/ScheduledTasks/Running/9492d30c70f7f1bec3757c9d0a4feb45?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=66d7e90c-2c70-4902-91c4- ^^ Not sure how much of that is relevant, but there's more mentioned in the log that refers to the show name etc. I've since added x2 more channels, bringing me up to a total of x4 channels. Two of them are working, x2 of them aren't, the logs above refer to one that isn't. All created the same way etc. I come back the next day after leaving the above in place, to see for whatever reason that x3 of the channels now don't work
PaulE123 20 Posted December 9, 2022 Posted December 9, 2022 A quick refresh of the page, and now x3 of them DO work I genuinely don't know what I'm doing wrong that I just can't get that one show to work...
PaulE123 20 Posted December 9, 2022 Posted December 9, 2022 Ok more weirdness (sorry for spamming posts) But I just realised one of the shows has disappeared from my channel, and looking at the epg data, it disappeared because the EPG data ran out. See pics... So there's something up with the EPG, and maybe that's related to why the 4th channel won't display the show?
PaulE123 20 Posted December 9, 2022 Posted December 9, 2022 On 12/6/2022 at 11:32 PM, pünktchen said: @PaulE123 If you either enable debug logging in the plugin or for the whole Emby server and then do a guide refresh, the log file should list the series and episode names for every program that the plugin is generating. That is metadata from your library, not filenames. So please tell me if that is available in the log file. Sorted, it was the "days to download guide data" setting all along. It was defaulted to auto, so I changed it to x3 days restarted the emby docker and boom, all working perfect now 1
ryzen5000 17 Posted December 9, 2022 Posted December 9, 2022 Hi I am trying to set up virtual TV plugin 4.7. Firstly is there a newer version of this plugin? It looks like this was last created 2019 and might be outdated considering EMby has evolved. I added 3 channels but only one is showing up in the TV guide and I tried reinstalling the plugin several times. I set each chanel up the same way. Can anyone tell me how to make the other channels show up?
ryzen5000 17 Posted December 9, 2022 Posted December 9, 2022 Hi is there a newer version of this plugin, last developed was 2019? I made 4 channels and only one shows up. I tried reinstalling the plugin several times and I cannot get it working.
pünktchen 1411 Posted December 10, 2022 Author Posted December 10, 2022 1 hour ago, ryzen5000 said: Hi is there a newer version of this plugin, last developed was 2019? Why do you think that? Doesn't the version history tell an other story? 1 hour ago, ryzen5000 said: I made 4 channels and only one shows up. Sorry, but how should we know where's the problem with that many informations?
ryzen5000 17 Posted December 10, 2022 Posted December 10, 2022 I hope this is not the only response I get because I do not see any helpful solutions or questions. Does anyone know why my channels are not showing up?
roaku 842 Posted December 10, 2022 Posted December 10, 2022 (edited) 17 minutes ago, ryzen5000 said: I hope this is not the only response I get because I do not see any helpful solutions or questions. Does anyone know why my channels are not showing up? The developer of the plugin just asked you for details on your configuration. I suggest screenshots. Edited December 10, 2022 by roaku 1
hstamas 179 Posted December 19, 2022 Posted December 19, 2022 @pünktchencould you tell me if this is the correct syntax for telling a channel to not include episodes from 2 different tags I've defined? CH1 && !Christmas Cooking && !Thanksgiving Cooking I want channel #1 to not play episodes with the tags "Christmas Cooking" and Thanksgiving Cooking". Thanks a lot!
InaudibleDirge 7 Posted December 19, 2022 Posted December 19, 2022 would it be possible for a channel to populate from content in playlists?
