gtpvkr 2 Posted October 8, 2022 Posted October 8, 2022 Hi @pünktchen Library Folder not displaying, please help me version=4.7.8.0 Plugin 4.7.X
Junglejim 385 Posted October 8, 2022 Posted October 8, 2022 1 hour ago, gtpvkr said: Hi @pünktchen Library Folder not displaying, please help me version=4.7.8.0 Plugin 4.7.X That's strange, what os are you running there? Is "Emby User: TV" a valid user on your server?
gtpvkr 2 Posted October 8, 2022 Posted October 8, 2022 TV & test are both valid users, i dont see any response in api in network tab
Junglejim 385 Posted October 8, 2022 Posted October 8, 2022 2 minutes ago, gtpvkr said: I'm using windows 11 Ok.. that rules me out for assistance , I'm a Linux user. I'm sure someone will have some idea.. @pünktchen is your best bet.
pünktchen 1411 Posted October 8, 2022 Author Posted October 8, 2022 2 hours ago, gtpvkr said: TV & test are both valid users, i dont see any response in api in network tab An empty response is not an error. It just means the user has no access rights to any library. Check the user settings!
gtpvkr 2 Posted October 8, 2022 Posted October 8, 2022 thanks @pünktchen, issue resolved when I did below changes to user Earlier user does not have full lib access and only few libraries access , even though nothing was displayed. Now I changed to full Library access and able to see Libraries are loading. Thanks again
pünktchen 1411 Posted October 8, 2022 Author Posted October 8, 2022 1 minute ago, gtpvkr said: Earlier user does not have full lib access and only few libraries access , even though nothing was displayed. Now I changed to full Library access and able to see Libraries are loading. Of course it's not intentional that the user needs access to all libraries. So something must have been changed in Emby that i have to fix in the plugin.
pünktchen 1411 Posted October 8, 2022 Author Posted October 8, 2022 (edited) On 10/8/2022 at 9:47 AM, home04277 said: Tried the new Version but now i am not even see the Plugin anymore. Try this one please: Edited October 11, 2022 by pünktchen Removed attachement
home04277 1 Posted October 9, 2022 Posted October 9, 2022 I did and now i see the Plugin back in Settings but still empty Library. Attaching new Logs. Is it just as i use Emby on Synology? embyserver (1).txt
pünktchen 1411 Posted October 9, 2022 Author Posted October 9, 2022 6 hours ago, home04277 said: Is it just as i use Emby on Synology? Not Synology in general. It seems to be a problem with modells that need the Mono framework to run Emby or it's just your installation. What Synology do you own?
home04277 1 Posted October 9, 2022 Posted October 9, 2022 I had initially the Emby Version from Synology App Store, later updated manually using the packages from Emby Page. VirtualTV hasn’t worked on any versions so I guess it’s may related to Synology specific s
pünktchen 1411 Posted October 9, 2022 Author Posted October 9, 2022 I've asked the Emby chief developer for some help. 1
masterdot 0 Posted October 9, 2022 Posted October 9, 2022 Hi there, at first thanks for this BRILLIANT idea! Im currently setting up some channels and have some questions/ problems: I want to make a channel with just horror and thriller movies. I did filter with Horror||Thriller but it looks like its not working correctly. Maybe you have a quick help for that? And I want to make a channel just playing my youtube "mirror". But It doesnt seem to collect the movies from there, I did create a library with all the youtubes in it. But it seems to ignore it. Is there any chance to use a playlist as source filter? In combination with smart playlists I have a idea how to solve my problems, but it seems not to be possible. One idea is a channel with: "play all the movies that are not watched, or been played more than one time. sorted by date added/ last played" for creating a channel with unwatched movies or often watched movies. And how would I create something like playing some shorts between the movies/ episodes? As you see I have some problems with collecting the materials thanks in advance
home04277 1 Posted October 9, 2022 Posted October 9, 2022 10 minutes ago, pünktchen said: I've asked the Emby chief developer for some help. Thanks, much appreciated your time on this issue. I saw your plugin and thought that’s it for my Mediathek but since that stucking. What I tried so far: - multiple versions from emby - create new users with full access - create multiple api keys all those get the library selection showing content
pünktchen 1411 Posted October 10, 2022 Author Posted October 10, 2022 On 10/9/2022 at 6:02 PM, masterdot said: I want to make a channel with just horror and thriller movies. I did filter with Horror||Thriller but it looks like its not working correctly. Maybe you have a quick help for that? The condition sounds okay to me. Keep in mind strm files are not supported. If that's not your problem, i kneed more info. On 10/9/2022 at 6:02 PM, masterdot said: I did create a library with all the youtubes in it. But it seems to ignore it. A Home Videos & Photos library is not supported for channel creation. I don't see the need for it. Those libraries can only act as a source for bumpers/shorts between the main program. On 10/9/2022 at 6:02 PM, masterdot said: Is there any chance to use a playlist as source filter? It's something i'd like to add at some time, but obviously it's currently not possible. On 10/9/2022 at 6:02 PM, masterdot said: And how would I create something like playing some shorts between the movies/ episodes? Fill in the bumpers folder path with something (a subfolder for example) that is part of a Home Videos & Photos library.
pünktchen 1411 Posted October 10, 2022 Author Posted October 10, 2022 On 10/9/2022 at 6:09 PM, home04277 said: Thanks, much appreciated your time on this issue. I saw your plugin and thought that’s it for my Mediathek but since that stucking. What I tried so far: - multiple versions from emby - create new users with full access - create multiple api keys all those get the library selection showing content I still need more time to solve your problem. The proposed solution to fix your issue, also breaks some main functionality of the plugin, where i'm still searching for an acceptable workaround. 1
jblaze12 8 Posted October 11, 2022 Posted October 11, 2022 Quote A Home Videos & Photos library is not supported for channel creation. I don't see the need for it. Those libraries can only act as a source for bumpers/shorts between the main program. I just ran into this too. It's not a good reason but I have one: I have a bunch of halloween single episodes from random shows I don't want to collect overall (and have clutter my library). So making a home videos channel means I can even customize season only content without having to collect entire shows for 1 episode.
jblaze12 8 Posted October 11, 2022 Posted October 11, 2022 I ended up just creating a new library as tv shows instead of mixed content and put the individual episodes into series folders and it worked.
home04277 1 Posted October 11, 2022 Posted October 11, 2022 9 hours ago, pünktchen said: I still need more time to solve your problem. The proposed solution to fix your issue, also breaks some main functionality of the plugin, where i'm still searching for an acceptable workaround. Just curious what could be the cause of that. Is it the Package Management of Synology or dependencies which might causing it. Seems to work for others like a charme.
pünktchen 1411 Posted October 11, 2022 Author Posted October 11, 2022 1 hour ago, home04277 said: Is it the Package Management of Synology or dependencies which might causing it. It's the dependencies. Because you have a Unix like OS and an ARM processor, your Emby installation needs the Mono runtimes to execute code that was developed for Windows .NetFramework. It seems that Emby for Mono is compiled against older libraries than my plugin is targeting. But i'm on a good way and will provide you another test version later today. 1
pünktchen 1411 Posted October 11, 2022 Author Posted October 11, 2022 (edited) @home04277 Hopefully the last test version: Edited October 12, 2022 by pünktchen Removed attachement 1
home04277 1 Posted October 12, 2022 Posted October 12, 2022 That works now! But is it normal that i just can choose the top level folder and not be more granular? I have one Big Library with dozens of TV Shows but i put them in separate Folders. How can i just include specific subfolders? I can Always include specific Shows but how to limit just to this?
