mellowmustard 0 Posted June 18, 2022 Posted June 18, 2022 For some reason I am unable to get playlist (live) to work. Continuous works but i find my content doesnt hold the same aspect ratio so it doesnt really like continuous mode, but thats neither here nor there....Id rather get Playlist mode to work. When I put it on playlist mode and select it, it goes to a black screen for 30 seconds then drops back to home. ONLY think i have found in the logs was /var/lib/emby/metadata/library/00/00e6b1ff67d0cfb65ba8825631fe1b94/backdrop.png so....i donno. Anyhelp would be amazing. Thanks!
pünktchen 1411 Posted June 18, 2022 Author Posted June 18, 2022 You could start with: What device and client? Local or remote connection? Full log? Nevertheless, try to "Play on ..." something from a browser session on your server device to the device where the virtual channels don't work. If that also fails and you have configured a web proxy, make sure that it allows websockets.
mellowmustard 0 Posted June 19, 2022 Posted June 19, 2022 OK i have it running in a debian container in proxmox it was unable to play on chrome. I do have a web proxy and it does have allow websockets. 2022-06-18 20:42:34.515 Info Server: http/1.1 Response 204 to host1. Time: 1ms. http://emby_remote_ip/emby/Sessions/Playing/Progress?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc&X-Emby-Client-Version=4.7.2.0&reqformat=json 2022-06-18 20:42:39.547 Error Server: Error processing request *** Error Report *** Version: 4.7.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.15.30-2-pve (build@proxmox) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP PVE 5.15.30-3 (Fri Framework: .NET 6.0.2 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 12 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/var/lib/emby/metadata/library/00/00e6b1ff67d0cfb65ba8825631fe1b94/backdrop.png'. File name: '/var/lib/emby/metadata/library/00/00e6b1ff67d0cfb65ba8825631fe1b94/backdrop.png' at Emby.Drawing.Skia.SkiaEncoder.GetSKFileStream(String path) at Emby.Drawing.Skia.SkiaEncoder.EncodeImage(String inputPath, String outputPath, Boolean autoOrient, Nullable`1 orientation, Int32 quality, ImageProcessingOptions options, ImageFormat selectedOutputFormat) at Emby.Drawing.ImageProcessor.ProcessImage(ImageProcessingOptions options, CancellationToken cancellationToken) at Emby.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Drawing.Skia TargetSite: SkiaSharp.SKFileStream GetSKFileStream(System.String) Path: /var/lib/emby/metadata/library/00/00e6b1ff67d0cfb65ba8825631fe1b94/backdrop.png
pünktchen 1411 Posted June 19, 2022 Author Posted June 19, 2022 12 hours ago, mellowmustard said: OK i have it running in a debian container in proxmox it was unable to play on chrome. Chrome in the debian container or elsewhere? LAN or WAN? Full log? Have you tried the test that i suggested?
mellowmustard 0 Posted June 19, 2022 Posted June 19, 2022 (edited) So, as you can see Im not great at this. @pünktchen sorry bout that. Emby is running in a debian container in Proxmox I tried to use playlist mode in chrome on my windows 10 desktop. did not work. used firefox to stream to my cellphone (samsung z fold). it worked. Tried playing in firefox (windows 10) and it works. It seems to dislike chrome and emby theater. I use a containerd ngnix proxy manager and have websockets support on. I sent you some logs. I dont know if they are correct Edited June 19, 2022 by mellowmustard
PrincessClevage 175 Posted June 20, 2022 Posted June 20, 2022 (edited) Where can I find the latest dll? When I enable continuous playlist mode for tv shows folder it just plays movies even tho I have select the tv folder and selected context is tv series ? nevermind, looks like I just had to add a genre to the field Edited June 20, 2022 by PrincessClevage
PrincessClevage 175 Posted June 22, 2022 Posted June 22, 2022 (edited) When i attempt to chrome cast the channel i have created to a chrome cast device it fails to start. Curious if chrome cast might of already been tested and working with this plugin? The only way i can get it to work is to set it to continuous playback (Live) which seems to force transcoding Edited June 22, 2022 by PrincessClevage
sirmiketr 5 Posted June 28, 2022 Posted June 28, 2022 Any plans to update for 4.8? Able to get channels up and running but when i press play it shows me the loading icon and nothing more. Logs don't show much. Tried over LAN and WAN, android, different web browsers. including log embyserver_6.txt
pünktchen 1411 Posted June 28, 2022 Author Posted June 28, 2022 24 minutes ago, sirmiketr said: Any plans to update for 4.8? Why? 4.8 is not different than 4.7 26 minutes ago, sirmiketr said: Logs don't show much. It only shows the guide refresh, but no (complete) playback attempt.
pünktchen 1411 Posted June 28, 2022 Author Posted June 28, 2022 On 6/22/2022 at 10:40 AM, PrincessClevage said: When i attempt to chrome cast the channel i have created to a chrome cast device it fails to start. Curious if chrome cast might of already been tested and working with this plugin? The only way i can get it to work is to set it to continuous playback (Live) which seems to force transcoding Sorry for the late answer, but obviously you've already found what's working and what's not. Playlist playback will not work with casting and there's nothing i can do here.
sirmiketr 5 Posted July 4, 2022 Posted July 4, 2022 On 6/28/2022 at 3:45 AM, pünktchen said: Why? 4.8 is not different than 4.7 Well, currently continuous playback (live) breaks everything and gives a constant playback error (no compatible streams) for me. I used to have 4 channels on playlist(live) and they all played correctly, i switched 2 channels to continuous playback (live) and now no channel will play. the logs look exactly the same as above.
pünktchen 1411 Posted July 4, 2022 Author Posted July 4, 2022 5 hours ago, sirmiketr said: the logs look exactly the same as above. I don't believe that. Your previous log wasn't even a full log, it was cutted after a guide refresh. Go into your log folder and just delete everything. In Emby Logs make sure debug logging is enabled. Rotate the log file under Scheduled Tasks. Try to play a channel, but make sure no other task is running at that time and no other user is playing something. Send me the whole content of your log folder.
sirmiketr 5 Posted July 4, 2022 Posted July 4, 2022 41 minutes ago, pünktchen said: I don't believe that. Your previous log wasn't even a full log, it was cutted after a guide refresh. Go into your log folder and just delete everything. In Emby Logs make sure debug logging is enabled. Rotate the log file under Scheduled Tasks. Try to play a channel, but make sure no other task is running at that time and no other user is playing something. Send me the whole content of your log folder. I actually downloaded the whole log, but believe what you will. Debugging was not enabled for anything in that log so that may be why. I've enabled debugging for both virtualtv and emby itself and rotated them as requested. and here they are. Uncut and raw for your pleasure. Even went onto a clickorama. I'm seeing this though : Does it require any special permissions on linux? embyserver_7.txt ffmpeg-VirtualTV3_20220704230231.txt
pünktchen 1411 Posted July 5, 2022 Author Posted July 5, 2022 Your api key seems to have a "space" at the end, that's why it fails.
sirmiketr 5 Posted July 5, 2022 Posted July 5, 2022 We have movement! although now i'm met with simply a black screen : The playlist (live) channels started working tho - I'm including the logs. lmk if these logs have enough detail ffmpeg-transcode-338b5946-4d2d-4d8a-a1f8-38a1dd2236f9_1.txt embyserver_8.txt ffmpeg-VirtualTV3_20220705030044.txt
sirmiketr 5 Posted July 5, 2022 Posted July 5, 2022 Nevermind! Seems like it just needed some time, everything plays correctly now! 1
badwhip 4 Posted July 7, 2022 Posted July 7, 2022 i use to beable to point to a whole folder and it would add all the shows too the tv channel. those channels have stopped working and the only ones that are working are the ones were i have desinated each show. has something changed in the updates for this? do you need anything in tags if u want the whole folder of shows to be added?
pünktchen 1411 Posted July 7, 2022 Author Posted July 7, 2022 I think i've changed this long time ago. You have to use at least one condition that fulfills your needs. It doesn't have to be tags.
badwhip 4 Posted July 7, 2022 Posted July 7, 2022 Yeah I have been running the same channel for a long time and when I updated to latest dll file the ones thst were blank didn't work anymore so if I have two drives with classic TV shows1 and classic TV shows 2 how do I put something in where it will pull all the shows from these two drive something with a *?
hstamas 179 Posted July 10, 2022 Posted July 10, 2022 (edited) I know this has been talked about before but recently I have noticed it being much more frequent. Episodes repeating themselves in less than 24 hours. As my wife sits here this morning watching the Food Network channel I’ve set up she is viewing an episode that was shown less than 24 hours before. I also notice it with my Family Guy channel. Seem pretty consistant and almost always repeats within a 24 hour time frame. Is there any way to get things more randomized? I have plenty of any given show to pull from yet it consistently does this and also only seems to pull from a small subset of episodes. Edited July 10, 2022 by hstamas 1
demhinds 5 Posted July 10, 2022 Posted July 10, 2022 8 hours ago, hstamas said: I know this has been talked about before but recently I have noticed it being much more frequent. Episodes repeating themselves in less than 24 hours. As my wife sits here this morning watching the Food Network channel I’ve set up she is viewing an episode that was shown less than 24 hours before. I also notice it with my Family Guy channel. Seem pretty consistant and almost always repeats within a 24 hour time frame. Is there any way to get things more randomized? I have plenty of any given show to pull from yet it consistently does this and also only seems to pull from a small subset of episodes. It sounds like you need to simply adjust the guide refresh delay setting within the main settings of the plugin. I am guessing yours isn't set or is set to 24 hours. Change it to a longer time frame. It's titled something like "disable creation of new programming for _ hours" (apologies as I am not at my computer at the moment so I can't be more specific)
PuffyToesToo 348 Posted July 11, 2022 Posted July 11, 2022 On 7/7/2022 at 6:18 PM, badwhip said: Yeah I have been running the same channel for a long time and when I updated to latest dll file the ones thst were blank didn't work anymore so if I have two drives with classic TV shows1 and classic TV shows 2 how do I put something in where it will pull all the shows from these two drive something with a *? I don't know if this will help you at all, but I had this problem until I put (for example) '1900' for minimum release date. All I needed in my case was to add that and mine populated afterward. (I am only chiming in as I use a similar setup for classic tv channels).
hstamas 179 Posted July 11, 2022 Posted July 11, 2022 16 hours ago, demhinds said: It sounds like you need to simply adjust the guide refresh delay setting within the main settings of the plugin. I am guessing yours isn't set or is set to 24 hours. Change it to a longer time frame. It's titled something like "disable creation of new programming for _ hours" (apologies as I am not at my computer at the moment so I can't be more specific) Mine is at a of default of 0? Could that be the issue? Ive refreshed guide data manually and it still seems to be the same? Suggestion as to a number to put in there? Thanks for your help!
