pünktchen 1411 Posted May 21, 2022 Author Posted May 21, 2022 @Mookdog can you try this version please: VirtualTV-Test.zip
softworkz 5133 Posted May 21, 2022 Posted May 21, 2022 30 minutes ago, pünktchen said: I saw it in the server log, that's why i requested the ffmpeg log after this. But that looks okay to me. I'm not sure about the ending of the transcoding process. Normally, Emby sends a 'q' to quit and then we see the word "EXIT" printed in the log which allows to determine whether the shutdown was graceful. But maybe you do it in a different way..? But I still think that the key is the server error regarding segments.
pünktchen 1411 Posted May 21, 2022 Author Posted May 21, 2022 37 minutes ago, softworkz said: I'm not sure about the ending of the transcoding process. Normally, Emby sends a 'q' to quit and then we see the word "EXIT" printed in the log which allows to determine whether the shutdown was graceful. But maybe you do it in a different way..? But I still think that the key is the server error regarding segments. When the user starts playing a channel a 60 seconds ts file is placed in the transcoding folder and is used as path for the live tv request. If then the app sends a playback start event to Emby, my plugin sends a remote play command to the app with the actual video from the library. But the remote play command isn't executed anymore in the app, because an error is thrown for the 60 seconds ts file (timing problem?). My suspicion is that the auto cleanup of the transcoding folder is too aggressive. The small ts file gets deleted while the app hasn't yet started the remote playback command.
Jdturos 0 Posted May 21, 2022 Posted May 21, 2022 7 hours ago, Spaceboy said: a new plugin was required for server versions 4.7+. have you manually installed that? No I didn’t can you send it to me
Spaceboy 2573 Posted May 21, 2022 Posted May 21, 2022 32 minutes ago, Jdturos said: No I didn’t can you send it to me It’s in the 1st post
Mookdog 90 Posted May 21, 2022 Posted May 21, 2022 (edited) 4 hours ago, pünktchen said: @Mookdog can you try this version please: VirtualTV-Test.zip 1.58 MB · 1 download Hey @pünktchen For the browser it worked fine. But as far as the shield tv on Emby app for Android TV it still shows a blank screen still Update : It seems like it worked remotely (I tested on phone with cellular network) and it played. But locally its not on both ATV version and regular android version Update Update : I just had a friend test it remotely from another state and his is working fine. Locally it doesnt play Mook Edited May 21, 2022 by Mookdog Update
pünktchen 1411 Posted May 21, 2022 Author Posted May 21, 2022 If you have the regular Android app installed at the same time as the AndroidTV app on the Shield, please uninstall the regular app and try again.
Mookdog 90 Posted May 21, 2022 Posted May 21, 2022 (edited) 9 minutes ago, pünktchen said: If you have the regular Android app installed at the same time as the AndroidTV app on the Shield, please uninstall the regular app and try again. Ok uninstalled rebooted shield and tried the ATV version and still the same blank screen also rebooted server https://streamable.com/m6b1bh update : Seems to be the shield causing the problem. I just tried on my Formuler GTV and it worked perfect Mook Edited May 21, 2022 by Mookdog update
pünktchen 1411 Posted May 21, 2022 Author Posted May 21, 2022 I'm out of ideas. I also own a Shield and it's working for me. Although i'm still on Shield Experience 8, but i can't image that makes a difference or others would have reported it here. Maybe you should make a new thread in the AndroidTV section and send an in app log to ebr.
Mookdog 90 Posted May 21, 2022 Posted May 21, 2022 14 minutes ago, pünktchen said: I'm out of ideas. I also own a Shield and it's working for me. Although i'm still on Shield Experience 8, but i can't image that makes a difference or others would have reported it here. Maybe you should make a new thread in the AndroidTV section and send an in app log to ebr. I had to factory reset shield. All is fine now working as it should. Thank u for working on this with me I appreciate it. All working fine now Mook 1
rattlerviper 0 Posted May 22, 2022 Posted May 22, 2022 So I got this set up and working today and it is great! One question though, what file type and parameters are allowed for the TV logo? I seem to be unable to get one set.
Mookdog 90 Posted May 22, 2022 Posted May 22, 2022 1 hour ago, Jdturos said: What is SHIELD NvIdia Shield Pro is an android streaming box that allows u to stream movies and shows/play games etc etc. My personal opinion is its the best android device on the market since 2015 Mook
Mookdog 90 Posted May 24, 2022 Posted May 24, 2022 Hey @pünktchen Plugin is working great I do have 1 question What can I do to prevent my epg from running out of program data ? I want it to continue the whole week until the guide refreshes after a week ? I have it setup to play episodes in order but it doesnt repeat after the show is done Mook
pünktchen 1411 Posted May 25, 2022 Author Posted May 25, 2022 Server -> Live TV -> Advanced -> Number of days of guide data to download: Anything but Auto
Mookdog 90 Posted May 25, 2022 Posted May 25, 2022 1 hour ago, pünktchen said: Server -> Live TV -> Advanced -> Number of days of guide data to download: Anything but Auto Thanks bro I completely forgot about that part Mook
dsync89 0 Posted May 25, 2022 Posted May 25, 2022 (edited) Was searching on Google for native pseudotv plugin for Emby and stumbled across this one. Hats off for this native plugin built directly into emby Before I start does it support direct play or HLS direct without transcoding? I've previously tried pseudotv, dizquetv and ersatztv on my Kodi Emby setup to simulate tv browsing experience, and would like to compare them with this one too. Edited May 25, 2022 by dsync89
pünktchen 1411 Posted May 25, 2022 Author Posted May 25, 2022 14 minutes ago, dsync89 said: Before I start does it support direct play or HLS direct without transcoding? Yes.
thisismytrial 0 Posted June 1, 2022 Posted June 1, 2022 I would like to switch to playlist mode, but there is one issue that keeps coming up. Basically, it seems like there is no way to use playlist mode without the log showing that my active account is watching or just watched a show that aired. Obviously, I created a user just to be the Channel User. I have Clear Resume Point, Remove Shows From Continue Watching and Add the "Channel User" to playback sessions all checked. However, if I tune into a show while logged into my normal account, it still shows up on the log and thus Continue Watching however briefly. Continuous Playback mode doesn't have this problem and it only logs that my account tuned to that channel. Is there anyway to use VirtualTV in Playlist Mode without leaving any trace on my normal account and it only effecting the Channel User? Thanks for all you do, @pünktchen!
pünktchen 1411 Posted June 2, 2022 Author Posted June 2, 2022 21 hours ago, thisismytrial said: Is there anyway to use VirtualTV in Playlist Mode without leaving any trace on my normal account and it only effecting the Channel User? No, not possible because effectively the logged in user is playing the videos from the library. Beside the Activity messages in the dashboard, does it make any problem to Continue Watching or similar or why do you want to use the channel user?
vtjapes 10 Posted June 2, 2022 Posted June 2, 2022 I have a lot of movies that I put into collections since it's easier to bulk move something into a collection instead of adding a tag to each file. I recently discovered this plugin and I made a bunch of channels for my son. I was wondering if there was a way to make a channel out of a few collections. For instance I made a collection of modern Kaiju movies and a second collection of old ones. If I want to create a Kaiju channel currently I'd have to tag each movie individually and then use the "tags" flag to grab movies for the channel. So curious if Collections could be added in addition to Tags, Genres, Actors, Directors, and Studios that are already available. Thanks again for creating this. My son and I are having a blast creating channels.
thisismytrial 0 Posted June 4, 2022 Posted June 4, 2022 On 6/2/2022 at 5:24 PM, pünktchen said: No, not possible because effectively the logged in user is playing the videos from the library. Beside the Activity messages in the dashboard, does it make any problem to Continue Watching or similar or why do you want to use the channel user? I never use the channel user. But I find the watch data doesn't stick exclusively to that user. My main user account tends to have the episodes show up on Continue Watching. Most of the time very briefly, but it happens often enough that it doesn't feel like a clean experience like the Continuous Playback channels do.
roaku 842 Posted June 4, 2022 Posted June 4, 2022 I'm in a similar situation. I have a lot of channels dedicated to classic sitcoms. I don't want continue watching and trakt thinking I'm watching all of the Beverly Hillbillies just because I had some guests over and we watched a couple of random show episodes. I currently log in as a special purpose Emby user for watching Virtual TV channels.
