crusher11 1150 Posted April 28, 2022 Posted April 28, 2022 Yep, that was a lot quicker than I was anticipating. Excellent!
PuffyToesToo 348 Posted April 28, 2022 Posted April 28, 2022 Thank you for all the hard work @pünktchen. 2
warrentc3 47 Posted April 28, 2022 Posted April 28, 2022 (edited) Testing now... thanks for all your hard work on this. Looks like the Actor per Episode is still providing incorrect episodes where the actor isn't listed as appearing. Curious if there's any way to not have episodes show as "Premiere". Edited April 28, 2022 by warrentc3
pünktchen 1411 Posted April 28, 2022 Author Posted April 28, 2022 8 hours ago, warrentc3 said: Looks like the Actor per Episode is still providing incorrect episodes where the actor isn't listed as appearing. It's working fine here in my testing. Are you sure there aren't any other rules than actor for your channel that leads to the undesired result? 8 hours ago, warrentc3 said: Curious if there's any way to not have episodes show as "Premiere". It is showing this for items that have not been watched by the user that you have selected in the channel definition of the config. I like it this way, so i will not remove it completely. What i could do is to make it dependend on the playback option "Add the Channel User to playback sessions (Sync play state)". Would that help you?
warrentc3 47 Posted April 28, 2022 Posted April 28, 2022 8 minutes ago, pünktchen said: It's working fine here in my testing. Are you sure there aren't any other rules than actor for your channel that leads to the undesired result? Literally the only rule set is actor = “Anthony Bourdain”. I setup a virtualtv user for library access. i suppose i could mark my whole library as watched. i totally understand why the play state is what it is. there isn’t any way to have guide data per user, so that’ll do. thanks!
pünktchen 1411 Posted April 28, 2022 Author Posted April 28, 2022 42 minutes ago, warrentc3 said: Literally the only rule set is actor = “Anthony Bourdain”. What else should i say? The only way to debug your problem would be sending me your library.db
warrentc3 47 Posted April 28, 2022 Posted April 28, 2022 6 minutes ago, pünktchen said: What else should i say? The only way to debug your problem would be sending me your library.db i’ll do some repro work on my dev instance with logging turned up and keep you posted.
fillidill 175 Posted May 1, 2022 Posted May 1, 2022 I love this plugin and am a regular user of it. Would it be possible to add a logo of the channel playing in the video OSD? See a simple mockup below. But I am guessing this maybe have to be done by the emby team to even be possible? 3
david.torcivia 2 Posted May 12, 2022 Posted May 12, 2022 Are there plans to increase the content types? Say if I wanted to make an MTV type channel that just plays music videos (something emby supports and has additional metadata for via the IMVDB plugin).
pünktchen 1411 Posted May 12, 2022 Author Posted May 12, 2022 7 hours ago, david.torcivia said: Are there plans to increase the content types? Say if I wanted to make an MTV type channel that just plays music videos (something emby supports and has additional metadata for via the IMVDB plugin). Music videos are already possible. 1
Seger 123 Posted May 18, 2022 Posted May 18, 2022 (edited) Hey, I just updated to the new server version and now I no longer see the live channels, do I have to do anything special? The plugin is still maintained and my settings are still there. Edit:just seen, must also install the new plugin Edited May 18, 2022 by Seger
Mookdog 90 Posted May 19, 2022 Posted May 19, 2022 (edited) Hey @pünktchenI am on the beta .40 of the emby server for windows. For some reason the streams load fine with the plugin on a browser (All though slow when connecting to them). On the android tv app it will not play. The wheel spins for a few seconds screen goes black and the player counts like -012 and so on but no video ever plays. Any idea what could cause that ? Edit : Now its not playing in the browser either. I am going to attach a video so u can see what it does on android tv https://streamable.com/1vnuv5 Mook Edited May 19, 2022 by Mookdog Update
pünktchen 1411 Posted May 19, 2022 Author Posted May 19, 2022 Sounds like session mismatch. Maybe a restart of Emby server will. help. Otherwise logs will tell us more.
Mookdog 90 Posted May 19, 2022 Posted May 19, 2022 @pünktchenHere a few logs I dont know exactly which one is which ffmpeg-VirtualTV1_20220519022315.txt ffmpeg-VirtualTV3_20220519005508.txt ffmpeg-VirtualTV0_20220519022804.txt ffmpeg-VirtualTV1_20220519022226.txt
pünktchen 1411 Posted May 19, 2022 Author Posted May 19, 2022 3 hours ago, Mookdog said: @pünktchenHere a few logs I dont know exactly which one is which Okay, you're obviously using Continous Playback. This seems to be working at the plugin side, at least for the concatenated ts file. Can you try to play one of those ts files in the transcoding temp folder with VLC at the time you start playback in Emby? I also need the server log for further assistance.
Mookdog 90 Posted May 20, 2022 Posted May 20, 2022 7 hours ago, pünktchen said: Okay, you're obviously using Continous Playback. This seems to be working at the plugin side, at least for the concatenated ts file. Can you try to play one of those ts files in the transcoding temp folder with VLC at the time you start playback in Emby? I also need the server log for further assistance. Hey I played the channel on my shield then went to my transcoding folder on my pc and played it with vlc and it came up with a black screen and thats it I will attach server log now Thanks Mook embyserver.txt
pünktchen 1411 Posted May 20, 2022 Author Posted May 20, 2022 5 hours ago, Mookdog said: Hey I played the channel on my shield then went to my transcoding folder on my pc and played it with vlc and it came up with a black screen and thats it I'm really confused now. The previous "ffmpeg-VirtualTVx_xxxxxxxxxxxx.txt" log files will only be created with "Continous Playback" mode. Now in your server log i see you are using "Playlist Playback" mode. That works completely different and it is normal that "VirtualTVIntro.ts" from the transcoding temp folder will show just a black video. In your server log are two playback attempts: One was in Chrome and that one was working as far as i can see it from the log file. The other one was in the AndroidTV app and yes i see an error that resulted from a missing ts segment. The ts segments are generated by ffmpeg if the app cannot direct play the "VirtualTVIntro.ts" file. The question is why was the the ts segment missing? Is there any "ffmpeg-directstream-4a6f8e01" log?
Mookdog 90 Posted May 20, 2022 Posted May 20, 2022 2 hours ago, pünktchen said: I'm really confused now. The previous "ffmpeg-VirtualTVx_xxxxxxxxxxxx.txt" log files will only be created with "Continous Playback" mode. Now in your server log i see you are using "Playlist Playback" mode. That works completely different and it is normal that "VirtualTVIntro.ts" from the transcoding temp folder will show just a black video. In your server log are two playback attempts: One was in Chrome and that one was working as far as i can see it from the log file. The other one was in the AndroidTV app and yes i see an error that resulted from a missing ts segment. The ts segments are generated by ffmpeg if the app cannot direct play the "VirtualTVIntro.ts" file. The question is why was the the ts segment missing? Is there any "ffmpeg-directstream-4a6f8e01" log? Here ya go Mook ffmpeg-directstream-4a6f8e01-483c-4890-8cea-50f031fec924_1.txt
pünktchen 1411 Posted May 20, 2022 Author Posted May 20, 2022 That looks okay to me, but i'm not the expert. Maybe @softworkz can have a look at the ffmpeg and server log from the previous posts. Btw. does the problem start exactly with the server update or after some time? Does the problem occur always now or only sometimes?
Mookdog 90 Posted May 20, 2022 Posted May 20, 2022 1 hour ago, pünktchen said: That looks okay to me, but i'm not the expert. Maybe @softworkz can have a look at the ffmpeg and server log from the previous posts. Btw. does the problem start exactly with the server update or after some time? Does the problem occur always now or only sometimes? Happens all the time I really cant tell if the server update did it or what. I know on previous stable it worked fine Mook
pünktchen 1411 Posted May 21, 2022 Author Posted May 21, 2022 Does it make a difference if you activate direct play live tv in the app settings?
softworkz 5133 Posted May 21, 2022 Posted May 21, 2022 10 hours ago, pünktchen said: That looks okay to me, but i'm not the expert. Maybe @softworkz can have a look at the ffmpeg and server log from the previous posts. Btw. does the problem start exactly with the server update or after some time? Does the problem occur always now or only sometimes? You should look into the server log. There are a number of errors like System.ArgumentException: System.ArgumentException: Invalid segment index requested: 9 - Segment count: 0 There have been some changes to the segment service, so maybe that's related.
Jdturos 0 Posted May 21, 2022 Posted May 21, 2022 My Virtual Tv box was working fine for minths and suddenly the channels disappeared I am a premium Emby member can you please help plug-in is still installed
Spaceboy 2573 Posted May 21, 2022 Posted May 21, 2022 1 hour ago, Jdturos said: My Virtual Tv box was working fine for minths and suddenly the channels disappeared I am a premium Emby member can you please help plug-in is still installed a new plugin was required for server versions 4.7+. have you manually installed that? 1
pünktchen 1411 Posted May 21, 2022 Author Posted May 21, 2022 8 hours ago, softworkz said: You should look into the server log. There are a number of errors like System.ArgumentException: System.ArgumentException: Invalid segment index requested: 9 - Segment count: 0 I saw it in the server log, that's why i requested the ffmpeg log after this. But that looks okay to me.
