Luke 42255 Posted March 16, 2022 Posted March 16, 2022 10 minutes ago, pünktchen said: @Luke have you already removed the old live tv api in the latest beta server? Yes, but I'm available to give you whatever help you need.
pünktchen 1411 Posted March 16, 2022 Author Posted March 16, 2022 1 minute ago, Luke said: Yes, but I'm available to give you whatever help you need. Hah, you can't give me enough time (anymore)! 1
roaku 842 Posted March 26, 2022 Posted March 26, 2022 I'm really enjoying this plugin, but am having an issue with excluding seasons by tag. I'm trying to use this functionality to prevent TV Show Specials from appearing in a particular channel. As an example, I have The Office Specials Season tagged with 'vtv-skip': I have the 'Workplace Comedy' channel configured to always exclude the 'vtv-skip' tag: But no matter how many guide refreshes I go through, I always end up with episodes from the 'Specials' Season in the channel: Am I misunderstanding or misconfiguring something?
GrimReaper 4912 Posted March 26, 2022 Posted March 26, 2022 1 minute ago, roaku said: I'm really enjoying this plugin, but am having an issue with excluding seasons by tag. I'm trying to use this functionality to prevent TV Show Specials from appearing in a particular channel. As an example, I have The Office Specials Season tagged with 'vtv-skip': I have the 'Workplace Comedy' channel configured to always exclude the 'vtv-skip' tag: But no matter how many guide refreshes I go through, I always end up with episodes from the 'Specials' Season in the channel: Am I misunderstanding or misconfiguring something? You need to enter "!vtv-skip" in "Tags:" field a bit lower down. 1
roaku 842 Posted March 26, 2022 Posted March 26, 2022 22 minutes ago, GrimReaper said: You need to enter "!vtv-skip" in "Tags:" field a bit lower down. Thanks, that seemed to do it. 1
Mookdog 90 Posted March 27, 2022 Posted March 27, 2022 On 3/16/2022 at 6:19 PM, pünktchen said: Hah, you can't give me enough time (anymore)! Any word on an update ? I would switch back to the previous one that worked but I like beta testing lol Mook
crusher11 1150 Posted April 15, 2022 Posted April 15, 2022 So this plugin is dead as of the latest beta? 1
BrianSDX2 3 Posted April 16, 2022 Posted April 16, 2022 I also can no longer see my virtualtv channels on 4.7.0.35. They are completely gone. 1
pünktchen 1411 Posted April 16, 2022 Author Posted April 16, 2022 On 4/15/2022 at 8:57 AM, crusher11 said: So this plugin is dead as of the latest beta? The plugin is not dead! It's just dysfunctional in the last betas. 1
mike3821 67 Posted April 17, 2022 Posted April 17, 2022 Hoping to get this working again. I have no choice but to run the beta.
crusher11 1150 Posted April 17, 2022 Posted April 17, 2022 7 hours ago, pünktchen said: The plugin is not dead! It's just dysfunctional in the last betas. "Dead" as in "completely not working" rather than "no longer in development". I have no "live TV" library at all now.
nagetech 70 Posted April 17, 2022 Posted April 17, 2022 I’m sure the developer will get it ironed out. They know how much we love this plugin! just gotta be patient 1
horstepipe 423 Posted April 21, 2022 Posted April 21, 2022 hello I'm just stumbling about this plugin. I'm wondering, can I set this up in addition to my current live tv setup (using m3u) and will the plugin channels show in a seperate group?
Dez_Lamar 10 Posted April 21, 2022 Posted April 21, 2022 32 minutes ago, horstepipe said: hello I'm just stumbling about this plugin. I'm wondering, can I set this up in addition to my current live tv setup (using m3u) and will the plugin channels show in a seperate group? No, it'll be mix together, the server will see the virtualTv as if they were regular channels 1
horstepipe 423 Posted April 21, 2022 Posted April 21, 2022 1 minute ago, TallBoiDez said: No, it'll be mix together, the server will see the virtualTv as if they were regular channels cool, thanks. Now I'm also waiting for a beta fix 1
crusher11 1150 Posted April 27, 2022 Posted April 27, 2022 So what exactly is the status of this at this point?
roaku 842 Posted April 27, 2022 Posted April 27, 2022 14 minutes ago, crusher11 said: So what exactly is the status of this at this point? 4.7 changes a bunch of core Emby services/interfaces/etc. this plugin depends on, so the plugin developer is working as fast as they can to rewrite significant elements of the plugin to accommodate the not particularly documented changes. You can follow the progress on the Developer API forum: 1
crusher11 1150 Posted April 27, 2022 Posted April 27, 2022 I know the big picture, I'm just thinking in terms of timeframes...are we talking weeks? Months? Be nice to have some sort of idea of where the patching-up is at.
roaku 842 Posted April 27, 2022 Posted April 27, 2022 I was hoping my post would add some perspective on expectations versus appreciation for the extensive updates to this free plugin for an Emby release that doesn't exist yet.
crusher11 1150 Posted April 27, 2022 Posted April 27, 2022 I don't have expectations, I'd just like to acquire some. Getting them from the plugin dev is a better way of doing so than just making ones up. 2
crusher11 1150 Posted April 27, 2022 Posted April 27, 2022 *sigh* I'm not making demands, or anything like that. Just asking if there's anything approaching a ballpark idea of where we're at. I have no clue what's going on under the hood so anything from "it should be ready in a week" through "it might take a year or two" all the way up to "it won't ever happen" is entirely plausible, and I'm just asking if that range can be narrowed at all.
Carlo 4561 Posted April 27, 2022 Posted April 27, 2022 I'm sure it's sooner than later but this plugin currently works fine on release software correct? It's only the beta server that causes the problem right? If so you have a solution. Beta's come with risk that they can break or change functionality of 3rd party software that will require some things to be reworked.
pünktchen 1411 Posted April 28, 2022 Author Posted April 28, 2022 New version 1.1.2 in the starting post: Playback: Fixed watch state for consecutive items in Playlist mode Added Playlist (Archive) playback mode to always start shows at the beginning General: Added compatibility version for Emby 4.7.x 11
Mookdog 90 Posted April 28, 2022 Posted April 28, 2022 1 hour ago, pünktchen said: New version 1.1.2 in the starting post: Playback: Fixed watch state for consecutive items in Playlist mode Added Playlist (Archive) playback mode to always start shows at the beginning General: Added compatibility version for Emby 4.7.x Working great on latest beta. Thanks so much for the update. I can die a happy man now lol Mook 1
Carlo 4561 Posted April 28, 2022 Posted April 28, 2022 11 hours ago, cayars said: I'm sure it's sooner than later but this plugin currently works fine on release software correct? 4 hours ago, pünktchen said: New version 1.1.2 in the starting post: That was definitely sooner then later! Thanks pünktchen
