pünktchen 1411 Posted January 9, 2020 Author Posted January 9, 2020 @@pünktchen Any chance of expanding the amount of channels to 20? I would try series, but I have too much genres in movies that reserve all of the 10 current ones :D You will get this tonight. @@pünktchen And did you get any feedback by Luke for a better integration with ffmpeg/Emby stream options?We've already discussed what's the best solution, but if or when this will be integrated he didn't mentioned. 4
WilhelmStroker 107 Posted January 9, 2020 Posted January 9, 2020 Awesome, will test and let you know.
pünktchen 1411 Posted January 10, 2020 Author Posted January 10, 2020 New version 0.6.2 in the starting post: Increased channels to twenty. Unfortunately this breaks your existing plugin configuration and you'll have to start from scratch. I'm really sorry for this! Fixed some serious time calculation mistakes for the "AutoMarkWatched" function and made it configurable by percent. Hopefully fixed the exception at playback start that some of you reported. (@@CBers @@WilhelmStroker @@hstamas) 4
WilhelmStroker 107 Posted January 10, 2020 Posted January 10, 2020 So far so good! All my channels seem to start properly now. Will do some more testing to make sure everything is working as expected.
sh0rty 728 Posted January 11, 2020 Posted January 11, 2020 From channel 11 on I am not able to assign the channel logo inside the Plugin settings @@pünktchen
CBers 7557 Posted January 11, 2020 Posted January 11, 2020 New version 0.6.2 in the starting post: Increased channels to twenty. Unfortunately this breaks your existing plugin configuration and you'll have to start from scratch. I'm really sorry for this! Fixed some serious time calculation mistakes for the "AutoMarkWatched" function and made it configurable by percent. Hopefully fixed the exception at playback start that some of you reported. (@@CBers @@WilhelmStroker @@hstamas) Still getting my 2 channels transcoding, even though the same items Direct Play outside of VirtualTV. Has there been any feedback from @@Luke or @@ebr as why this is happening? Surely Emby can work out that the source is local, direct from disk and not external.
pünktchen 1411 Posted January 11, 2020 Author Posted January 11, 2020 From channel 11 on I am not able to assign the channel logo inside the Plugin settings @@pünktchenI see, you mean the file picker button. You can still type the path and it gets saved. 1
pünktchen 1411 Posted January 11, 2020 Author Posted January 11, 2020 Still getting my 2 channels transcoding, even though the same items Direct Play outside of VirtualTV. Has there been any feedback from @@Luke or @@ebr as why this is happening? Surely Emby can work out that the source is local, direct from disk and not external. In "single playback" mode? Are you sure it's transcoding or is it a remux? Can you post the media info for one item where this happens? From Emby side of things the live tv engine doesn't know there's actually a local file behind the channel stream. I have to use a direct stream with video and audio copy by ffmpeg because currently it's the only way to seek to the start position.
CBers 7557 Posted January 11, 2020 Posted January 11, 2020 In "single playback" mode? Are you sure it's transcoding or is it a remux? Can you post the media info for one item where this happens? From Emby side of things the live tv engine doesn't know there's actually a local file behind the channel stream. I have to use a direct stream with video and audio copy by ffmpeg because currently it's the only way to seek to the start position. Yes, single playback mode. The Android TV (ATV) app says Trans/I. The same video Direct Plays in normal Emby, so it's something that either the plugin, or Emby's Live TV routines is mis-playing. If you're using ffmpeg to get to the correct start position, then that's probably it. Not telling you how to code, as I have no idea, but can't you use the resume function code, as that must be doing the same thing?
pünktchen 1411 Posted January 11, 2020 Author Posted January 11, 2020 Not telling you how to code, as I have no idea, but can't you use the resume function code, as that must be doing the same thing?No this is just not possible. For resume the player has to send multiple http range requests to the server to get the media type, codecs, runtime and finally the start position. Even i would do this in my plugin, it will be lost when the result is hand over to the live tv engine. Only a real media player can interpret the results of the range request. Btw. it's always direct playing with Emby Theater.
pünktchen 1411 Posted January 11, 2020 Author Posted January 11, 2020 Okay @@CBers it seems the Android apps only allow .ts as a container for live tv streams. How silly is that [emoji2955] You can also see this in your log folder: The direct stream log is generated by the plugin. Then follows a remux log because the app requests a container swap. Finally you get a transcoding log because the app can't play the remuxed stream. Interestingly it works without transcoding when the plugin already initiates the container swap [emoji54] I will make an option for this. 3
pünktchen 1411 Posted January 11, 2020 Author Posted January 11, 2020 Okay @@CBers the new option won't help you with the Android TV app. As i've found out it only helps with the Mobile app. The big problem seems to be the audio track codec. Somehow the Android TV app/Exoplayer doesn't like codecs other than AC3 for the live tv stream. I have a Shield and an audio system that can play everything up to True-HD Atmos and DTS-X. With movies from my library there's never a problem, but with live tv stream from my plugin that has a DTS audio track it's like this in the Android TV app: The player starts with direct playback for the video track and local downmix for the audio track (i can see this for one second in the stats for nerds). This doesn't work, so the app requests a direct stream where only the audio is transcoded (remux log). This still doesn't work, so the app requests a full transcode. Then playback is successfull. I will give you the option for a ts stream, but it's up to you and the other guys to solve the audio problem with ebr. 2
CBers 7557 Posted January 12, 2020 Posted January 12, 2020 I will give you the option for a ts stream, but it's up to you and the other guys to solve the audio problem with ebr. Thanks. Is @@ebr aware of this issue do you know? Perhaps he can code something to cater for it.
sh0rty 728 Posted January 12, 2020 Posted January 12, 2020 (edited) So much people over at Plex and other Media solutions are screaming for a PseudoTV like solution. And here it is, @@pünktchen created a unique selling point that totally separates Emby from other solutions. Everyone now can enjoy TV, even you have no cable card. To be honest, this is exactly a plugin I would have expected by the Emby Team as an optional core part of Emby. Edited January 12, 2020 by shorty1483 3
Spaceboy 2573 Posted January 12, 2020 Posted January 12, 2020 0.6.2 seems to work ok for me but actually crashes embyserver.exe at the end of every completed show. this is on latest stable just using one channel made up of one show picked by tag 1
pünktchen 1411 Posted January 12, 2020 Author Posted January 12, 2020 0.6.2 seems to work ok for me but actually crashes embyserver.exe at the end of every completed show. this is on latest stable just using one channel made up of one show picked by tagContinious playback on or off?
sh0rty 728 Posted January 12, 2020 Posted January 12, 2020 Continious playback on or off?Me too on a fast run yesterday in Browser. No continous Playback.
Spaceboy 2573 Posted January 12, 2020 Posted January 12, 2020 (edited) Continious playback on or off?off Out now but I’ll get you some logs later. I did take a look and there seemed to be no indication of any issue. Edited January 12, 2020 by Spaceboy
WilhelmStroker 107 Posted January 12, 2020 Posted January 12, 2020 (edited) Similar issue here. Continuous playback turned off and it doesn't look like the process crashes but my server becomes unresponsive and I need to restart it after an episode finishes. Will do some more testing and check the logs later. Edited January 12, 2020 by WilhelmStroker
pünktchen 1411 Posted January 12, 2020 Author Posted January 12, 2020 It's the "AutoMarkWatched" function Please set it to 0 until i find the root cause. 2
pünktchen 1411 Posted January 13, 2020 Author Posted January 13, 2020 (edited) New version 0.6.4 in the starting post: Fixed "Watched Only" condition for tv shows. @@hstamas Fixed http response header for the export web api. (necessary for Kodi Simple PVR addon) Fixed Emby crash by "AutoMarkWatched". @@Spaceboy @@shorty1483 @@WilhelmStroker Added option to force ts container in single playback mode. @@CBers Edited January 13, 2020 by pünktchen 2
hstamas 179 Posted January 13, 2020 Posted January 13, 2020 New version 0.6.4 in the starting post: Fixed "Watched Only" condition for tv shows. @@hstamas Confirmed that the issue with programs from different media locations not populating the guide if "watched only" was selected is fixed. Thanks punktchen!
CBers 7557 Posted January 13, 2020 Posted January 13, 2020 New version 0.6.4 in the starting post: Added option to force ts container in single playback mode. @@CBers Does this option have to be on for all platforms ? I ask, as I am having issue just playing the content remotely in Chrome. I will try with my Shield/ATV app later when I get home from work.
pünktchen 1411 Posted January 13, 2020 Author Posted January 13, 2020 Does this option have to be on for all platforms ? I ask, as I am having issue just playing the content remotely in Chrome. I will try with my Shield/ATV app later when I get home from work. You are asking questions. How should i know? I don't have all platform devices. I do not even use any of the official apps for watching live tv. I can say it has to be on for the Android Mobile app. For Android TV it depends somehow on the app setting "Direct stream live tv" if you get sound or not. 1
