VicMoore 755 Posted February 22, 2021 Posted February 22, 2021 I would like to reset and clear all of my channels and start fresh. How can I do this? My configuration is emby running on a synology NAS. This is a great plugin... Vic
pünktchen 1411 Posted February 22, 2021 Author Posted February 22, 2021 Remove the dll and xml from the plugin folder, restart Emby and run the guide refresh task.
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 Punktchen, I can't find the XML file in the plugin directory. What is it's name? I am running emby on a synology NAS. I don't know if that makes a difference. I removed the old DLL, restarted Emby, refreshed the Live TV Guide, copied the new Virtual TV DLL (version 0.9.6) to the plugin dir and then restarted Emby again and refreshed the TV guide again. Now nothing works. I can use the virtual TV plugin to create channels but noting populates the TV guide. I tried using tags, movie names, and emby libraries. None worked. The problem might be in the XML file that I could not find and delete. Please don't take any of my comments as complaints. You are doing a fantastic job. Vic
pünktchen 1411 Posted February 23, 2021 Author Posted February 23, 2021 There should be a subfolder "configurations" in the plugin folder.
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 Punktchen, I found the xml file. I will delete it and try everything over again. Vic
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 Deleting the XML file helped. But I can't filter a channel with either tags or by giving movie or TV show names (the associated emby libraries are checked). I am using the 0.9.6 plugin. I can populate the directory for a channel if I select an emby library and don't add any other filtering. I hope this helps explain my problem. I know you are working hard on this plugin and I appreciate your time. Vic
pünktchen 1411 Posted February 23, 2021 Author Posted February 23, 2021 9 minutes ago, VicMoore said: But I can't filter a channel with either tags or by giving movie or TV show names Your input is not saved or you don't get any result with your entered input?
pünktchen 1411 Posted February 23, 2021 Author Posted February 23, 2021 You can also pm me your log file.
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 When I filter with a tag or a filename, nothing gets displayed in the TV Guide. If I just select one of the Emby libraries, the TV guide gets populated. For example, I have an Emby library with various TV shows. Each is in a separate folder, such as "good witch" and "Matlock." All are in one library called TV Shows. In your plugin if I select the library "TV Shows" and do no further filtering, such as giving a tag name or a file name, then the TV Guide gets populated properly with all of the shows in the directory. In this case it would include both "Good Witch" and "Matlock" episodes. If I tag the Good Which directory using the meta data tool, and use that tag to select from "TV Shows" only the Good Witch episodes then nothing appears in the TV Guide. With earlier versions of your plugin the tags worked perfectly. That's how I organized content for each channel. Vic
GrimReaper 4910 Posted February 23, 2021 Posted February 23, 2021 4 hours ago, VicMoore said: When I filter with a tag or a filename, nothing gets displayed in the TV Guide. If I just select one of the Emby libraries, the TV guide gets populated. For example, I have an Emby library with various TV shows. Each is in a separate folder, such as "good witch" and "Matlock." All are in one library called TV Shows. In your plugin if I select the library "TV Shows" and do no further filtering, such as giving a tag name or a file name, then the TV Guide gets populated properly with all of the shows in the directory. In this case it would include both "Good Witch" and "Matlock" episodes. If I tag the Good Which directory using the meta data tool, and use that tag to select from "TV Shows" only the Good Witch episodes then nothing appears in the TV Guide. With earlier versions of your plugin the tags worked perfectly. That's how I organized content for each channel. Vic Which sever version are you running? I can confirm it works with both Include Name rule and Tags rule on 0.9.6/4.5.4.0 stable.
GrimReaper 4910 Posted February 23, 2021 Posted February 23, 2021 3 hours ago, VicMoore said: I am using version 4.5.4 Vic Then I suppose your rules are not being met at some point. Log might give some insight there. As would your setup screenshot.
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 Attached are pictures of the setup. Now I will create a debug log
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 Attached is the log. I don't know if I did it right or not. I enabled debug logging in the plugin and then refreshed the TV Guide. Vic embyserver.txt
GrimReaper 4910 Posted February 23, 2021 Posted February 23, 2021 3 hours ago, VicMoore said: Attached is the log. I don't know if I did it right or not. I enabled debug logging in the plugin and then refreshed the TV Guide. Vic embyserver.txt 1.03 MB · 0 downloads 2021-02-23 01:15:45.490 Info VirtualTV Plugin: GetLibraryItems > No Episode Items match the Channel Conditions 2021-02-23 01:15:45.490 Info VirtualTV Plugin: GetPrograms > Channel: Good Witch, ChannelId: VirtualTV0, Returning 0 TVShows How did you tag your show? And is it located at TV2 folder?
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 Below is a snapshot from the metadata editor
GrimReaper 4910 Posted February 23, 2021 Posted February 23, 2021 3 hours ago, VicMoore said: Below is a snapshot from the metadata editor Well, it might've just as well be that that syntax is causing some issues, as I've also had 0 returns when tagging with 'GoodWitch'. Could you try assigning another tag to that TV show, let's say 'Test', and use that as an argument in channel Tags field, Save, Refresh Guide?
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 I changed the tag to 'test' and it now works. 1
GrimReaper 4910 Posted February 23, 2021 Posted February 23, 2021 2 hours ago, VicMoore said: I changed the tag to 'test' and it now works. Great. Just keep it simple for now, until @pünktchen takes a look at it.
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 will do... thanks for the help. I live in Florida and it's 2AM in the morning. Time to stop programming and go to bed. Vic
GrimReaper 4910 Posted February 23, 2021 Posted February 23, 2021 4 hours ago, GrimReaper76 said: Well, it might've just as well be that that syntax is causing some issues, as I've also had 0 returns when tagging with 'GoodWitch'. Could you try assigning another tag to that TV show, let's say 'Test', and use that as an argument in channel Tags field, Save, Refresh Guide? Further testing, upon reapplying 'GoodWitch' tag and using 'goodwitch' Tags field argument - it worked. As it worked upon changing condition back to 'GoodWitch'. And also when tagging another Show with 'GoodWitch', it got included properly. Strange.
pünktchen 1411 Posted February 23, 2021 Author Posted February 23, 2021 @VicMoore the tag name already points out where the problem is. It's the "Witch" Honestly, i don't know. Let's wait if more user now have problem with tags. In the meantime i will create you an extra debugging build around the tags and also because you get an error when the config screen tries to get your library folders. 1
VicMoore 755 Posted February 23, 2021 Posted February 23, 2021 Thanks Punkchen. I will install the build as soon as you get it ready. I will also build another channel to confirm everything is now working OK. Vic
