PuffyToesToo 348 Posted August 30, 2020 Posted August 30, 2020 When watching a channel with mixed resolutions, the channel keeps the resolution of the first video (apparently?). Is there any work around for this? Thanks!
pünktchen 1411 Posted August 30, 2020 Author Posted August 30, 2020 Disable resolution switching in the app 1
Dibbes 515 Posted August 30, 2020 Posted August 30, 2020 (edited) 6 hours ago, pünktchen said: Ah the test version. It has to be Drama && !Christmas so this should be correct then: Fantasy||Science Fiction && !Christmas or should this be Fantasy||Science Fiction||!Christmas Edited August 30, 2020 by Dibbes
PuffyToesToo 348 Posted August 30, 2020 Posted August 30, 2020 (edited) 10 hours ago, pünktchen said: Disable resolution switching in the app Thank you pünktchen, I'll give that a go. Would I find this in Emby itself or the plugin? Sorry to ask but I'm not familiar with this setting for some reason. Edited August 30, 2020 by PuffyToesToo
pünktchen 1411 Posted August 30, 2020 Author Posted August 30, 2020 5 hours ago, Dibbes said: so this should be correct then: Fantasy||Science Fiction && !Christmas or should this be Fantasy||Science Fiction||!Christmas (Fantasy || Science Fiction) && !Christmas 1
pünktchen 1411 Posted August 30, 2020 Author Posted August 30, 2020 53 minutes ago, PuffyToesToo said: Thank you pünktchen, I'll give that a go. Would I find this in Emby itself or the plugin? Sorry to ask but I'm not familiar with this setting for some reason. It's a client app playback setting. 1
Dibbes 515 Posted August 30, 2020 Posted August 30, 2020 19 minutes ago, pünktchen said: (Fantasy || Science Fiction) && !Christmas I retract my statement of a few days back that I understood the way of setting up genre filtering... sorry
Dibbes 515 Posted August 30, 2020 Posted August 30, 2020 Drama && !Christmas gives me an empty channel...
Psyborg 43 Posted August 30, 2020 Posted August 30, 2020 @pünktchen Would it be possible to add "Country" as another channel condition? I think this is the only criterion I really miss, besides the mentioned things that are are in the pipeline already.
PuffyToesToo 348 Posted August 31, 2020 Posted August 31, 2020 12 hours ago, pünktchen said: It's a client app playback setting. Thanks for the advice pünktchen, I'm guessing it's not an available setting on Roku as I haven't found anything remotely similar to that in its settings.
MischievousMet 0 Posted August 31, 2020 Posted August 31, 2020 Out of curiosity, would it be possible to have a separate scheduled task to create the M3U and XML instead of it being tied to the Refresh Guide Data schedule? It's no big deal if not.
pünktchen 1411 Posted August 31, 2020 Author Posted August 31, 2020 2 hours ago, MischievousMet said: Out of curiosity, would it be possible to have a separate scheduled task to create the M3U and XML instead of it being tied to the Refresh Guide Data schedule? It's no big deal if not. I don't understand. The export possibility is already a separate task, but of course you have to refresh the guide first or you won't get new data.
MischievousMet 0 Posted September 5, 2020 Posted September 5, 2020 On 8/31/2020 at 2:05 AM, pünktchen said: I don't understand. The export possibility is already a separate task, but of course you have to refresh the guide first or you won't get new data. The guide for my IPTV goes for 24 hours, but they do update it throughout the day. To have an up-to-date guide, I would like to refresh 2 times in a day. So I was curious if there was a way to separate the generation of the channels outside of the Guide Refresh so the custom channels don't get overwritten. Maybe giving the XML and M3U it's own selection under Scheduled Tasks and an option to disable the creation through a Guide Refresh. If not, it's no big deal. I can live without it. I was just something I'd see was a possibility. Build out custom channels for several days while still updating my guide a couple of times a day would just be the cherry on top.
pünktchen 1411 Posted September 5, 2020 Author Posted September 5, 2020 (edited) So basically you just want to "suspend" the creation of VirtualTV guide data within the guide refresh task. If you tell me how that "option" should look and work from the users standpoint, then maybe. Currently i have no idea what should trigger new guide data and what should prevent it. Edited September 5, 2020 by pünktchen
pünktchen 1411 Posted September 5, 2020 Author Posted September 5, 2020 Would a simple timer "Suspend creation of guide data for ... hours" fullfill your need?
MischievousMet 0 Posted September 5, 2020 Posted September 5, 2020 4 hours ago, pünktchen said: So basically you just want to "suspend" the creation of VirtualTV guide data within the guide refresh task. If you tell me how that "option" should look and work from the users standpoint, then maybe. Currently i have no idea what should trigger new guide data and what should prevent it. I guess what I'm wondering is if you could add the XML and M3U creation to Scheduled Tasks with an option to disable Refresh Guide channel creation? That's kind of what I was thinking. Those with an IPTV that gives 24 hours of XML data could update regularly during the day while keeping their custom channels unaffected.
pünktchen 1411 Posted September 5, 2020 Author Posted September 5, 2020 The xml is really only an export of the program data that is already in the database. I do not create the data in any way with the export task or api. I understand your problem, but obviously you do not understand what the export does. So what about my suggested option? Will this help?
MischievousMet 0 Posted September 6, 2020 Posted September 6, 2020 3 hours ago, pünktchen said: The xml is really only an export of the program data that is already in the database. I do not create the data in any way with the export task or api. I understand your problem, but obviously you do not understand what the export does. So what about my suggested option? Will this help? Ah, I did not know that. I think your solution would probably help.
pünktchen 1411 Posted September 6, 2020 Author Posted September 6, 2020 (edited) New version 0.8.5 in the starting post: General: fixed a bug with Emby user names that have special characters when getting user folders fixed an exception at Guide Refresh with empty bumpers folder create transcoding folder if missing Export web API: added option to convert lossless audio to AC3 (default on) added option to choose program image format (default thumb, otherwise poster) changed playback stop method that recognizes client disconnects while streaming Channels: support "Season" less folder structures for tv shows support of conditional logical operators for Genres and Tags condition cache database query results to speed up Guide Refresh times added global option to supend the creation of new program data while doing a Guide Refresh Playback: Moved global "Single Playback" option to channel specific option ...and a little bonus Sorry, for this version you have to delete any existing VirtualTV.xml configuration file! Edit: I had to remove the new version from the start post because of a very small but annoying bug. Will re-upload it within 24 hours. Edited September 7, 2020 by pünktchen 4
Dibbes 515 Posted September 7, 2020 Posted September 7, 2020 3 hours ago, pünktchen said: Done! and thirty channels!!! WoooHoooo!!!!
Inx192 0 Posted September 7, 2020 Posted September 7, 2020 (edited) Works perfect so far and the extra channels is a nice bonus, thank you! The only issue i am having which was there from before is in TV i have genres showing in channels they shouldn't do. I have cleaned up all genres and for example I still have some reality shows like 'Ax men' showing up in documentaries, i have checked over and over and 'Ax Men' has no trace of documentary in the metadata. I have also rebuilt everything from scratch a few time too. Adding !reality to the genre has fixed it though. Edit: I Just checked my Documentary Genre channel and it is showing 'An Idiot Abroad' and 'Outback Opal Hunters' on it and I cleaned them shows to have a genre only of 'Reality'. Edit Again: I have found my issue, it has nothing to do with the plugin. I cleaned the show metadata up so the show only has one genre of preference but the nfo of each video in that series has not been changed, I now need to work out how to clean each nfo file somehow. Edited September 7, 2020 by Inx192
jli 1 Posted September 7, 2020 Posted September 7, 2020 Thx punktchen, fixed that season folder issue. Works like a charm. Crazy quick guide updating too. Seriously wow and thank you!
MischievousMet 0 Posted September 7, 2020 Posted September 7, 2020 Just a quick question, but what are the options Single Playback and Continuous Playblack (both Archive and Live)?
