pünktchen 1411 Posted December 29, 2019 Author Posted December 29, 2019 I'm having the same issue as above, I get the channel to show but no program information or movies show up for it. I didn't convert from 3.5But you've only tried Emby stable?Or does it also work for you with beta, but not stable? Anything in the logs? @@Spaceboy
pünktchen 1411 Posted December 29, 2019 Author Posted December 29, 2019 Sorry mate,was busy updating ,all my APCs I checked with stream.mp4? and stream.mkv? and both are working on latest VLC. Are you sure you've tried it with the url from inside your ffmpeg error log above and not any working ffmpeg log?
sh0rty 728 Posted December 29, 2019 Posted December 29, 2019 Are you sure you've tried it with the url from inside your ffmpeg error log above and not any working ffmpeg log? Yes sir. I searched exactly this error log.
pünktchen 1411 Posted December 29, 2019 Author Posted December 29, 2019 Yes sir. I searched exactly this error log. Very strange! Sometimes ffmpeg likes your file and sometimes not. What should i do now
Dibbes 515 Posted December 29, 2019 Posted December 29, 2019 (edited) Hmmm... on beta server 4.4.0.4 the channels don't even show up. I get a timeline on the web client, but that's the only thing... EDIT2: After running the Scheduled tasks "Refresh Guide" manually twice, the "Export VirtualTV Channels & Program" completed successfully and the web-client started showing what needed to be shown EDIT: I just need to say that I absolutely love this idea and once it incorporates series (and maybe later on even music...??? ) this will most likely be my most used feature of Emby! Let me know how to buy you a beer or coffee or something... Edited December 29, 2019 by Dibbes 1
jachin99 88 Posted December 29, 2019 Posted December 29, 2019 But you've only tried Emby stable? Or does it also work for you with beta, but not stable? Anything in the logs? @@Spaceboy That's on Emby Stable.
pünktchen 1411 Posted December 29, 2019 Author Posted December 29, 2019 @@jachin99 @@Spaceboy @@Dibbes and all others that will follow, please pm me some logs and either screenshots of your channel configuration or the VirtualTV.xml file that is inside ...\plugins\configurations When you just say "it doesn't work" i cannot help you, because it works for @@shorty1483 and me with stable and beta. 1
Dibbes 515 Posted December 29, 2019 Posted December 29, 2019 (edited) @@jachin99 @@Spaceboy @@Dibbes and all others that will follow, please pm me some logs and either screenshots of your channel configuration or the VirtualTV.xml file that is inside ...\plugins\configurations When you just say "it doesn't work" i cannot help you, because it works for @@shorty1483 and me with stable and beta. Done... let me know if you need anything else Edited December 29, 2019 by Dibbes
Sammy 791 Posted December 30, 2019 Posted December 30, 2019 See what happens when you take a hiatus!? I'll need to read up on this one soon. THANKS! Sent from my SM-G960U1 using Tapatalk 1
moha03 1 Posted December 30, 2019 Posted December 30, 2019 Any errors in the logs? If not enable debug logging in Emby, do a guide refresh and pm the log. good morning, I uninstalled your addon to install the new version, but now I don't see it in the list of extensions anymore.
pünktchen 1411 Posted December 30, 2019 Author Posted December 30, 2019 good morning, I uninstalled your addon to install the new version, but now I don't see it in the list of extensions anymore. Have you copied over the new plugin version to your plugins folder and then restarted Emby? You will not find the plugin in the catalog yet.
moha03 1 Posted December 30, 2019 Posted December 30, 2019 Have you copied over the new plugin version to your plugins folder and then restarted Emby? You will not find the plugin in the catalog yet. yes I took the new version I copied it into the folder as you can see on the picture. the addon should appear between themes song and trailers like yesterday but I don't see it
Jdiesel 1439 Posted December 30, 2019 Posted December 30, 2019 I'm getting this error when I run the scheduled task 2019-12-30 13:06:15.219 Error TaskManager: Error *** Error Report *** Version: 4.4.0.3 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.19.56.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll Processor count: 12 Program data path: /config Application directory: /system System.Net.WebException: System.Net.WebException: The remote server returned an error: (500) Internal Server Error. at System.Net.HttpWebRequest.GetResponse() at System.Net.WebClient.GetWebResponse(WebRequest request) at System.Net.WebClient.DownloadBits(WebRequest request, Stream writeStream) at System.Net.WebClient.DownloadFile(Uri address, String fileName) at System.Net.WebClient.DownloadFile(String address, String fileName) at VirtualTV.Services.ExportVirtualTVTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: System.Net.Requests TargetSite: System.Net.WebResponse GetResponse()
pünktchen 1411 Posted December 30, 2019 Author Posted December 30, 2019 I'm getting this error when I run the scheduled task There should be one or two web request before the error in your log: Info HttpServer: HTTP GET http://127.0.0.1:8096/emby/VirtualTV/Channels?Pass=. UserAgent: Info HttpServer: HTTP GET http://127.0.0.1:8096/emby/VirtualTV/Guide?Pass=. UserAgent: Which one is failing for you?
moha03 1 Posted December 30, 2019 Posted December 30, 2019 Have you copied over the new plugin version to your plugins folder and then restarted Emby? You will not find the plugin in the catalog yet. no solution for me?
pünktchen 1411 Posted December 30, 2019 Author Posted December 30, 2019 no solution for me?Is there an error in your logs?
moha03 1 Posted December 30, 2019 Posted December 30, 2019 Is there an error in your logs? I don't know how to use the newspaper, but here it is. embyserver.txt
Jdiesel 1439 Posted December 30, 2019 Posted December 30, 2019 There should be one or two web request before the error in your log: Info HttpServer: HTTP GET http://127.0.0.1:8096/emby/VirtualTV/Channels?Pass=. UserAgent: Info HttpServer: HTTP GET http://127.0.0.1:8096/emby/VirtualTV/Guide?Pass=. UserAgent: Which one is failing for you? 2019-12-30 14:14:54.540 Info HttpServer: HTTP GET http://127.0.0.1:8096/emby/VirtualTV/Channels?Pass=. UserAgent: 2019-12-30 14:14:54.619 Info HttpServer: SocketException: http://127.0.0.1:8096/emby/VirtualTV/Channels?Pass= 2019-12-30 14:14:54.620 Info HttpServer: HTTP Response 500 to 127.0.0.1. Time: 80ms. http://127.0.0.1:8096/emby/VirtualTV/Channels?Pass= 2019-12-30 14:14:54.623 Error TaskManager: Error *** Error Report *** Version: 4.4.0.3 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.19.56.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll Processor count: 12 Program data path: /config Application directory: /system System.Net.WebException: System.Net.WebException: The remote server returned an error: (500) Internal Server Error. at System.Net.HttpWebRequest.GetResponse() at System.Net.WebClient.GetWebResponse(WebRequest request) at System.Net.WebClient.DownloadBits(WebRequest request, Stream writeStream) at System.Net.WebClient.DownloadFile(Uri address, String fileName) at System.Net.WebClient.DownloadFile(String address, String fileName) at VirtualTV.Services.ExportVirtualTVTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) Source: System.Net.Requests TargetSite: System.Net.WebResponse GetResponse()
pünktchen 1411 Posted December 30, 2019 Author Posted December 30, 2019 I don't know how to use the newspaper, but here it is. The dll isn't even loaded by Emby. Maybe it is blocked by Windows? Right click the ddl file and select properties, a unblock checkbox or button shoul be availiable which allows to resolve the problem.
moha03 1 Posted December 30, 2019 Posted December 30, 2019 The dll isn't even loaded by Emby. Maybe it is blocked by Windows? Right click the ddl file and select properties, a unblock checkbox or button shoul be availiable which allows to resolve the problem. I don't see what her options are talking to you, can you give me a capture.
pünktchen 1411 Posted December 30, 2019 Author Posted December 30, 2019 I don't see what her options are talking to you, can you give me a capture. Something like this:
jachin99 88 Posted December 30, 2019 Posted December 30, 2019 Which folder are you placing the file into?
