Achiwa 0 Posted March 7, 2025 Posted March 7, 2025 Is there a way I can turn my VirtualTV stations into M3U files to send to my friends IPTV style?
TariqK 6 Posted March 9, 2025 Posted March 9, 2025 Is it possible to add audio support for our own custom 'radio stations'? An Emby Dev said it might be easier to add support to this plugin rather than try make a new one as I did here:
bovaflux 0 Posted March 9, 2025 Posted March 9, 2025 I’d love to have support for audio channels so i could kind of build my own algorithmic playlists.
SHO NUT 2 Posted March 17, 2025 Posted March 17, 2025 I've just installed this plugin, but I'm stuck at the 'Include items from the selected Folder(s):' when setting up a channel. The list of available sources (Libraries) is not populating. I've selected a User, but their Libraries do not show up. The Api key has been entered into Playback Settings. I've tried changing the Channel Content Source, but none allow me to select any sources. I've restarted the Emby Server. I've cleared the browser cache. Thanks in advance.
yaksplat 69 Posted March 17, 2025 Posted March 17, 2025 Is there any way to disable the Premiere flag?
SHO NUT 2 Posted March 17, 2025 Posted March 17, 2025 (edited) 2 hours ago, SHO NUT said: I've just installed this plugin, but I'm stuck at the 'Include items from the selected Folder(s):' when setting up a channel. The list of available sources (Libraries) is not populating. I've selected a User, but their Libraries do not show up. The Api key has been entered into Playback Settings. I've tried changing the Channel Content Source, but none allow me to select any sources. I've restarted the Emby Server. I've cleared the browser cache. Thanks in advance. It turns out that selecting Collections instead of Rules will allow it to create a guide and everything seems to be working but I never had an opportunity to select the source Library nor did I need to specify a Collection. I also have the above issue of the Premiere label on a lot of shows. Edited March 17, 2025 by SHO NUT
Junglejim 385 Posted March 18, 2025 Posted March 18, 2025 12 hours ago, yaksplat said: Is there any way to disable the Premiere flag? Yep, select this doodad.. 2
royaltrash 1 Posted April 2, 2025 Posted April 2, 2025 VirtualTV was working fine, but I had to do a fresh install of Emby for reasons. But now I can't get playlist playback to work at all. Both continuous and native playback work fine. Using playlist playback I either get: -a playback error immediately after hitting play -a black screen where it hangs on the ts or mp4 intro video depending on which one I picked The only substantial changes from my previous install is non-default metadata and cache folders and the 0.43 beta server instead of 0.42. Did 0.43 break something? I've tried everything I can think of. I'll supply logs if needed.
royaltrash 1 Posted April 3, 2025 Posted April 3, 2025 14 hours ago, royaltrash said: VirtualTV was working fine, but I had to do a fresh install of Emby for reasons. But now I can't get playlist playback to work at all. Both continuous and native playback work fine. Using playlist playback I either get: -a playback error immediately after hitting play -a black screen where it hangs on the ts or mp4 intro video depending on which one I picked The only substantial changes from my previous install is non-default metadata and cache folders and the 0.43 beta server instead of 0.42. Did 0.43 break something? I've tried everything I can think of. I'll supply logs if needed. I don't see a way to edit, but just wanted to say 0.43 did break playlist playback. Works again after going back to 0.42.
pünktchen 1411 Posted April 3, 2025 Author Posted April 3, 2025 43 minutes ago, royaltrash said: I don't see a way to edit, but just wanted to say 0.43 did break playlist playback. Works again after going back to 0.42. Confirmed! But it's not something i can repair in the plugin. The used server function is just brocken. Will create a bug report.
pünktchen 1411 Posted April 3, 2025 Author Posted April 3, 2025 On 3/17/2025 at 7:06 PM, yaksplat said: Is there any way to disable the Premiere flag? On 3/18/2025 at 7:54 AM, Junglejim said: Yep, select this doodad.. There's also an option for this in the channel settings of the plugin: "Set Premiere and Repeat indicators for programs". 1
pünktchen 1411 Posted April 3, 2025 Author Posted April 3, 2025 On 3/17/2025 at 4:55 PM, SHO NUT said: I've just installed this plugin, but I'm stuck at the 'Include items from the selected Folder(s):' when setting up a channel. The list of available sources (Libraries) is not populating. I've selected a User, but their Libraries do not show up. I've tried changing the Channel Content Source, but none allow me to select any sources. On 3/17/2025 at 7:31 PM, SHO NUT said: It turns out that selecting Collections instead of Rules will allow it to create a guide and everything seems to be working but I never had an opportunity to select the source Library nor did I need to specify a Collection. This is not a normal behaviour. I would a need a debug log to get further insides.
pünktchen 1411 Posted April 3, 2025 Author Posted April 3, 2025 On 3/9/2025 at 1:32 AM, TariqK said: Is it possible to add audio support for our own custom 'radio stations'? On 3/9/2025 at 7:35 AM, bovaflux said: I’d love to have support for audio channels so i could kind of build my own algorithmic playlists. As you can see from my very long response time, that request will not happen anytime soon.
pünktchen 1411 Posted April 3, 2025 Author Posted April 3, 2025 On 3/7/2025 at 9:22 PM, Achiwa said: Is there a way I can turn my VirtualTV stations into M3U files to send to my friends IPTV style? Export Settings!
pünktchen 1411 Posted April 3, 2025 Author Posted April 3, 2025 @hdsuisseI'm really sorry for the very late response. Unfortunately i cannot reproduce your issue. If you are still interested, please use the attached version. Enable debug logging in Emby and the plugin, reproduce your problem and send me the log file. VirtualTV.2.1.7.1.zip
hdsuisse 14 Posted April 3, 2025 Posted April 3, 2025 (edited) Hi, no problem. In the meantime, I've moved my server from a Synology to a Ugreen. The behavior here is exactly the same. Continuous playback doesn't work, and the live playlist freezes when changing channels. Edited April 3, 2025 by GrimReaper Attachment removed
pünktchen 1411 Posted April 3, 2025 Author Posted April 3, 2025 @hdsuisseAt the time you've added an "Authentication Info" in the Export Settings of the plugin, you've had to enter some "App or Device Name". As a result a new device with that same name should have been created in Emby's dashboard under Devices. Did you delete that device from the device list? Also the user that you've selected in the "Authentication Info" dialog needs to have access to that device in the Access settings of his user profile.
hdsuisse 14 Posted April 4, 2025 Posted April 4, 2025 (edited) VirtualTV device is there and ok, acces to the device allowed and the device name is unique. Edited April 4, 2025 by hdsuisse
pünktchen 1411 Posted April 4, 2025 Author Posted April 4, 2025 5 hours ago, hdsuisse said: VirtualTV device is there and ok, acces to the device allowed and the device name is unique. And when you play a channel on your Enigma 2 receiver, can you see the channel is playing in Emby's dashboard?
pünktchen 1411 Posted April 5, 2025 Author Posted April 5, 2025 7 hours ago, hdsuisse said: yes But i do not see any playback attempts from your Enigma receiver in your log files! There are only multiple attempts with Chrome and "Playlist Playback" mode, which is brocken in current Beta server.
hdsuisse 14 Posted April 6, 2025 Posted April 6, 2025 ok, i repeat the test tomorrow and send a new log.
hdsuisse 14 Posted April 10, 2025 Posted April 10, 2025 (edited) hi pünktchen, i had time to make some test. with latest beta 4.9.0.44 and your VirtualTV.dll 2.1.7.1, its working bether, but still crashes from live TV. Edited April 10, 2025 by hdsuisse
