Tester 45 Posted February 16, 2025 Posted February 16, 2025 I can no longer watch my m3u hdhomerun playlist using SparkleTV. I am not sure what changed nor what is wrong, but I do know I can no longer play this playlist with VLC when in the past I could. I am able to watch channels directly in Emby, but not outside using the virtualTV generated playlist. EPG loads fine. Any suggestions as to what I can check out ? embyserver.txt channels.m3u
pünktchen 1411 Posted February 16, 2025 Author Posted February 16, 2025 6 hours ago, Tester said: I can no longer watch my m3u hdhomerun playlist using SparkleTV. I am not sure what changed nor what is wrong, but I do know I can no longer play this playlist with VLC when in the past I could. I am able to watch channels directly in Emby, but not outside using the virtualTV generated playlist. EPG loads fine. Any suggestions as to what I can check out ? There's no playback attempt in you log, so i don't know. 1
Tester 45 Posted February 16, 2025 Posted February 16, 2025 4 hours ago, pünktchen said: There's no playback attempt in you log, so i don't know. Gotcha, that's probably because I started with a new log and never tuned a channel. Attached is latest log, I first tuned directly from Emby and then from Sparkle using the attached m3u list. I am not entirely sure this is virtualtv related, but hoping maybe you can shed some light on this or give me a clue. Thanks for the quick response embyserver.txt
pünktchen 1411 Posted February 18, 2025 Author Posted February 18, 2025 @TesterI've uploaded a new version that should fix your problem. 1
Tester 45 Posted February 18, 2025 Posted February 18, 2025 2 hours ago, pünktchen said: @TesterI've uploaded a new version that should fix your problem. Now back to working perfectly, thanks so much for the quick fix !!
Dondoe 0 Posted February 19, 2025 Posted February 19, 2025 how can i get this plugin? I'm using emby on my synology ds918+ (native package) and can't find this plugin there (I have a feeling there should be more plugins in general) emby version is 4.8.10 and it says its up2date. am i missing something?
mickle026 653 Posted February 19, 2025 Posted February 19, 2025 (edited) 2 hours ago, Dondoe said: how can i get this plugin? I'm using emby on my synology ds918+ (native package) and can't find this plugin there (I have a feeling there should be more plugins in general) emby version is 4.8.10 and it says its up2date. am i missing something? Regarding there should be more..... Quite a few community plugins have to be put into the server plugin directory manually, after manually downloading them. Many are not in the catalogue. Edited February 19, 2025 by mickle026
pünktchen 1411 Posted February 20, 2025 Author Posted February 20, 2025 5 hours ago, Dondoe said: how can i get this plugin? I'm using emby on my synology ds918+ (native package) and can't find this plugin there (I have a feeling there should be more plugins in general) emby version is 4.8.10 and it says its up2date. am i missing something? It's under the Live TV category in the plugin catalog.
Dondoe 0 Posted February 20, 2025 Posted February 20, 2025 7 hours ago, pünktchen said: It's under the Live TV category in the plugin catalog. your right, it is i use the android app for server management most of the time and there most of the plugins don't show up in the catalog, for wathever reason. To confirm i've opened the gui with a webbrowser and they are all there. thx
Jator 13 Posted February 22, 2025 Posted February 22, 2025 Playing with this plugin and seem to be hitting a wall. I can see the channels I am creating in the plugin: But when I try and go to the channel in the guide, it's not showing up: Here's a few screenshots of the settings I have in the configuration page: Strangely nothing shows up in Save and Preview unless I populate a timeframe in the "newer than" field. Not sure if other fields have the same effect, I just happened to stubmle on that. I tried all teh various playback options, all had the same effect. I did see a channel one time in teh guide, but it didn't have any content and when I came back after checking the library content, it was gone (didn't get a picture of that). Also, in doing some reasearch, seems like I may need an API key to make this work? If so, I'm getting this error which I am assuming is not a good sign:
pünktchen 1411 Posted February 22, 2025 Author Posted February 22, 2025 3 hours ago, Jator said: Strangely nothing shows up in Save and Preview unless I populate a timeframe in the "newer than" field. Not sure if other fields have the same effect, I just happened to stubmle on that. This is intentional. At least one rule has to be evaluated to get any outcome. What prevents you to fill in anything for release date? 3 hours ago, Jator said: Also, in doing some reasearch, seems like I may need an API key to make this work? No. Only if you plan to use continuous playback.
Jator 13 Posted February 23, 2025 Posted February 23, 2025 The channels ultimately show up, but it's a couple of hours after I hit save, so not sure what I am doing wrong. For now, so long as they eventually show up, I'm good. Thanks.
hdsuisse 14 Posted February 23, 2025 Posted February 23, 2025 Hi, i try to play a Virtual Tv Stream with my Enigma2 SAT-Receiver. i ad this export the Channels to my channel list of the Receiver, like this #NAME Emby TV Daniel #SERVICE 4097:0:19:150:8:1:C00000:0:0:0:http%3a//IP%3a8096/emby/VirtualTV/2074177/stream.ts?StreamType=Universal&Timeout=3&Token=bfd07c6b55144aa09cxxxxx:Kino AKTUELL #DESCRIPTION Kino AKTUELL #SERVICE 4097:0:19:151:8:1:C00000:0:0:0:http%3a//IP%3a8096/emby/VirtualTV/2074178/stream.ts?StreamType=Universal&Timeout=3&Token=bfd07c6b55144aa09cxxxxx:Kino ACTION #DESCRIPTION Kino ACTION all Works ok, but sometimes when i zap between the channels, Emby Live-TV crash and no more playback of any channel is possible, only restarting Emby brings all back. i think ffmpeg transcoding is not answering anymore ffmpeg version 5.1-emby_2023_06_25_p2 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (crosstool-NG 1.25.0) Execution Date: 2025-02-23 14:22:40 [http @ 0x18d5d80] HTTP error 500 Internal Server Error [concat @ 0x18cadc0] Impossible to open 'http://127.0.0.1:8096/emby/Videos/8990/stream.ts?StartTimeTicks=45166687994&Copytimestamps=false&VideoCodec=h264&AudioCodec=ac3&AudioChannels=2&AudioBitRate=192000&AudioSampleRate=48000&AudioStreamIndex=1&MediaSourceId=mediasource_8990&PlaySessionId=119ea569e1544591901373094c8a9a2a&api_key=a0130536b5xxxxx' /volume1/Emby/transcoding-temp/VirtualTV-c2d045169dxxxxxx-20250223142240.txt: Server returned 5XX Server Error reply EXIT emby Server show this error 2025-02-23 14:34:08.642 Error App: Error sending socket message from 0.0.0.0:1900 to ip:49834 *** Error Report *** Version: 4.9.0.38 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect *** Error Report *** Version: 4.9.0.38 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #72806 SMP Thu Sep 5 13:44:44 CST 2024 OS/Process: x64/x64 Framework: .NET 8.0.11 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at VirtualTV.Services.EventService.EventService.<SessionEventSubscriber>b__0_1(Object s, PlaybackStopEventArgs e) at MediaBrowser.Common.Events.EventHelper.TriggerAll[T](EventHandler`1 mainHandler, Object sender, T args, ILogger logger) Source: VirtualTV TargetSite: Void <SessionEventSubscriber>b__0_1(System.Object, MediaBrowser.Controller.Library.PlaybackStopEventArgs) the crash with the Virtual Channels are not happened when i use the Android APP maybe you have a idea why LiveTV crashes with enigma2 Box Streaming in the attachments you see also my Virtual TV config thx VirtualTV.xml
pünktchen 1411 Posted February 23, 2025 Author Posted February 23, 2025 5 hours ago, Jator said: The channels ultimately show up, but it's a couple of hours after I hit save, so not sure what I am doing wrong. For now, so long as they eventually show up, I'm good. Thanks. You have to run the Refresh Guide task to populate your programs!
pünktchen 1411 Posted February 23, 2025 Author Posted February 23, 2025 5 hours ago, hdsuisse said: sometimes when i zap between the channels, Emby Live-TV crash and no more playback of any channel is possible, only restarting Emby brings all back. Does it only happen if you "zap" between the channels or also if you stop one before starting an other? 5 hours ago, hdsuisse said: the crash with the Virtual Channels are not happened when i use the Android APP Because you have set "Playlist" playback for your channels. But that only works with Emby apps, while the exported channels will always use "Continuous" playback.
hdsuisse 14 Posted February 24, 2025 Posted February 24, 2025 14 hours ago, pünktchen said: Does it only happen if you "zap" between the channels or also if you stop one before starting an other? it happens when i zap between VirtualTV Channels. With the enigma2 Receiver is no stop function, it is like broadcast Channel, zap from one to the other. 14 hours ago, pünktchen said: Because you have set "Playlist" playback for your channels. But that only works with Emby apps, while the exported channels will always use "Continuous" playback. with "Continuous" playback (Live) in the Channel Stettings, i have the same issue with the enigma2 Receiver plus the Android App can not play the Virtual Cnannels any more. curios
pünktchen 1411 Posted February 24, 2025 Author Posted February 24, 2025 2 hours ago, hdsuisse said: with "Continuous" playback (Live) in the Channel Stettings, i have the same issue with the enigma2 Receiver plus the Android App can not play the Virtual Cnannels any more. What's your Emby server version?
hdsuisse 14 Posted February 24, 2025 Posted February 24, 2025 Version: 4.9.0.38 Synology NAS DSM Version: 7.2.2-72806 Update 3, no Doker installation
hdsuisse 14 Posted February 24, 2025 Posted February 24, 2025 i think hardware transcoding is brocken, my Synolgy DSM720+ have QuickSync GeminiLake, but i try later with software transcodinc only and report.
hdsuisse 14 Posted February 24, 2025 Posted February 24, 2025 same behavior without hardware transcoding *** Error Report *** Version: 4.9.0.38 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology72_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #72806 SMP Thu Sep 5 13:44:44 CST 2024 OS/Process: x64/x64 Framework: .NET 8.0.11 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at VirtualTV.Services.EventService.EventService.<SessionEventSubscriber>b__0_1(Object s, PlaybackStopEventArgs e) at MediaBrowser.Common.Events.EventHelper.TriggerAll[T](EventHandler`1 mainHandler, Object sender, T args, ILogger logger) Source: VirtualTV TargetSite: Void <SessionEventSubscriber>b__0_1(System.Object, MediaBrowser.Controller.Library.PlaybackStopEventArgs) and the Emby LiveTV crashes
pünktchen 1411 Posted February 24, 2025 Author Posted February 24, 2025 2 hours ago, hdsuisse said: Version: 4.9.0.38 Synology NAS DSM Version: 7.2.2-72806 Update 3, no Doker installation I think @Testeris using Emby stable with the plugins export api, so it's probably a change in the beta version of Emby that leads to your problem. I'll try to find a fix.
Tester 45 Posted March 1, 2025 Posted March 1, 2025 On 2/24/2025 at 10:19 AM, pünktchen said: I think @Testeris using Emby stable with the plugins export api, so it's probably a change in the beta version of Emby that leads to your problem. I'll try to find a fix. Yes I am on stable 4.8.10.0
hdsuisse 14 Posted March 1, 2025 Posted March 1, 2025 (edited) i update to Version 4.9.0.40 beta today, same issues Transcoding for VirtualTV not working Live TV Crash when zap between Channels when Set Channels to Continuous Playback, the Channels are not playable anymore. Edited March 1, 2025 by hdsuisse
TariqK 6 Posted March 2, 2025 Posted March 2, 2025 (edited) Having a TV Channel with one specific show does not work by just using the 'include' filter, anyone else? Edited March 2, 2025 by TariqK
