pünktchen 1411 Posted March 20, 2024 Author Posted March 20, 2024 2 hours ago, crusher11 said: No, it listed the movie. But there's no Emby setting to play extras with the movie, is there? Do extras and movies share the same ItemId? You can check that youself in the adressbar of a browser.
crusher11 1147 Posted March 20, 2024 Posted March 20, 2024 39 minutes ago, pünktchen said: But there's no Emby setting to play extras with the movie, is there? Do extras and movies share the same ItemId? You can check that youself in the adressbar of a browser. Another movie with extras came on and it briefly started a "making of" before playing a theme.mp3, which may or may not be from the same movie but it's queued up a whole playlist of random things. embyserver (1).txt
pünktchen 1411 Posted March 20, 2024 Author Posted March 20, 2024 Do you have any experience with Emby's Rest API?
pünktchen 1411 Posted March 20, 2024 Author Posted March 20, 2024 @gihayes@crusher11For your reference, i've reported it as an Emby bug: 1
crusher11 1147 Posted March 20, 2024 Posted March 20, 2024 5 hours ago, pünktchen said: Do you have any experience with Emby's Rest API? Nope. Know nothing about APIs at all.
gihayes 47 Posted March 23, 2024 Posted March 23, 2024 On 3/20/2024 at 8:37 AM, pünktchen said: @gihayes@crusher11For your reference, i've reported it as an Emby bug: Thanks
jiggity 35 Posted March 24, 2024 Posted March 24, 2024 I really want to like this plug in but every time I use it I find enough that irks me to want to stop using it. Before the 4.8.* upgrade it was slow, way too slow to rebuild the guide, so i switched to ersatzTV and ran an external docker program just to build the guides and pipe that back to emby Luke convinced me to give the rebuild of virtualTV another try These are the issues that make me want to abandon it again: Playlists can only follow playlist order if they are set as mixed content in the channel setup; regardless of list type. Movie channels will trigger trailers from the cinematic plug in, and if you skip them, it does not go to the movie, but into the extras/featurettes folder of where the trailer was. If you keep skipping it will eventually come to the movie that was 'scheduled' but it will not play it as it was supposed to play it. TV shows will jump to the point the timing shows it is at, movies won't. Kinda defeats the purpose. I even tried disabling the cinematic plug in and that did not have any effect. Collections made with Seasons from TV shows will not show any items if a channel is made with that collection. Channels with resolution changes can often fail to load the next file when downgrading the resolution. Going from 4k to 1080 can result in the next file in the 'playlist' not loading through the channel, where a playlist works fine. This can result in some weird transcoding behaviour when you try and load a different channel. Even with tags music videos will not load I wish you luck with development
pünktchen 1411 Posted March 24, 2024 Author Posted March 24, 2024 1 hour ago, jiggity said: Before the 4.8.* upgrade it was slow, way too slow to rebuild the guide, so i switched to ersatzTV and ran an external docker program just to build the guides and pipe that back to emby One user of my plugin probably has the biggest library of all of the users here in the forum. As long as he doesn't complain, all is fine. It must be something on your side then. 1 hour ago, jiggity said: Playlists can only follow playlist order if they are set as mixed content in the channel setup; regardless of list type. Did you report this? No. 1 hour ago, jiggity said: Collections made with Seasons from TV shows will not show any items if a channel is made with that collection. Again. Did you report this? No. 1 hour ago, jiggity said: Even with tags music videos will not load. Did you ask for help? 1 hour ago, jiggity said: Movie channels will trigger trailers from the cinematic plug in, and if you skip them, it does not go to the movie, but into the extras/featurettes folder of where the trailer was. If you keep skipping it will eventually come to the movie that was 'scheduled' but it will not play it as it was supposed to play it. TV shows will jump to the point the timing shows it is at, movies won't. Kinda defeats the purpose. I even tried disabling the cinematic plug in and that did not have any effect. Sounds like the Emby bug that is discussed above your post. 1 hour ago, jiggity said: Channels with resolution changes can often fail to load the next file when downgrading the resolution. Going from 4k to 1080 can result in the next file in the 'playlist' not loading through the channel, where a playlist works fine. This can result in some weird transcoding behaviour when you try and load a different channel. Blame the Emby app or device that you are using for this issue. The plugin only provides a pointer to the content that has to be played. It does not stream or play it. 1 hour ago, jiggity said: I wish you luck with development Thank you. 1
gihayes 47 Posted April 1, 2024 Posted April 1, 2024 (edited) Hi pünktchen, I really like your plugin, and think it's great. It's easy to set up and use. Everything is working fine for me except bumpers. I have the bumper field pointing to M:\VTV1\Commercials, which is inside a Home Videos & Photos library named VTV1. The bumpers do not appear in the preview, or in the listing after I have saved and refreshed the guide. I have tried another library as a test and still no bumpers appear in the preview or guide. Everything else works perfectly! If I go to the Library VTV1, I am able to see the commercials I have there and they play fine. I looked through the log, but didn't know what I was looking for. My settings are as follows: Channel is Enabled No Export Caching Data (I've tried with Cache off also) No Premier or Repeat I have a Logo (Just Added) No Primetime Playback Method: Playlist (Live) 90 and 80 for watched percent times Bumpers are in M:\VTV1\Commercials inside the Library VTV1 which is a Home Videos & Photos library who's Root is M:\VTV1 Min/Max Videos 1/2 Min/Max Bumpers 1/2 Emby User VTV has access to all Libraries Channel Content Source: Playlist Channel Content: Movies Watched and Unwatched Playlist is VTVQuantumPhysics All my channels play fine, just no bumpers. Can you help? Debug was on for Emby and for the Channel Thanks embyserver.txt Edited April 1, 2024 by gihayes
gihayes 47 Posted April 1, 2024 Posted April 1, 2024 56 minutes ago, gihayes said: Hi pünktchen, I really like your plugin, and think it's great. It's easy to set up and use. Everything is working fine for me except bumpers. I have the bumper field pointing to M:\VTV1\Commercials, which is inside a Home Videos & Photos library named VTV1. The bumpers do not appear in the preview, or in the listing after I have saved and refreshed the guide. I have tried another library as a test and still no bumpers appear in the preview or guide. Everything else works perfectly! If I go to the Library VTV1, I am able to see the commercials I have there and they play fine. I looked through the log, but didn't know what I was looking for. My settings are as follows: Channel is Enabled No Export Caching Data (I've tried with Cache off also) No Premier or Repeat I have a Logo (Just Added) No Primetime Playback Method: Playlist (Live) 90 and 80 for watched percent times Bumpers are in M:\VTV1\Commercials inside the Library VTV1 which is a Home Videos & Photos library who's Root is M:\VTV1 Min/Max Videos 1/2 Min/Max Bumpers 1/2 Emby User VTV has access to all Libraries Channel Content Source: Playlist Channel Content: Movies Watched and Unwatched Playlist is VTVQuantumPhysics All my channels play fine, just no bumpers. Can you help? Debug was on for Emby and for the Channel Thanks embyserver.txt 1.39 MB · 0 downloads I decided to watch one of the channels I had created, and Lo and Behold, the commercials were playing. They don't appear in the Preview, or on the Timeline in the Guide, but when the channel is played, they are there. I'm happy. Thanks again for this plugin ünktchen!
pünktchen 1411 Posted April 1, 2024 Author Posted April 1, 2024 New version 2.0.3.0 in the plugin catalogue: Channels: Fixed missing Playlist sort order for Content Type Movies, TVShows and MusicVideos Added support for Seasons with Content Source Collections Export API: Improved xmltv compatibility The plugin should not auto update, so a manual download from the catalog is required. As usual, you should clear your browser cache before opening the plugin config page.
pünktchen 1411 Posted April 1, 2024 Author Posted April 1, 2024 @TesterThank you for your patience! I'm sorry it took so long. 1
Tester 45 Posted April 2, 2024 Posted April 2, 2024 1 hour ago, pünktchen said: @TesterThank you for your patience! I'm sorry it took so long. absolutely no need to apologize, I appreciate your efforts !! Anyway, I wrote a python script to update the xml each time it was generated while I waited for the new version.
hstamas 179 Posted April 19, 2024 Posted April 19, 2024 (edited) Revisiting VirtualTV after some time away. Using the latest Dev build on a M1 Mac. Even though I have all the appropriate items checked in the playback progress section my Continues Watching is littered with half watched shows if I do any sort of channel surfing during a viewing session. Anything I can provide to help pinpoint the issue just let me know. Also note that for some reason, when ever this happens (after I clean up all the Continue Watching shows) I will usually get 3 movies (always the same ones) in that list even though I dont use VirtualTV for movies. These movies are fully watched and have been for years but somehow are getting marked partially watched at this time so the above may be part of a larger watch state issue? Edited April 19, 2024 by hstamas
pünktchen 1411 Posted April 20, 2024 Author Posted April 20, 2024 On 4/19/2024 at 1:56 PM, hstamas said: Using the latest Dev build on a M1 Mac. Even though I have all the appropriate items checked in the playback progress section my Continues Watching is littered with half watched shows if I do any sort of channel surfing during a viewing session. Anything I can provide to help pinpoint the issue just let me know. Are there any errors related to VirtualTV in Emby's log file. Does the problem also happen with the web app? Which playback mode have you chosen in the plugin? On 4/19/2024 at 1:56 PM, hstamas said: Also note that for some reason, when ever this happens (after I clean up all the Continue Watching shows) I will usually get 3 movies (always the same ones) in that list even though I dont use VirtualTV for movies. These movies are fully watched and have been for years but somehow are getting marked partially watched at this time so the above may be part of a larger watch state issue? I don't think the plugin is doing this. When you look around the forum, you will always find different problems regarding Continou Watching.
Jekill 1 Posted April 21, 2024 Posted April 21, 2024 (edited) Does anyone have any idea why when I start a VirtualTV channel, it plays on all open tabs? Edited April 21, 2024 by Jekill
hstamas 179 Posted April 22, 2024 Posted April 22, 2024 On 4/20/2024 at 7:58 PM, pünktchen said: Are there any errors related to VirtualTV in Emby's log file. Does the problem also happen with the web app? Which playback mode have you chosen in the plugin? I don't think the plugin is doing this. When you look around the forum, you will always find different problems regarding Continou Watching. No errors that I can see in a weeks worth of logs. Web app doesnt seem to reproduce the issue but if I just let Emby sit for a few days watching nothing, all the partially watched shows that I cleared out of my Continue Watching come back. I am using Playlist (Live) mode.
pünktchen 1411 Posted April 22, 2024 Author Posted April 22, 2024 On 4/21/2024 at 4:28 PM, Jekill said: Does anyone have any idea why when I start a VirtualTV channel, it plays on all open tabs? That's because there's no distinction between multiple browser tabs - it counts as one device within one Emby session.
pünktchen 1411 Posted April 22, 2024 Author Posted April 22, 2024 1 hour ago, hstamas said: No errors that I can see in a weeks worth of logs. Web app doesnt seem to reproduce the issue Mmh, that's bad. Of course as a first step, you could enable debug logging in Emby and the plugin. Rotate the log file, just watch one single episode and send me the log file via pm. 1 hour ago, hstamas said: if I just let Emby sit for a few days watching nothing, all the partially watched shows that I cleared out of my Continue Watching come back. It comes back even if you don't watch something with VirtualTV?
Jekill 1 Posted April 22, 2024 Posted April 22, 2024 12 minutes ago, pünktchen said: That's because there's no distinction between multiple browser tabs - it counts as one device within one Emby session. And there's no way for this behavior not to happen?
pünktchen 1411 Posted April 22, 2024 Author Posted April 22, 2024 (edited) 13 minutes ago, Jekill said: And there's no way for this behavior not to happen? Not yet. At least not with one of the "Playlist" playback modes. The same thing will happen if you use the "Play to" feature in Emby on your smartphone to play something in a browser. Edited April 22, 2024 by pünktchen
pünktchen 1411 Posted April 22, 2024 Author Posted April 22, 2024 @hstamasAre you still using Emby For Kodi Next Gen?
hstamas 179 Posted April 23, 2024 Posted April 23, 2024 17 hours ago, pünktchen said: @hstamasAre you still using Emby For Kodi Next Gen? No - Ive moved away from that a long time ago. Just official apps now.
hstamas 179 Posted April 23, 2024 Posted April 23, 2024 17 hours ago, pünktchen said: Mmh, that's bad. Of course as a first step, you could enable debug logging in Emby and the plugin. Rotate the log file, just watch one single episode and send me the log file via pm. It comes back even if you don't watch something with VirtualTV? Yeah it all comes back. I only use Emby now to dabble as I have moved back to Plex for the time being. I keep checking in hopes that Emby will get the whole Apple TV thing straightened out. I just looked at my Continue Watching list after not touching Emby since before the weekend and all those partials are back including the 3-4 movies I mentioned.
