pünktchen 1411 Posted January 22, 2024 Author Posted January 22, 2024 35 minutes ago, Kyrunner said: 2.0.0.1 I'll upload a new version tonight. That should fix your problem. 1
pünktchen 1411 Posted January 22, 2024 Author Posted January 22, 2024 1 minute ago, Dibbes said: @KyrunnerPlay with these settings: They are broken in v2.0.0.1 on newer Emby Beta versions.
Kyrunner 86 Posted January 22, 2024 Posted January 22, 2024 3 minutes ago, Dibbes said: @KyrunnerPlay with these settings: Just changed my settings to the one in the screenshot but still shows up on continue watching
Dibbes 515 Posted January 22, 2024 Posted January 22, 2024 7 minutes ago, pünktchen said: They are broken in v2.0.0.1 on newer Emby Beta versions. Ahhhh... fair enough...
pünktchen 1411 Posted January 22, 2024 Author Posted January 22, 2024 (edited) New version 2.0.2.0 in the plugin catalogue: General: Unified Logging output Channels: Fixed some bugs around Program File Caching Fixed Playlist and Collection visibility in Add/Edit Channel dialog Changed order of some Channel Rules to clarify the logic behind Performance improvements to Guide Refresh Added Runtime Logging to Guide Refresh Added option to disable program indicators Premiere and Repeat Added preview to Add/Edit Channel dialog Playback: Fixed some exceptions in Session Events for Playback Progress Reporting Fixed Remove from Continuou Watching The plugin should not auto update, so a manual download from the catalog is required. As usual, you should clear your browser cache before opening the plugin config page. Edited January 23, 2024 by pünktchen 2
TZTZoro 26 Posted January 23, 2024 Posted January 23, 2024 @pünktcheni do not know the source or if i should post it for the emby team but i cant install it i get a pop up modal that it is succes and that i need to restart, a few toast messages one of them sais failure and then this
Dibbes 515 Posted January 23, 2024 Posted January 23, 2024 (edited) Yup, same here. Doesn't matter if it's a new install or an update, it will always fail. Downloading the file manually from the plugin store, rename manually and add it to Emby, seems to work however... VirtualTV.dll Edited January 23, 2024 by Dibbes
crusher11 1147 Posted January 23, 2024 Posted January 23, 2024 (edited) I haven't attempted the update (it doesn't even seem to be available) but mine doesn't appear to honor the "play watched only" setting. Edited January 23, 2024 by crusher11
pünktchen 1411 Posted January 23, 2024 Author Posted January 23, 2024 (edited) 12 hours ago, TZTZoro said: @pünktcheni do not know the source or if i should post it for the emby team but i cant install it i get a pop up modal that it is succes and that i need to restart, a few toast messages one of them sais failure and then this @TZTZoro@Dibbes@crusher11Can you please try it again. @LukeSomething is wrong with either the plugin catalog or the update mechanism in Emby. The previous plugin version in the catalog is 2.0.0.1. I've then uploaded a new version 2.0.1.0 to the catalog, but the installation of that plugin version is failing. I've rebuilded the assembly multiple times, tried different browsers for uploading to the catalog. The only thing that helped was changing the plugin version number to 2.0.2.0. It's like Emby could not differentiate between 2.0.0.1 and 2.0.1.0 It's also replicable. If i change the version number back to 2.0.1.0, the installation is failing again. 2024-01-23 16:33:38.243 Debug Server: http/1.1 GET http://localhost:8097/emby/Packages/VirtualTV?AssemblyGuid=DCCF87B2-B42D-4C1B-B237-69C30F288AEA&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 2024-01-23 16:33:38.243 Debug Server: http/1.1 GET http://localhost:8097/emby/Plugins?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 2024-01-23 16:33:38.244 Info HttpClient: POST https://www.mb3admin.com/admin/service/package/retrieveall?includeAllRuntimes=true 2024-01-23 16:33:38.244 Debug Server: http/1.1 Response 200 to ::1. Time: 1ms. GET http://localhost:8097/emby/Plugins?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de 2024-01-23 16:33:38.244 Debug Server: http/1.1 GET http://localhost:8097/emby/web/configurationpages?PageType=PluginConfiguration&UserId=fa980721e5df4a7a912eac013cc26a8b&EnableInMainMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 2024-01-23 16:33:38.245 Debug Server: http/1.1 Response 200 to ::1. Time: 1ms. GET http://localhost:8097/emby/web/configurationpages?PageType=PluginConfiguration&UserId=fa980721e5df4a7a912eac013cc26a8b&EnableInMainMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de 2024-01-23 16:33:38.247 Debug Server: http/1.1 Response 200 to ::1. Time: 6ms. GET http://localhost:8097/emby/Users/fa980721e5df4a7a912eac013cc26a8b/Views?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de 2024-01-23 16:33:38.263 Debug Server: http/1.1 GET http://localhost:8097/emby/web/configurationpages?PageType=PluginConfiguration&UserId=fa980721e5df4a7a912eac013cc26a8b&EnableInUserMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 2024-01-23 16:33:38.264 Debug Server: http/1.1 Response 200 to ::1. Time: 1ms. GET http://localhost:8097/emby/web/configurationpages?PageType=PluginConfiguration&UserId=fa980721e5df4a7a912eac013cc26a8b&EnableInUserMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de 2024-01-23 16:33:39.732 Debug Server: http/1.1 Response 200 to ::1. Time: 1490ms. GET http://localhost:8097/emby/Packages/VirtualTV?AssemblyGuid=DCCF87B2-B42D-4C1B-B237-69C30F288AEA&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de 2024-01-23 16:33:45.298 Debug Server: http/1.1 GET http://localhost:8097/emby/Plugins?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 2024-01-23 16:33:45.299 Debug Server: http/1.1 Response 200 to ::1. Time: 1ms. GET http://localhost:8097/emby/Plugins?X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de 2024-01-23 16:33:46.981 Info Server: http/1.1 POST http://localhost:8097/emby/Packages/Installed/VirtualTV?updateClass=Dev&AssemblyGuid=DCCF87B2-B42D-4C1B-B237-69C30F288AEA&version=2.0.1.0&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 2024-01-23 16:33:46.982 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2024-01-23 16:33:47.909 Info Server: http/1.1 Response 204 to ::1. Time: 929ms. POST http://localhost:8097/emby/Packages/Installed/VirtualTV?updateClass=Dev&AssemblyGuid=DCCF87B2-B42D-4C1B-B237-69C30F288AEA&version=2.0.1.0&X-Emby-Client=Emby Web&X-Emby-Device-Name=Google Chrome Windows&X-Emby-Device-Id=##########&X-Emby-Client-Version=4.8.0.74&X-Emby-Token=##########&X-Emby-Language=de 2024-01-23 16:33:47.910 Info HttpClient: GetTempFileResponse url: https://embydata.com/admin/service/packageFiles/VirtualTV.dll_2.0.1.0.exe 2024-01-23 16:33:47.910 Info HttpClient: GET https://embydata.com/admin/service/packageFiles/VirtualTV.dll_2.0.1.0.exe 2024-01-23 16:33:48.481 Error InstallationManager: Package installation failed *** Error Report *** Version: 4.8.0.74 Command line: D:\Emby-4.8.0.66\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.18363 Framework: .NET 6.0.26 OS/Process: x64/x64 Runtime: D:/Emby-4.8.0.66/system/System.Private.CoreLib.dll Processor count: 8 Data path: D:\Emby-4.8.0.66\programdata Application path: D:\Emby-4.8.0.66\system System.Exception: System.Exception: Download validation failed for VirtualTV. Probably corrupted during transfer. at Emby.Server.Implementations.Updates.InstallationManager.PerformPackageInstallation(IProgress`1 progress, String target, PackageVersionInfo package, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.InstallPackageInternal(PackageVersionInfo package, Boolean isPlugin, IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.InstallPackage(PackageVersionInfo package, Boolean isPlugin, IProgress`1 progress, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2024-01-23 16:33:48.481 Error InstallationManager: Error in event handler *** Error Report *** Version: 4.8.0.74 Command line: D:\Emby-4.8.0.66\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.18363 Framework: .NET 6.0.26 OS/Process: x64/x64 Runtime: D:/Emby-4.8.0.66/system/System.Private.CoreLib.dll Processor count: 8 Data path: D:\Emby-4.8.0.66\programdata Application path: D:\Emby-4.8.0.66\system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Notifications.NotificationManager._installationManager_PackageInstallationFailed(Object sender, InstallationFailedEventArgs e) at MediaBrowser.Common.Events.EventHelper.TriggerAll[T](EventHandler`1 mainHandler, Object sender, T args, ILogger logger) Source: Emby.Notifications TargetSite: Void _installationManager_PackageInstallationFailed(System.Object, MediaBrowser.Common.Updates.InstallationFailedEventArgs) 2024-01-23 16:33:48.482 Error App: From FireAndForget - System.Threading.Tasks.UnwrapPromise`1[System.Threading.Tasks.VoidTaskResult] *** Error Report *** Version: 4.8.0.74 Command line: D:\Emby-4.8.0.66\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.18363 Framework: .NET 6.0.26 OS/Process: x64/x64 Runtime: D:/Emby-4.8.0.66/system/System.Private.CoreLib.dll Processor count: 8 Data path: D:\Emby-4.8.0.66\programdata Application path: D:\Emby-4.8.0.66\system System.AggregateException: System.AggregateException: One or more errors occurred. (Download validation failed for VirtualTV. Probably corrupted during transfer.) ---> System.Exception: Download validation failed for VirtualTV. Probably corrupted during transfer. at Emby.Server.Implementations.Updates.InstallationManager.PerformPackageInstallation(IProgress`1 progress, String target, PackageVersionInfo package, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.InstallPackageInternal(PackageVersionInfo package, Boolean isPlugin, IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.InstallPackage(PackageVersionInfo package, Boolean isPlugin, IProgress`1 progress, CancellationToken cancellationToken) --- End of inner exception stack trace --- Source: TargetSite: No Stack Trace Available InnerException: System.Exception: Download validation failed for VirtualTV. Probably corrupted during transfer. Source: Emby.Server.Implementations TargetSite: Void MoveNext() at Emby.Server.Implementations.Updates.InstallationManager.PerformPackageInstallation(IProgress`1 progress, String target, PackageVersionInfo package, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.InstallPackageInternal(PackageVersionInfo package, Boolean isPlugin, IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.InstallPackage(PackageVersionInfo package, Boolean isPlugin, IProgress`1 progress, CancellationToken cancellationToken) Edited January 23, 2024 by pünktchen
crusher11 1147 Posted January 23, 2024 Posted January 23, 2024 Okay, I've updated and it's still not respecting "play only watched".
pünktchen 1411 Posted January 23, 2024 Author Posted January 23, 2024 1 minute ago, crusher11 said: Okay, I've updated and it's still not respecting "play only watched". Do you mean "Watched state to include for movies/music videos", respectively "Watched state to include for tv shows/episodes"?
Smitty018210 147 Posted January 23, 2024 Posted January 23, 2024 I'm a little confused where do I download this plugin from? Was thinking of trying it out, but the downloads on the first post don't work when I download and put them in the plugin folder. Not sure what I am doing wrong.
pünktchen 1411 Posted January 23, 2024 Author Posted January 23, 2024 8 minutes ago, Smitty018210 said: I'm a little confused where do I download this plugin from? It depends on the Emby version you have installed.
Dez_Lamar 10 Posted January 23, 2024 Posted January 23, 2024 Can some explain to me how do I separate multiple studios in this plugin do I use "|" or "||" or "&&"
pünktchen 1411 Posted January 23, 2024 Author Posted January 23, 2024 2 minutes ago, TallBoiDez said: Can some explain to me how do I separate multiple studios in this plugin do I use "|" or "||" or "&&" "||" if the item should have any of the studios or "&&" if the item should have all studios.
Dez_Lamar 10 Posted January 23, 2024 Posted January 23, 2024 21 minutes ago, pünktchen said: "||" if the item should have any of the studios or "&&" if the item should have all studios. Ohhh okay that's why those channels aren't working. Thanks for clarifying that for me
Dibbes 515 Posted January 23, 2024 Posted January 23, 2024 @pünktchen Quick question: Does this work now?
pünktchen 1411 Posted January 23, 2024 Author Posted January 23, 2024 15 minutes ago, Dibbes said: @pünktchen Quick question: Does this work now? I hope so
Smitty018210 147 Posted January 23, 2024 Posted January 23, 2024 2 hours ago, pünktchen said: It depends on the Emby version you have installed. Just the normal 4.7.14.0 version. Not using the beta.
pünktchen 1411 Posted January 23, 2024 Author Posted January 23, 2024 8 minutes ago, Smitty018210 said: Just the normal 4.7.14.0 version. Not using the beta. Then it's "VirtualTV.1.1.3.2_Emby.4.7.x.zip" that you want. Did you extract the dll from the zip or did you copy the zip to your plugins folder? Also what OS do you have?
Smitty018210 147 Posted January 23, 2024 Posted January 23, 2024 (edited) 52 minutes ago, pünktchen said: Then it's "VirtualTV.1.1.3.2_Emby.4.7.x.zip" that you want. Did you extract the dll from the zip or did you copy the zip to your plugins folder? Also what OS do you have? I unzipped it and put it into the plugin folder. Then restarted my server, but nothing happened. I am going to try again and see what happens. Thanks for the help. Edited January 23, 2024 by Smitty018210
pünktchen 1411 Posted January 23, 2024 Author Posted January 23, 2024 15 minutes ago, Smitty018210 said: I unzipped it and put it into the plugin folder. Then restarted my server, but nothing happened. Emby has two plugins folders! Make sure it's the correct one - for Windows it is under "programdata". For non Windows operating systems i don't know the path, but i know you have to give attention to the file permissions.
crusher11 1147 Posted January 24, 2024 Posted January 24, 2024 11 hours ago, pünktchen said: Do you mean "Watched state to include for movies/music videos", respectively "Watched state to include for tv shows/episodes"? Yeah, that one.
