aerial 0 Posted December 24, 2019 Posted December 24, 2019 I'm having a problem selecting my media. When I go to any of my Media Libraries I can not select Shows or Favorites. I have no problem with Continue Watching, Next Up, Latest Movies, and Latest Episodes. I tried uninstalling theater and reinstall, also backing up server to an early point when everything was working correctly. I'm having this problem on two different machines also everything was fine this morning and started this afternoon. Thanks Joel
Luke 42241 Posted December 24, 2019 Posted December 24, 2019 Hi there, what do you mean by "cannot select" ?
aerial 0 Posted December 24, 2019 Author Posted December 24, 2019 (edited) If I move my cursor to Shows, Favorites, Movies and hit select nothing happens except for the audible tone. Edited December 24, 2019 by aerial
Luke 42241 Posted December 24, 2019 Posted December 24, 2019 That's strange. Can you try restarting the app? What version of emby theater is it?
aerial 0 Posted December 24, 2019 Author Posted December 24, 2019 I have tried restarting the app. I also uninstalled and reinstalled. It is happening on two different machines so I thought it might be an Emby Server issue so I rolled back to an earlier backup. If I access through my browser I have no issues. Version 3.0.10
Guest asrequested Posted December 24, 2019 Posted December 24, 2019 Yup! Is no workee. You can't get into the library
Guest asrequested Posted December 24, 2019 Posted December 24, 2019 (edited) Oh boy! Very little works! Edited December 24, 2019 by Doofus
Luke 42241 Posted December 24, 2019 Posted December 24, 2019 Have you tried restarting the app? Seems to be ok here.
Luke 42241 Posted December 24, 2019 Posted December 24, 2019 Ok it's only an issue with the horizontal home screen. I'll get an update out to resolve it. Thanks.
statik 0 Posted December 24, 2019 Posted December 24, 2019 (edited) Same issue. Emby Theater worked yesterday but today I can only select from continue watching or a suguested series or movie. When I click on movies, favorites, programs, shows, or guide I only get an audible indication. I changed to vertical display and all works well. Edited December 24, 2019 by statik
