toonces2 0 Posted December 23, 2019 Posted December 23, 2019 (edited) Just got a new fire TV cube and installed Kodi 19. This is the first time I've used this software so that's why I'm thinking I haven't gotten the hang of it yet. I followed a video that ended me up with a build called "Leia," I think. I can also get it to access something called Xenon as well. Without any additional addons it seems like this software is by itself able to get me to movies but it seems like everywhere I go the sources just don't pan out. It usually takes somewhere between 15-30 minutes to find a movie source that will actually play. I saw where one called Covenant is good but I installed it and it doesn't seem to be doing any better. If there was a KODI Addons for Dummy's I would read it. What do I need to do to access movies more easily? Also some strange text has permanently appeared on the top part of my screen when KODI is running. It's on there no matter what screen I'm in. In all white letters it reads... LOG:/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log MEM: 586123 / 2037436 KB - FPS: 59.4 fps xxU: #0: 0.0% #1: 0.0% #2: 0.0% #3: 0.0% #4: 0.0% #5: 0.0% (CPU - KODI 187.85%) What is this and do I need to do some kind of re-install to get it off? Edited December 23, 2019 by toonces2
ebr 16332 Posted December 23, 2019 Posted December 23, 2019 Hi. Are you using Emby server and one of our add-ons?
