Sub21 0 Posted December 23, 2019 Posted December 23, 2019 As I wrote above, if I start Emby listen to a song, leave and go to another app and then return to Emby, it gets stuck at searching for server. If I force quit the app then restart, it works fine. Any suggestions?Thanks
vdatanet 1619 Posted December 23, 2019 Posted December 23, 2019 (edited) 1.4.4.01 Native player is back! It is enabled by default and you can switch to the MPV-based player by enabling the 'Enable MPV' setting in the settings We have updated the styles of the MPV player drop-down to align with tvOS 13 Fixed a bug that prevented subtitles and audio tracks in the MPV player drop down from being highlighted when focused The Home View, most Movies, Shows, and Music views will now refresh when the app is brought back into the foreground Added a skip button to the Emby Connect screen to align with other Emby apps Improved language handling by ensuring a base language is chosen first before considering the locale Fixed a scenario where you could get to views (like Select Server and such) by pressing MENU when the Home view is displayed I think the issue is fixed in latest beta. You can give it a try, send a PM to @@ebr asking him for a TestFlight invitation. Remember to provide him your App Store mail. The more beta testers, the better. Edited December 23, 2019 by vdatanet
