CWNashvegas 170 Posted October 10, 2013 Posted October 10, 2013 1916 * 812 seems like a really weird resolution for a video. I've seen this non-fullscreen issue once or twice when I scale a video up from a resolution that's smaller than the device screen. Old 4:3 tv shows would be an example. This is happening to me also, with old 4:3 tv shows. And since that is what makes up the majority of my library... They played fine with MX, but they were squished using the internal player. I'm just not able to help much with testing right now, but I thought I'd add a "me too", especially since you mentioned the exact content I'm having the issue with. Pretty much all of my content is of a resolution smaller than my screen (Iconia A200, 1280 x 800 display).
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 (edited) Here is a sample of my video file... Can you test this? https://dl.dropboxusercontent.com/u/5118921/Videos/Fast.%26.Furious.6%20(1)-003.mkv Just add it in one of your collections temporary.. Full-screened: That's being repoted in the Dashboard as 40:17,which is also 2:35. Audio:DTS • 1536 kbps • 6 ch • 48000 khz • Default Video:h264 • 1280 • 544 • 40:17 • 1642 kbps • 23.97602 • Default Edited October 10, 2013 by CBers
sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 (edited) ok, so it's your video files... Can I ask you where does it come from? Edited October 10, 2013 by sfnetwork
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 (edited) ok, so it's your video files... When playing via internal player - works fine in VLC. Works fine in MBC and MBT as well. Edited October 10, 2013 by CBers
sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 (edited) When playing via internal player - works fine in VLC. Works fine in MBC and MBT as well. I think I'm confused... which one works ok? my sample or your MKV... Edited October 10, 2013 by sfnetwork
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 I think I'm confused... which one works ok? my sample or your MKV... In MBC & MBT mine plays fine but it doesn't in Android. Your's plays fine in Android.
sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 In MBC & MBT mine plays fine but it doesn't in Android. Your's plays fine in Android. If possible, could you create and share a sample of your MKV file so I could test it?
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 If possible, could you create and share a sample of your MKV file so I could test it? How's the best/easiest way of doing that ??
sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 How's the best/easiest way of doing that ?? http://www.youtube.com/watch?v=Z9H31taQLdQ I use MKVtoolNix
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 Playing my video in the default Android video player:
Tharnax 49 Posted October 10, 2013 Posted October 10, 2013 Did you consider creating the products in BETA as their own category, where rather then having questions/answers as one long thread people could create individual posts. Similar to what you have for MBT, MBC, Web Client, etc.? Obviously, once the product goes to Production it would be could be moved out into the non-Beta section and the threads under the category closed. Just a thought.
sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 @sfnetwork - try this. everything seems OK with your file when testing it... Now I'm confused lol
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 Just adding that clip to my library and will play it back through Android app. Perhaps it just needs re-muxing !!
sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 Did you consider creating the products in BETA as their own category, where rather then having questions/answers as one long thread people could create individual posts. Similar to what you have for MBT, MBC, Web Client, etc.? Obviously, once the product goes to Production it would be could be moved out into the non-Beta section and the threads under the category closed. Just a thought. I agree that we should move this conversation in a separate tread as this seems really specific.......
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 (edited) My clip still doesn't play full screen via the Android client: Nexus 10: Nexus 4: OK, gonna try my daughter's Nexus 7 (2012) next !! Edited October 10, 2013 by CBers
sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 (edited) how to you make it transcode video but copy stream audio? I can't seem to reproduce this... Edited October 10, 2013 by sfnetwork
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 how to you make it transcode video but copy stream audio? I can't seem to reproduce this... You tell me
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 Doesn't play back full-screen on Nexus 7 either:
sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 (edited) I'm really trying to reproduce your video size issue using your sample... I just can't... it always works for me. (only have my hands on the Nexus 7 2013 right now) Edited October 10, 2013 by sfnetwork
sfnetwork 514 Posted October 10, 2013 Posted October 10, 2013 how to you make it transcode video but copy stream audio? I can't seem to reproduce this... ok... Since your audio can be copy streamed and if video quality is lower than MKV bitrate, it does this. Basically video quality setting doesn't change the audio request (transcode/copystream; if it can copy, it will whatever quality setting you have) lol doesn't really help with your issue, just answers my own question.
CBers 7554 Posted October 10, 2013 Posted October 10, 2013 Don't bust a gut on it, as it's not the end of the world, as I'll just play what I need to in an external player.
Luke 42243 Posted October 11, 2013 Posted October 11, 2013 no because it might need a different container.
Redshirt 1487 Posted October 11, 2013 Author Posted October 11, 2013 (edited) how to you make it transcode video but copy stream audio? I can't seem to reproduce this... The only way I can see that happening is if the bitrate in the settings is lower than the source bitrate. Edit: Ah I see you already figured that out... carry on Edited October 11, 2013 by Redshirt 1
