jmelan 1 Posted November 10, 2013 Posted November 10, 2013 thanks guys, rechecked debug logging is set, new server log sent - looks same to me, ffmpeg sent as well.
jmelan 1 Posted November 10, 2013 Posted November 10, 2013 just checked with files i specifically encoded for android and direct stream works perfectly
Redshirt 1487 Posted November 10, 2013 Author Posted November 10, 2013 There's still no debug info in that server log. It's been so long since I had that option unchecked. Perhaps you need to restart the server once enabling debug logging for it to start writing the debug info. So let's try this one more time. Restart server, delete the logs then try playback again.
jmelan 1 Posted November 10, 2013 Posted November 10, 2013 that did it, needed to restart server, much more info now, sent some other files start but crash on seeking, no problems with the direct stream files
Redshirt 1487 Posted November 10, 2013 Author Posted November 10, 2013 ok, that is the log I want. But your not going to believe this. When you PM a log like you are, the forum software truncates the text. So rather than useful info I get. Url: http://192.168.1.50:...positionTicks=0 So knowing the forum software does this, use something like dropbox/skydrive or dump the contents into paste2.org and give me that link.
Redshirt 1487 Posted November 10, 2013 Author Posted November 10, 2013 Ok I have that. Tikuf and I will discuss it shortly.
Tikuf 663 Posted November 10, 2013 Posted November 10, 2013 (edited) @@jmelan is the file seekable outside mediabrowser ? If not it is most likely because the file was downloaded from a live stream and the timestamps are a little messed up. Edited November 10, 2013 by Redshirt
jmelan 1 Posted November 10, 2013 Posted November 10, 2013 (edited) perfectly seekable in 7MC and on Nexus 10 Also, just tested on my galaxy s4 and it works perfectly on there as well Test file has the same result as the original Thx! ...As soon as the 4.4 update is available for the Nexus 10 I can test that as well Edited November 10, 2013 by jmelan
CBers 7554 Posted November 10, 2013 Posted November 10, 2013 As soon as the 4.4 update is available for the Nexus 10 I can test that as well Soon, very soon In the meantime, take a break
Tikuf 663 Posted November 10, 2013 Posted November 10, 2013 @jmelan how does it work streaming through mb on your s4?
jmelan 1 Posted November 10, 2013 Posted November 10, 2013 Perfectly fine, no problems on the S4 with 15.6
Redshirt 1487 Posted November 12, 2013 Author Posted November 12, 2013 This topic is closed for all intents and purposes. Please follow this android thread moving forward. Thanks. http://mediabrowser.tv/community/index.php?/topic/1958-android-client-release-candidate/ 1
Luke 42243 Posted July 16, 2017 Posted July 16, 2017 @@sfnetwork @@CBers @@jmelan @@autoepg @@snake98 @@Abobader @@nardoth @@kamakamadaun @@thoror @@blade005 @@kazz63758 @@coolspot @@Yogi 2.9.32 is rolling out and supports offline browsing and playback. The feature is still very new so please make sure to leave your feedback and we will continue to improve it. Thanks !
