JBFROG 0 Posted December 22, 2019 Posted December 22, 2019 (edited) Since last few days, I'm not able to identify any album with MusicBrainz or gathering pictures. Is there any known issue about athentication to external websites or change in protocols ? It seems the certificates doesn't work anymore. InnerException: Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED at /source/mono/external/boringssl/ssl/handshake_client.c:1132 More details in joined log file. Thanks for your support Edited December 22, 2019 by JBFROG
Luke 42240 Posted December 22, 2019 Posted December 22, 2019 Hi there, please attach the emby server log file. thanks !
JBFROG 0 Posted December 23, 2019 Author Posted December 23, 2019 Please find attached the last logfile. I launched multiple umage requests for Artists search and TV. Regards, embyserver.zip
Luke 42240 Posted December 23, 2019 Posted December 23, 2019 Hi, all outgoing communications are failing. It looks like you have something blocking Emby Server from sending requests to remote websites. This could be firewall, security software, of VPN. If you can resolve this then it should resolve your issue. Please let us know if this helps. Thanks.
JBFROG 0 Posted December 23, 2019 Author Posted December 23, 2019 I checked everything related to newtork and found no issues. I tried to uninstall and reinstall MusicBrainz and AudioDB. In that log file, you will find I can download TV series pictures without any problem. When I try to identify Artists, I receive a SSL error. "InnerException: Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED at /source/mono/external/boringssl/ssl/handshake_client.c:1132" embyserver.zip
JBFROG 0 Posted December 29, 2019 Author Posted December 29, 2019 After a full unistall/install of Emby, I give up. Same symptoms, same errors... onlhy with MusicBrainz. I don't use HTTPS and don't have installed any certificate. Emby is running on a Synology NAS DS218Play. Joined a fresh log file. Thanks for your support. embyserver.txt
mengx8 0 Posted January 4, 2020 Posted January 4, 2020 I have the same problem 2020-01-05 06:53:19.339 Error App: Error in MusicBrainz *** Error Report *** Version: 4.3.1.0 Command line: /var/packages/EmbyServer/target/server/EmbyServer.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 5.18.0.240 (tarball Fri Jan 18 18:48:20 UTC 2019) Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/mono/5.18.0.240/lib/mono/4.5/mscorlib.dll Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.3.1.0 MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Error: TrustFailure (Authentication failed, see inner exception.) ---> System.Net.WebException: Error: TrustFailure (Authentication failed, see inner exception.) ---> System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. ---> Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED at /source/mono/external/boringssl/ssl/handshake_client.c:1132 at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00038] in <06b225350c3541b2a422a59539189a6b>:0 at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000a1] in <06b225350c3541b2a422a59539189a6b>:0 at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool) at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <06b225350c3541b2a422a59539189a6b>:0 at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000ff] in <06b225350c3541b2a422a59539189a6b>:0 at Mono.Net.Security.AsyncProtocolRequest.StartOperation (System.Threading.CancellationToken cancellationToken) [0x0008b] in <06b225350c3541b2a422a59539189a6b>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00252] in <06b225350c3541b2a422a59539189a6b>:0 at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x00126] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <06b225350c3541b2a422a59539189a6b>:0 --- End of inner exception stack trace --- at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x0021a] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00141] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebOperation.Run () [0x0009a] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00020] in <06b225350c3541b2a422a59539189a6b>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <06b73b509b314fc8a9db8d5f73b3c223>:0 --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsyncInternal (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x00769] in <ea16a5cfc8b849ea8a8b03b4ad685e1f>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsync (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x0009e] in <ea16a5cfc8b849ea8a8b03b4ad685e1f>:0 at MusicBrainz.MusicBrainzAlbumProvider.GetMusicBrainzResponse (System.String url, System.Boolean isSearch, System.Boolean forceMusicBrainzProper, System.Threading.CancellationToken cancellationToken) [0x001da] in <af82fbec3122458bb6911166df2d7780>:0 at MusicBrainz.MusicBrainzAlbumProvider.GetSearchResults (MediaBrowser.Controller.Providers.AlbumInfo searchInfo, System.Threading.CancellationToken cancellationToken) [0x0017c] in <af82fbec3122458bb6911166df2d7780>:0 at MusicBrainz.MusicBrainzAlbumProvider.GetMetadata (MediaBrowser.Controller.Providers.AlbumInfo id, System.Threading.CancellationToken cancellationToken) [0x00094] in <af82fbec3122458bb6911166df2d7780>:0 at MediaBrowser.Providers.Manager.MetadataService`2[TItemType,TIdType].ExecuteRemoteProviders (MediaBrowser.Controller.Providers.MetadataResult`1[T] temp, System.String logName, TIdType id, System.Collections.Generic.IEnumerable`1[T] providers, System.Threading.CancellationToken cancellationToken) [0x00138] in <b715abeb47a74caa86d135cf64129f07>:0 Source: mscorlib TargetSite: Void Throw() InnerException: System.Net.WebException: Error: TrustFailure (Authentication failed, see inner exception.) Source: System TargetSite: System.Net.WebResponse EndGetResponse(System.IAsyncResult) at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x0021a] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00141] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebOperation.Run () [0x0009a] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00020] in <06b225350c3541b2a422a59539189a6b>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <06b73b509b314fc8a9db8d5f73b3c223>:0 InnerException: System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. Source: mscorlib TargetSite: Void Throw() at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00252] in <06b225350c3541b2a422a59539189a6b>:0 at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x00126] in <06b225350c3541b2a422a59539189a6b>:0 at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <06b225350c3541b2a422a59539189a6b>:0 InnerException: Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED at /source/mono/external/boringssl/ssl/handshake_client.c:1132 Source: mscorlib TargetSite: Void Throw() at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00038] in <06b225350c3541b2a422a59539189a6b>:0 at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000a1] in <06b225350c3541b2a422a59539189a6b>:0 at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool) at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <06b225350c3541b2a422a59539189a6b>:0 at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000ff] in <06b225350c3541b2a422a59539189a6b>:0 at Mono.Net.Security.AsyncProtocolRequest.StartOperation (System.Threading.CancellationToken cancellationToken) [0x0008b] in <06b225350c3541b2a422a59539189a6b>:0
mengx8 0 Posted January 4, 2020 Posted January 4, 2020 Hi, all outgoing communications are failing. It looks like you have something blocking Emby Server from sending requests to remote websites. This could be firewall, security software, of VPN. If you can resolve this then it should resolve your issue. Please let us know if this helps. Thanks. Only MusicBrainZ has this problem
