wbestw 2 Posted December 22, 2019 Posted December 22, 2019 When I try to add in Libraries it says zero folders added
Luke 42239 Posted December 22, 2019 Posted December 22, 2019 Hi there, did you add the folder to your library? Can you show a screenshot of library setup? thanks.
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 When I try to add in Libraries it says zero folders added Yes heres picture https://imgur.com/a/kYUYFM4
Luke 42239 Posted December 23, 2019 Posted December 23, 2019 Ok, there's one folder there. Where does it say zero folders?
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 Ok, there's one folder there. Where does it say zero folders? It wont let me access my external usb hard drive
Luke 42239 Posted December 23, 2019 Posted December 23, 2019 But where does it say zero folders? Can you show a screenshot of that? Thanks.
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 But where does it say zero folders? Can you show a screenshot of that? Thanks. That has nothing to do not accesss any externan hard drive
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 But where does it say zero folders? Can you show a screenshot of that? Thanks. Can you do remote login to fix issue?
Luke 42239 Posted December 23, 2019 Posted December 23, 2019 I'm trying to help you. Can you tell me where it says zero folders?
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 I'm trying to help you. Can you tell me where it says zero folders? It doesnt say zero folders anymore I just cant access my external hard drives
Luke 42239 Posted December 23, 2019 Posted December 23, 2019 What happens when you try to access them?
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 (edited) What happens when you try to access them? I go here and its emty https://imgur.com/a/QgwrYSD no movies Edited December 23, 2019 by wbestw
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 Is What happens when you try to access them? Is there anyone with more knowledge about this 1
Happy2Play 9811 Posted December 23, 2019 Posted December 23, 2019 Sorry the partial library image and a home screen library image do not provide any information. What path is shown for you folder on the Library? Sound like the issue some users had where the update dropped the library.
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 (edited) Sorry the partial library image and a home screen library image do not provide any information. What path is shown for you folder on the Library? Sound like the issue some users had where the update dropped the library. Its https://imgur.com/a/tnkVkeI I deleted this https://imgur.com/a/tnkVkeI and reinstalled it becuase it wouldn't scan for new movies ever since then it wont access the external hard drive Edited December 23, 2019 by wbestw
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 Sorry the partial library image and a home screen library image do not provide any information. What path is shown for you folder on the Library? Sound like the issue some users had where the update dropped the library. Not much here really poor help
Happy2Play 9811 Posted December 23, 2019 Posted December 23, 2019 Sorry it is your system. I can only provide suggestions, just link anyone else on a forum. Have you removed and re-add the folder? Can you provide server logs? But it sound like a folder path issue as reported in other topics during the 4.3 update.
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 (edited) Sorry it is your system. I can only provide suggestions, just link anyone else on a forum. Have you removed and re-add the folder? Can you provide server logs? But it sound like a folder path issue as reported in other topics during the 4.3 update. Its not my system lol I removed folder and re-added your junk 4 times if my system why do you keep saying it was the upgrade? Edited December 23, 2019 by wbestw
wbestw 2 Posted December 23, 2019 Author Posted December 23, 2019 Its not my system lol I removed folder and re-added your junk 4 times if my system why do you keep saying it was the upgrade? Who wrote this software?
Happy2Play 9811 Posted December 23, 2019 Posted December 23, 2019 A developer that tries to accommodate all platforms. I guess porting all platforms is not a straight forward job and users get to identify all the issue that happen on their platform. As a Windows user I did not see any of the issues everyone else is having. So all we can do is try and figure out why your system is have issues with the update as it did not affect everyone. How about a server log?
wbestw 2 Posted December 24, 2019 Author Posted December 24, 2019 2019-12-23 19:45:16.104 Info Main: Application path: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/EmbyServer.dll2019-12-23 19:45:16.404 Info Main: Emby Command line: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/EmbyServer.dll -psn_0_610453 -noautorunwebapp Operating system: Unix 19.2.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/System.Private.CoreLib.dll Processor count: 4 Program data path: /Users/mc/.config/emby-server Application directory: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS2019-12-23 19:45:16.405 Info Main: Tray icon path: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/embytray2019-12-23 19:45:16.458 Info App: Application version: 4.3.1.02019-12-23 19:45:16.459 Info App: Loading assemblies2019-12-23 19:45:16.521 Info App: File /Users/mc/.config/emby-server/plugins/OpenSubtitles.dll has version 1.0.22.02019-12-23 19:45:16.522 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/OpenSubtitles.dll has version 1.0.22.02019-12-23 19:45:16.531 Info App: File /Users/mc/.config/emby-server/plugins/NfoMetadata.dll has version 1.0.24.02019-12-23 19:45:16.541 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/NfoMetadata.dll has version 1.0.23.02019-12-23 19:45:16.544 Info App: File /Users/mc/.config/emby-server/plugins/MovieDb.dll has version 1.2.6.02019-12-23 19:45:16.546 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/MovieDb.dll has version 1.2.6.02019-12-23 19:45:16.547 Info App: File /Users/mc/.config/emby-server/plugins/Emby.Webhooks.dll has version 1.0.8.02019-12-23 19:45:16.548 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/Emby.Webhooks.dll has version 1.0.8.02019-12-23 19:45:16.552 Info App: File /Users/mc/.config/emby-server/plugins/Emby.PortMapper.dll has version 1.0.2.02019-12-23 19:45:16.554 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/Emby.PortMapper.dll has version 1.0.2.02019-12-23 19:45:16.555 Info App: File /Users/mc/.config/emby-server/plugins/BlurayMounter.dll has version 1.0.0.02019-12-23 19:45:16.557 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/BlurayMounter.dll has version 1.0.0.02019-12-23 19:45:16.559 Info App: File /Users/mc/.config/emby-server/plugins/Tvdb.dll has version 1.0.22.02019-12-23 19:45:16.562 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/Tvdb.dll has version 1.0.22.02019-12-23 19:45:16.563 Info App: File /Users/mc/.config/emby-server/plugins/StudioImages.dll has version 1.0.1.02019-12-23 19:45:16.563 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/StudioImages.dll has version 1.0.1.02019-12-23 19:45:16.570 Info App: File /Users/mc/.config/emby-server/plugins/Emby.Dlna.dll has version 1.0.33.02019-12-23 19:45:16.572 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/Emby.Dlna.dll has version 1.0.33.02019-12-23 19:45:16.574 Info App: File /Users/mc/.config/emby-server/plugins/Fanart.dll has version 1.0.5.02019-12-23 19:45:16.580 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/Fanart.dll has version 1.0.5.02019-12-23 19:45:16.588 Info App: File /Users/mc/.config/emby-server/plugins/MusicBrainz.dll has version 1.0.11.02019-12-23 19:45:16.589 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/MusicBrainz.dll has version 1.0.9.02019-12-23 19:45:16.591 Info App: File /Users/mc/.config/emby-server/plugins/OMDb.dll has version 1.0.7.02019-12-23 19:45:16.592 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/OMDb.dll has version 1.0.7.02019-12-23 19:45:16.593 Info App: File /Users/mc/.config/emby-server/plugins/DvdMounter.dll has version 1.0.0.02019-12-23 19:45:16.594 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/DvdMounter.dll has version 1.0.0.02019-12-23 19:45:16.596 Info App: File /Users/mc/.config/emby-server/plugins/AudioDb.dll has version 1.0.6.02019-12-23 19:45:16.698 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/AudioDb.dll has version 1.0.6.02019-12-23 19:45:16.704 Info App: File /Users/mc/.config/emby-server/plugins/Emby.Server.CinemaMode.dll has version 1.0.30.02019-12-23 19:45:16.706 Info App: File /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/Resources/plugins/Emby.Server.CinemaMode.dll has version 1.0.30.02019-12-23 19:45:16.738 Info App: Loading OpenSubtitles, Version=1.0.22.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/OpenSubtitles.dll2019-12-23 19:45:16.738 Info App: Loading NfoMetadata, Version=1.0.24.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/NfoMetadata.dll2019-12-23 19:45:16.738 Info App: Loading MovieDb, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/MovieDb.dll2019-12-23 19:45:16.738 Info App: Loading Emby.Webhooks, Version=1.0.8.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/Emby.Webhooks.dll2019-12-23 19:45:16.738 Info App: Loading Emby.PortMapper, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/Emby.PortMapper.dll2019-12-23 19:45:16.738 Info App: Loading BlurayMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/BlurayMounter.dll2019-12-23 19:45:16.738 Info App: Loading Tvdb, Version=1.0.22.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/Tvdb.dll2019-12-23 19:45:16.738 Info App: Loading StudioImages, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/StudioImages.dll2019-12-23 19:45:16.738 Info App: Loading Emby.Dlna, Version=1.0.33.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/Emby.Dlna.dll2019-12-23 19:45:16.738 Info App: Loading Fanart, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/Fanart.dll2019-12-23 19:45:16.738 Info App: Loading MusicBrainz, Version=1.0.11.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/MusicBrainz.dll2019-12-23 19:45:16.738 Info App: Loading OMDb, Version=1.0.7.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/OMDb.dll2019-12-23 19:45:16.738 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/DvdMounter.dll2019-12-23 19:45:16.738 Info App: Loading AudioDb, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/AudioDb.dll2019-12-23 19:45:16.738 Info App: Loading Emby.Server.CinemaMode, Version=1.0.30.0, Culture=neutral, PublicKeyToken=null from /Users/mc/.config/emby-server/plugins/Emby.Server.CinemaMode.dll2019-12-23 19:45:16.738 Info App: Loading MediaBrowser.Api, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading MediaBrowser.WebDashboard, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading MediaBrowser.Model, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading MediaBrowser.Common, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading MediaBrowser.Controller, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading MediaBrowser.Providers, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.Photos, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.Server.Implementations, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.LiveTV, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.ActivityLog, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.Server.MediaEncoding, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading MediaBrowser.LocalMetadata, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.Notifications, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.Codecs.Dxva, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.Codecs, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.Server.Connect, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading Emby.Server.Sync, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.738 Info App: Loading EmbyServer, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null2019-12-23 19:45:16.873 Info SqliteUserRepository: Sqlite version: 3.28.02019-12-23 19:45:16.873 Info SqliteUserRepository: Sqlite compiler options: COMPILER=clang-10.0.0,DEFAULT_FOREIGN_KEYS,ENABLE_COLUMN_METADATA,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_RTREE,THREADSAFE=12019-12-23 19:45:16.889 Info SqliteUserRepository: Default journal_mode for /Users/mc/.config/emby-server/data/users.db is wal2019-12-23 19:45:16.930 Info AuthenticationRepository: Default journal_mode for /Users/mc/.config/emby-server/data/authentication.db is wal2019-12-23 19:45:16.954 Info ActivityRepository: Default journal_mode for /Users/mc/.config/emby-server/data/activitylog.db is wal2019-12-23 19:45:16.957 Info SqliteDisplayPreferencesRepository: Default journal_mode for /Users/mc/.config/emby-server/data/displaypreferences.db is wal2019-12-23 19:45:16.962 Info App: Adding HttpListener prefix http://+:8096/2019-12-23 19:45:16.975 Info App: Adding HttpListener prefix https://+:8920/2019-12-23 19:45:17.097 Info SqliteItemRepository: Default journal_mode for /Users/mc/.config/emby-server/data/library.db is wal2019-12-23 19:45:18.248 Info Skia: SkiaSharp version: 1.68.0.02019-12-23 19:45:18.282 Info TaskManager: Daily trigger for Thumbnail image extraction set to fire at 12/24/2019 02:00:00, which is 374.69529965 minutes from now.2019-12-23 19:45:18.311 Info TaskManager: Daily trigger for Rotate log file set to fire at 12/24/2019 00:00:00, which is 254.69481371666666 minutes from now.2019-12-23 19:45:18.327 Info App: ServerId: 5fe662fb5ac04905a6d0b23a713290422019-12-23 19:45:18.398 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint2019-12-23 19:45:18.531 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:12019-12-23 19:45:18.540 Info App: Init BeginReceive on 0.0.0.02019-12-23 19:45:18.541 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.14307 seconds2019-12-23 19:45:18.541 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint2019-12-23 19:45:18.541 Info App: Loading data from /Users/mc/.config/emby-server/data/connect.txt2019-12-23 19:45:18.543 Info App: Loading data from /Users/mc/.config/emby-server/data/wan.dat2019-12-23 19:45:18.545 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.004553 seconds2019-12-23 19:45:18.545 Info App: Core startup complete2019-12-23 19:45:18.545 Info App: Post-init migrations complete2019-12-23 19:45:18.545 Info App: Starting entry point NfoMetadata.EntryPoint2019-12-23 19:45:18.546 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 0.000129 seconds2019-12-23 19:45:18.546 Info App: Starting entry point Emby.Webhooks.WebhooksEntryPoint2019-12-23 19:45:18.547 Info App: Entry point completed: Emby.Webhooks.WebhooksEntryPoint. Duration: 0.0011179999999999999 seconds2019-12-23 19:45:18.547 Info App: Starting entry point Emby.PortMapper.ExternalPortForwarding2019-12-23 19:45:18.548 Info App: Entry point completed: Emby.PortMapper.ExternalPortForwarding. Duration: 0.00069 seconds2019-12-23 19:45:18.548 Info App: Starting entry point Emby.Security.PluginSecurityManager2019-12-23 19:45:18.548 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 2.8E-05 seconds2019-12-23 19:45:18.548 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint2019-12-23 19:45:18.548 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 7.099999999999999E-05 seconds2019-12-23 19:45:18.548 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint2019-12-23 19:45:18.548 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 6E-06 seconds2019-12-23 19:45:18.548 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint2019-12-23 19:45:18.548 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.000459 seconds2019-12-23 19:45:18.548 Info App: Starting entry point Emby.Server.Implementations.Playlists.PlaylistsEntryPoint2019-12-23 19:45:18.549 Info App: Entry point completed: Emby.Server.Implementations.Playlists.PlaylistsEntryPoint. Duration: 0.00043599999999999997 seconds2019-12-23 19:45:18.549 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint2019-12-23 19:45:18.549 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 9.499999999999999E-05 seconds2019-12-23 19:45:18.549 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint2019-12-23 19:45:18.550 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.001403 seconds2019-12-23 19:45:18.550 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup2019-12-23 19:45:18.680 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.12931499999999999 seconds2019-12-23 19:45:18.680 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint2019-12-23 19:45:18.680 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 4.9E-05 seconds2019-12-23 19:45:18.680 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake2019-12-23 19:45:18.680 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 1.9999999999999998E-05 seconds2019-12-23 19:45:18.680 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier2019-12-23 19:45:18.681 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0009119999999999999 seconds2019-12-23 19:45:18.681 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier2019-12-23 19:45:18.681 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.000149 seconds2019-12-23 19:45:18.681 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard2019-12-23 19:45:18.681 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 3.7999999999999995E-05 seconds2019-12-23 19:45:18.681 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents2019-12-23 19:45:18.681 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 1.6E-05 seconds2019-12-23 19:45:18.681 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier2019-12-23 19:45:18.681 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 1.4E-05 seconds2019-12-23 19:45:18.681 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint2019-12-23 19:45:18.687 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0055569999999999994 seconds2019-12-23 19:45:18.687 Info App: Starting entry point Emby.LiveTV.EntryPoint2019-12-23 19:45:18.689 Info LiveTV: Loading live tv data from /Users/mc/.config/emby-server/data/livetv/timers2019-12-23 19:45:18.693 Info App: Entry point completed: Emby.LiveTV.EntryPoint. Duration: 0.005665 seconds2019-12-23 19:45:18.693 Info App: Starting entry point Emby.LiveTV.RecordingNotifier2019-12-23 19:45:18.693 Info App: Entry point completed: Emby.LiveTV.RecordingNotifier. Duration: 0.000134 seconds2019-12-23 19:45:18.693 Info App: Starting entry point Emby.ActivityLog.ActivityLogEntryPoint2019-12-23 19:45:18.693 Info App: Entry point completed: Emby.ActivityLog.ActivityLogEntryPoint. Duration: 0.00028 seconds2019-12-23 19:45:18.693 Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint2019-12-23 19:45:18.694 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 0.0012569999999999999 seconds2019-12-23 19:45:18.694 Info App: Starting entry point Emby.Notifications.Notifications2019-12-23 19:45:18.695 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 9.8E-05 seconds2019-12-23 19:45:18.695 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint2019-12-23 19:45:18.697 Info App: SyncRepository Initialize taking write lock2019-12-23 19:45:18.697 Info App: SyncRepository Initialize write lock taken2019-12-23 19:45:18.697 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0026609999999999997 seconds2019-12-23 19:45:18.697 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint2019-12-23 19:45:18.697 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.000149 seconds2019-12-23 19:45:18.697 Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPoint2019-12-23 19:45:18.697 Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 2.1E-05 seconds2019-12-23 19:45:18.697 Info App: All entry points have started2019-12-23 19:45:18.940 Info LibraryMonitor: Watching directory /Volumes/8TB/Movies2019-12-23 19:45:19.060 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog2019-12-23 19:45:20.172 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:45:20.177 Error HttpServer: Access token is invalid or expired.2019-12-23 19:45:20.179 Info HttpServer: HTTP Response 401 to ::1. Time: 7ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:45:21.296 Info TaskManager: StartupTrigger fired for task: Check for plugin updates2019-12-23 19:45:21.297 Info TaskManager: Executing Check for plugin updates2019-12-23 19:45:21.299 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json2019-12-23 19:45:21.311 Info TaskManager: StartupTrigger fired for task: Check for application updates2019-12-23 19:45:21.311 Info TaskManager: Executing Check for application updates2019-12-23 19:45:21.326 Info TaskManager: StartupTrigger fired for task: Hardware Detection2019-12-23 19:45:21.326 Info TaskManager: Executing Hardware Detection2019-12-23 19:45:21.326 Info FfmpegManager: FFMpeg: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/ffmpeg2019-12-23 19:45:21.326 Info FfmpegManager: FFProbe: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/ffprobe2019-12-23 19:45:21.326 Info FfmpegManager: FFDetect: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/ffdetect2019-12-23 19:45:21.383 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Execute: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/ffmpeg -hide_banner -version2019-12-23 19:45:21.409 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds2019-12-23 19:45:21.566 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx2642019-12-23 19:45:21.566 Info SoftwareCodecProvider: hevc, libx265, libx264 Software Encoder, V-E-libx2652019-12-23 19:45:21.566 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg42019-12-23 19:45:21.566 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg42019-12-23 19:45:21.567 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx2019-12-23 19:45:21.572 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx2642019-12-23 19:45:21.572 Info SoftwareCodecProvider: hevc, libx265, libx264 Software Encoder, V-E-libx2652019-12-23 19:45:21.572 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg42019-12-23 19:45:21.572 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg42019-12-23 19:45:21.572 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx2019-12-23 19:45:21.695 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds2019-12-23 19:45:21.776 Info TaskManager: Hardware Detection Completed after 0 minute(s) and 0 seconds2019-12-23 19:45:25.056 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:45:25.147 Info HttpServer: HTTP Response 200 to ::1. Time: 91ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:45:29.248 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:45:29.249 Error HttpServer: Access token is invalid or expired.2019-12-23 19:45:29.250 Info HttpServer: HTTP Response 401 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:45:35.162 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:45:35.166 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:45:39.193 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:45:39.194 Error HttpServer: Access token is invalid or expired.2019-12-23 19:45:39.194 Info HttpServer: HTTP Response 401 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:45:45.110 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:45:45.113 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:45:49.287 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:45:49.288 Error HttpServer: Access token is invalid or expired.2019-12-23 19:45:49.288 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:45:55.083 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:45:55.085 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:45:59.249 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:45:59.250 Error HttpServer: Access token is invalid or expired.2019-12-23 19:45:59.251 Info HttpServer: HTTP Response 401 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:05.088 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:05.090 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:09.258 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:09.259 Error HttpServer: Access token is invalid or expired.2019-12-23 19:46:09.259 Info HttpServer: HTTP Response 401 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:15.393 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:15.395 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:19.252 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:19.253 Error HttpServer: Access token is invalid or expired.2019-12-23 19:46:19.253 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:23.576 Error HttpClient: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>-1</errorCode><errorDescription>Invalid Action</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>2019-12-23 19:46:23.578 Error PortMapper: Error creating port map *** Error Report *** Version: 4.3.1.0 Command line: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/EmbyServer.dll -psn_0_610453 -noautorunwebapp Operating system: Unix 19.2.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS/System.Private.CoreLib.dll Processor count: 4 Program data path: /Users/mc/.config/emby-server Application directory: /private/var/folders/7w/rv2r55pj32v9dwlx829gygkw0000gn/T/AppTranslocation/8E66C538-4D94-45FA-90DD-BEA95C8D5276/d/EmbyServer.app/Contents/MacOS MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: InternalServerError at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping) at Emby.PortMapper.ExternalPortForwarding.CreateRules(INatDevice device) Source: Emby.Server.Implementations TargetSite: Void MoveNext() 2019-12-23 19:46:24.691 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:24.693 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:30.173 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:30.174 Error HttpServer: Access token is invalid or expired.2019-12-23 19:46:30.175 Info HttpServer: HTTP Response 401 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:34.679 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:34.684 Info HttpServer: HTTP Response 200 to ::1. Time: 5ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:39.086 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:39.087 Error HttpServer: Access token is invalid or expired.2019-12-23 19:46:39.087 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:45.468 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:45.470 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:49.832 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:49.833 Error HttpServer: Access token is invalid or expired.2019-12-23 19:46:49.833 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:55.184 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:55.185 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:46:59.293 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:46:59.293 Error HttpServer: Access token is invalid or expired.2019-12-23 19:46:59.294 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:05.111 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:05.113 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:09.246 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:09.246 Error HttpServer: Access token is invalid or expired.2019-12-23 19:47:09.246 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:15.082 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:15.084 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:19.258 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:19.258 Error HttpServer: Access token is invalid or expired.2019-12-23 19:47:19.259 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:25.068 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:25.069 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:29.150 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:29.151 Error HttpServer: Access token is invalid or expired.2019-12-23 19:47:29.151 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:36.164 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:36.166 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:39.186 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:39.187 Error HttpServer: Access token is invalid or expired.2019-12-23 19:47:39.187 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:45.407 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:45.409 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:49.294 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:49.294 Error HttpServer: Access token is invalid or expired.2019-12-23 19:47:49.294 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:55.177 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:55.178 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:47:59.021 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:47:59.021 Error HttpServer: Access token is invalid or expired.2019-12-23 19:47:59.021 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:05.108 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:05.109 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:09.649 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:09.650 Error HttpServer: Access token is invalid or expired.2019-12-23 19:48:09.650 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:14.677 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:14.679 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:19.979 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:19.979 Error HttpServer: Access token is invalid or expired.2019-12-23 19:48:19.979 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:25.040 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:25.068 Info HttpServer: HTTP Response 200 to ::1. Time: 29ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:30.166 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:30.167 Error HttpServer: Access token is invalid or expired.2019-12-23 19:48:30.167 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:35.414 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:35.416 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:39.257 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:39.258 Error HttpServer: Access token is invalid or expired.2019-12-23 19:48:39.258 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:45.178 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:45.179 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:49.257 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:49.258 Error HttpServer: Access token is invalid or expired.2019-12-23 19:48:49.258 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:55.108 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:55.109 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:48:59.258 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:48:59.259 Error HttpServer: Access token is invalid or expired.2019-12-23 19:48:59.259 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:05.084 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:05.085 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:09.267 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:09.268 Error HttpServer: Access token is invalid or expired.2019-12-23 19:49:09.268 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:15.081 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:15.083 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:19.257 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:19.258 Error HttpServer: Access token is invalid or expired.2019-12-23 19:49:19.258 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:25.159 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:25.161 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:29.199 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:29.199 Error HttpServer: Access token is invalid or expired.2019-12-23 19:49:29.200 Info HttpServer: HTTP Response 401 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:30.768 Info HttpServer: WS http://localhost:8096/embywebsocket?api_key=58700ebf954c4858a01f86ce9fb3df3d&deviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTRfNikgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc4LjAuMzkwNC4xMDggU2FmYXJpLzUzNy4zNnwxNTc2MTkzMjMwNTU2. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:30.774 Warn SessionWebSocketListener: Unable to determine session based on url: /embywebsocket?api_key=58700ebf954c4858a01f86ce9fb3df3d&deviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTRfNikgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc4LjAuMzkwNC4xMDggU2FmYXJpLzUzNy4zNnwxNTc2MTkzMjMwNTU22019-12-23 19:49:35.722 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:35.724 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:37.597 Info HttpServer: HTTP GET http://localhost:8096/web/strings/en-US.json?v=1577148577595. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:37.598 Info HttpServer: HTTP GET http://localhost:8096/web/bower_components/emby-webcomponents/strings/en-US.json?v=1577148577595. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:37.599 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/web/bower_components/emby-webcomponents/strings/en-US.json?v=15771485775952019-12-23 19:49:37.600 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/web/strings/en-US.json?v=15771485775952019-12-23 19:49:37.617 Info HttpServer: HTTP GET http://localhost:8096/web/favicon.ico. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:37.619 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/web/favicon.ico2019-12-23 19:49:37.643 Info HttpServer: HTTP GET http://localhost:8096/web/manifest.json. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:37.644 Info HttpServer: HTTP Response 304 to ::1. Time: 0ms. http://localhost:8096/web/manifest.json2019-12-23 19:49:37.994 Info HttpServer: HTTP GET http://localhost:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:37.997 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/emby/system/info/public2019-12-23 19:49:38.002 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:38.009 Info HttpServer: HTTP Response 200 to ::1. Time: 7ms. http://localhost:8096/emby/System/Info2019-12-23 19:49:38.015 Info HttpServer: WS http://localhost:8096/embywebsocket?api_key=228a588cb83649819e65f774450e51d7&deviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTRfNikgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc4LjAuMzkwNC4xMDggU2FmYXJpLzUzNy4zNnwxNTc2MTkzMjMwNTU2. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:38.017 Info HttpServer: HTTP GET http://localhost:8096/emby/DisplayPreferences/usersettings?userId=1b283b69ef2b4a69a996b458f8de40ce&client=emby. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:38.027 Info HttpServer: HTTP POST http://localhost:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:38.037 Info HttpServer: HTTP Response 200 to ::1. Time: 20ms. http://localhost:8096/emby/DisplayPreferences/usersettings?userId=1b283b69ef2b4a69a996b458f8de40ce&client=emby2019-12-23 19:49:38.042 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/1b283b69ef2b4a69a996b458f8de40ce. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:38.068 Info HttpServer: HTTP Response 200 to ::1. Time: 27ms. http://localhost:8096/emby/Users/1b283b69ef2b4a69a996b458f8de40ce2019-12-23 19:49:38.070 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/1b283b69ef2b4a69a996b458f8de40ce. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:38.071 Info HttpServer: HTTP Response 204 to ::1. Time: 44ms. http://localhost:8096/emby/Sessions/Capabilities/Full2019-12-23 19:49:38.071 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Users/1b283b69ef2b4a69a996b458f8de40ce2019-12-23 19:49:38.120 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:38.122 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:38.123 Info HttpServer: HTTP GET http://localhost:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:38.125 Info HttpServer: HTTP GET http://localhost:8096/emby/Library/VirtualFolders. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:38.133 Info HttpServer: HTTP Response 200 to ::1. Time: 10ms. http://localhost:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true2019-12-23 19:49:38.142 Info HttpServer: HTTP Response 200 to ::1. Time: 17ms. http://localhost:8096/emby/Library/VirtualFolders2019-12-23 19:49:45.277 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:45.279 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:46.901 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:46.916 Info HttpServer: HTTP Response 200 to ::1. Time: 15ms. http://localhost:8096/emby/System/Configuration2019-12-23 19:49:47.007 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:47.017 Info HttpServer: HTTP Response 200 to ::1. Time: 10ms. http://localhost:8096/emby/System/Logs2019-12-23 19:49:55.155 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:55.156 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:49:55.841 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:55.841 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/System/Configuration2019-12-23 19:49:55.848 Info HttpServer: HTTP POST http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:49:55.876 Info ServerConfigurationManager: Saving system configuration2019-12-23 19:49:55.877 Info HttpServer: HTTP Response 204 to ::1. Time: 29ms. http://localhost:8096/emby/System/Configuration2019-12-23 19:50:01.537 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:01.540 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/emby/System/Configuration2019-12-23 19:50:01.548 Info HttpServer: HTTP POST http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:01.549 Info ServerConfigurationManager: Saving system configuration2019-12-23 19:50:01.549 Debug XmlSerializer: Serializing to file /Users/mc/.config/emby-server/config/system.xml2019-12-23 19:50:01.551 Info HttpServer: HTTP Response 204 to ::1. Time: 3ms. http://localhost:8096/emby/System/Configuration2019-12-23 19:50:03.839 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:03.908 Info HttpServer: HTTP Response 200 to ::1. Time: 68ms. http://localhost:8096/emby/System/Logs/embyserver.txt2019-12-23 19:50:05.107 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:05.108 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:50:15.082 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:15.083 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:50:24.721 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:24.722 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:50:35.157 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:35.158 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:50:45.057 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:45.058 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:50:55.020 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:55.021 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:50:57.535 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs/hardware_detection-63712727121.txt. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:50:57.549 Info HttpServer: HTTP Response 200 to ::1. Time: 14ms. http://localhost:8096/emby/System/Logs/hardware_detection-63712727121.txt2019-12-23 19:51:05.044 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:51:05.045 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true2019-12-23 19:51:15.290 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36 2019-12-23 19:51:15.291 Info HttpServer: HTTP Response 200 to ::1. Time: 1ms. ht
wbestw 2 Posted December 27, 2019 Author Posted December 27, 2019 Cant get any help on here can someone login my pc and help
Luke 42239 Posted January 6, 2020 Posted January 6, 2020 @@wbestw are you able to see the external hard drive in the MacOS finder application?
Damien_ 30 Posted February 4, 2020 Posted February 4, 2020 @@wbestw are you able to see the external hard drive in the MacOS finder application? User error
