jscoys 147 Posted December 21, 2019 Posted December 21, 2019 Hello, Long time I wanted to report this but was busy. On IPad mini 2, running on iOS 12.4.4, the iOS app is not preventing the screen to go off and then auto-lock... steps to reproduce: 1) start a playback 2) go on settings, then change the playback quality to something else, so the stream is restarted from the server 3) wait, after 2 minutes (by default) the screen goes darker and then shutdown, even if it’s playing something Seems not happening on my iPhone X. Also not happening if you start a playback without touching any options. Also if my memory is working well, it started when you fixed the same kind of dimming issue with iPhone X on a previous version, something like 2 months ago. Let me know if you need extra info, I can do a video if you want, and I’m in the beta program, so if you want me to test quickly I can! Thx Sent from my iPad using Tapatalk
jscoys 147 Posted December 23, 2019 Author Posted December 23, 2019 Still happening with the 1.9.0 (4) Sent from my iPad using Tapatalk
Luke 42242 Posted December 23, 2019 Posted December 23, 2019 Thanks for reporting. We'll take a look. 1
jscoys 147 Posted December 26, 2019 Author Posted December 26, 2019 Ok it happened to me today on my iPhone X... Sent from my iPhone using Tapatalk
Luke 42242 Posted December 26, 2019 Posted December 26, 2019 It's resolved for the next app update. Thanks.
jscoys 147 Posted December 26, 2019 Author Posted December 26, 2019 [emoji106][emoji106][emoji106] Sent from my iPhone using Tapatalk
jscoys 147 Posted December 30, 2019 Author Posted December 30, 2019 Fixed with last beta version thx! Sent from my iPhone using Tapatalk
