Guest Koda Posted December 21, 2019 Posted December 21, 2019 Hi I have a Huawei Mate 10 Pro with the newest Android Emby App. When I hear a Audio Book and come Back I see my Audio Book But when I click on play or push the button resume..., emby played from begin. A few weeks before it works. On the newest iOS App it all ready work. Is this a bug on the Android App? Best regards Koda
Guest Koda Posted December 21, 2019 Posted December 21, 2019 Sorry I can't edit. On Android I have set the app start manual that the energy safe mod of Android is not the problem.
Guest Koda Posted December 21, 2019 Posted December 21, 2019 (edited) Now I have additional see that after the change to chapter 1, on my start screen under recet play I see chapter 1 and 2Sorry for the bad english Ok on Desktop I have found an edit button. I think a few month before it was an older samsung tablet where it work. Is this a bug from app or from huawei? Edit: Now I have tested on a samung Galaxy Note 10 and it is the same issue. Second Issue with this: After reopen emby, and play from begin (I change the time), emby is stop playing if the chapter end. Edited December 22, 2019 by Koda
Luke 42244 Posted December 23, 2019 Posted December 23, 2019 Hi, we'll take a look at this. Thanks for reporting.
Guest Koda Posted December 23, 2019 Posted December 23, 2019 Thank you. I have tested two things: But when I click on play or push the button resume..., emby played from begin. I have download the emby apk from apkmirror in Version 3.0.21. The Resume playback from playbutton will work (But same as in other thread. Only the ony chapter of audiobook) Now I have additional see that after the change to chapter 1, on my start screen under recet play I see chapter 1 and 2 I have set emby server for 100% I musst see/hear two mark it as playes. But emby don't understand that the chapter is played 100%. When I ser 99% the older chapter is not longer shown on start screen.
Luke 42244 Posted December 23, 2019 Posted December 23, 2019 @@Happy2Play he's saying if he sets his max resume to 100%, then content never gets marked played. Are you able to reproduce?
negativzeroe 80 Posted January 4, 2020 Posted January 4, 2020 Link to this version of the app for others having this issue. Confirmed working. https://www.apkmirror.com/apk/emby-media/emby-for-android/emby-for-android-3-0-21-release/emby-for-android-3-0-21-android-apk-download/download/
Luke 42244 Posted January 4, 2020 Posted January 4, 2020 It's resolved for the next update to the app. Thanks. 1
negativzeroe 80 Posted January 4, 2020 Posted January 4, 2020 Right on. Figured I'd help out the lazies though
negativzeroe 80 Posted January 9, 2020 Posted January 9, 2020 It's resolved for the next update to the app. Thanks.Which build should I be looking out for? Was trying out beta....89 but the issue was still present.
negativzeroe 80 Posted January 20, 2020 Posted January 20, 2020 (edited) It's resolved for the next update to the app. Thanks.This is not resolved in .91 fyiTried wiping app data and redownloading Also it doesn't play the track I select. But this one only when downloaded Edited January 21, 2020 by negativzeroe
negativzeroe 80 Posted January 21, 2020 Posted January 21, 2020 (edited) Try one when connected to the server.Sorry, revised. Download only when wrong track. But resume still broken. Also I should note I've tried m4b and mp3 with same results. Edited January 21, 2020 by negativzeroe
Luke 42244 Posted January 21, 2020 Posted January 21, 2020 When playing directly from the server it seems to be ok from here.
negativzeroe 80 Posted January 21, 2020 Posted January 21, 2020 (edited) When playing directly from the server it seems to be ok from here.Here is my log. Turned on debugging for the last two attempts. Min resume is 2, max resume is 98, min length is 1 second. Another update. The wrong track issue occurs if in downloads. It also doesn't add the rest of the queue. If I browse to audiobook the old fashioned way it selects the correct track and adds the book to the queue. log.txt Edited January 21, 2020 by negativzeroe
Guest Koda Posted January 23, 2020 Posted January 23, 2020 I have try the .92 too and its not work with audiobooks where i listen online.
negativzeroe 80 Posted January 29, 2020 Posted January 29, 2020 (edited) @@Luke FYI still present in 97 of beta. Tested on mine and my wife's phone. I have the oneplus 5, she has the moto g6. Both opted into beta. Also the downloads are still wrong, I played chapter 24 of Crossroads of Twilight and it started playing chapter 29. Started with debug around 9:40. Hers started on the right track when navigating directly to downloads but the tracks were all out of order. log.txt Edited January 29, 2020 by negativzeroe
Guest Koda Posted January 29, 2020 Posted January 29, 2020 Hi I have tested zhe .97 non beta. The reszme don`t work on my Samsung Galaxy. Not the play Button and not the Resume Button play resume. Both start the file again. In my iPad it works.
Luke 42244 Posted January 31, 2020 Posted January 31, 2020 Ok sorry somehow the fix did not make it into the update. It will be in 3.0.98+. Thanks. 1
Guest Koda Posted March 4, 2020 Posted March 4, 2020 Thank you. Have you any news when the next release (no beta) is planed to fix this issue?
Luke 42244 Posted March 4, 2020 Posted March 4, 2020 As soon as it get through app store review. Thanks.
