tuvx 15 Posted December 20, 2019 Posted December 20, 2019 When playing back media with audio as Dolby Digital Mono, I get no sound (on Fire TV). Any suggestions?embyserver.txt ffmpeg-transcode-f327ec02-5571-4d83-a8be-ad049392d1b5_1.txt
ebr 16338 Posted December 20, 2019 Posted December 20, 2019 Hi. Try using the Playback Correction feature (cog menu during playback) and see if it corrects it.
tuvx 15 Posted December 20, 2019 Author Posted December 20, 2019 Unfortunately, that does not resolve the issue; still no sound.
Luke 42246 Posted December 21, 2019 Posted December 21, 2019 How have you configured your system audio settings on the Fire TV? Can you describe your audio setup? Thanks.
ebr 16338 Posted December 21, 2019 Posted December 21, 2019 Hi. Yes, please describe all the equipment and how it is configured and hooked up. Also, try the correction feature repeatedly until it quits. Thanks.
tuvx 15 Posted December 21, 2019 Author Posted December 21, 2019 So the issue was only isolated to the latest Fire Stick 4K. The sound settings were left at their default "Best Available"; once this was changed to "Dolby Digital" the problem was resolved.
