sv3nno 2 Posted December 18, 2019 Posted December 18, 2019 (edited) Hi, I got some issues with playback of .mkv files with MPEG2 audio in Emby Theater on Chrome 79. The video stream works fine, but audio is muted. Emby does not try to transcode the file, it says "direct playing". Therefor I'm sorry to say there is no ffmpeg log from this thing happening. Seems however Chrome does not support mpeg2 audio? In that case, shouldn't Emby then transcode this to something else? I've tried multiple .mkv video files with MPEG2 audio, and all are behaving in the exact same way. Direct media playback works fine in Android app on these files. Playback via Internet Explorer emby theater works fine, but then via transcoding (which is totally fine by me): TranscodeReasons=ContainerNotSupported input stream: Audio: mp2, 48000 Hz, stereo, s16p, 192 kb/s (default) output stream: Audio: aac (LC), 48000 Hz, stereo, fltp, 192 kb/s (default) Chrome version: 79.0.3945.88 running on Windows 8.1 Emby-server 4.3.0.30 running on Ubuntu Linux LTS 16.04 Attached image of details about video file. Attached image of playback stats in Chrome. Attached transcode logs when using Internet Explorer. Is there something wrong with my setup? Or is Chrome being stupid and reporting support for something it does not? Regards transcode.txt Edited December 18, 2019 by sv3nno
Solution Luke 42241 Posted December 19, 2019 Solution Posted December 19, 2019 Hi, please update to 4.3.1 and it shouldn't direct play it anymore. 1
sv3nno 2 Posted December 19, 2019 Author Posted December 19, 2019 Right you are Luke! All files are working fine now. Thanks a bunch. Regards
