Dedone 17 Posted December 16, 2019 Posted December 16, 2019 Hi everyone, I'm just try to use the convert function to convert a file that wouldn't skip. My problem is that the file remain in the section conversion as downloded but the task don't start. I've also try to laich it manually from the task page without any result
Luke 42242 Posted December 16, 2019 Posted December 16, 2019 Hi, we need to improve the label, but if it says downloaded then that means it's already done.
Dedone 17 Posted December 16, 2019 Author Posted December 16, 2019 No, I confirm that it don't make it
Luke 42242 Posted December 16, 2019 Posted December 16, 2019 That makes it look like it's done. Why don't you think that it's done? Please attach the emby server log. thanks.
Dedone 17 Posted December 16, 2019 Author Posted December 16, 2019 Let me know if it's ok embyserver.txt.pdf
Luke 42242 Posted December 16, 2019 Posted December 16, 2019 So there's nothing to convert, that's why it's already done. You have an mkv that already matches the target profile you've selected, and you picked original quality, therefore why convert it. If you want to see it actually convert, then pick a different output, such as the mobile profile which will produce mp4, or use the TV profile with a lower quality. 1
Dedone 17 Posted December 16, 2019 Author Posted December 16, 2019 Working great! As always... Thanks Luke!!!!!
