PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 Do you see contentype removed upon restore? nope i dont - so something else going on with config backup plugin then i guess - see above my options.xml did not change date/time from the copy i had
Happy2Play 9814 Posted March 12, 2020 Posted March 12, 2020 Okay it would appear the contenttype rewrite was from entering a library settings. If I don't enter library settings contenttype remains eventhough UI is Mixed Content. A plugin restore, or a database delete, or new install copying libraries from one install to another nukes contenttype. But me if there is a contenttype.collection in library folder it will restore to the content type.
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 .collection is redundant and not created for a new library created via the UI - so anybody that has created a new library since the .collection become redundant will see this If they rebuild their library - so needs fixing and testing before Stable goes out yes i expect the contenttype gets deleted on an edit - as the contentytype is missing from a "true" mixed content library - and this is part of the problem I dont see any amendment of a library xml file when copied to the test server (with server off) - on running up the server it just reads it and decides its a mixed library and adds the library to the ui
Happy2Play 9814 Posted March 12, 2020 Posted March 12, 2020 .collection is redundant and not created for a new library created via the UI - so anybody that has created a new library since the .collection become redundant will see this If they rebuild their library - so needs fixing and testing before Stable goes out yes i expect the contenttype gets deleted on an edit - as the contentytype is missing from a "true" mixed content library - and this is part of the problem I dont see any amendment of a library xml file when copied to the test server (with server off) - on running up the server it just reads it and decides its a mixed library and adds the library to the ui I understand new libraries don't create it but am saying if you add it they maintain content type. So to me there has to be something in the code about this. But if this process only works for me, then I have no idea.
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 i have not tried the .collection file - not saying it does not work - but is an option for users - but is only a workaround at best IMO Yes there is a lot of code issues around this - the change was made without any testing as this would have come up before Lets see what @@Luke comes back with as an answer/fix for the two or three different issues that have been uncovered - might be others we will have to see.
Happy2Play 9814 Posted March 12, 2020 Posted March 12, 2020 (edited) That is the issue since everything has changed so much over time there is going to be so many mixed variables. Everything new will only be options.xml but all old libraries will have .collection and .mblink. and .xml. So if never resaved/updated options.xml, collection files is required. I still have libraries on my Stable build that have options.xml without contenttype. But obviously the backups will work do to containing the .collection file. So backwards compatibility has to be maintained for OLD systems. The issue resides in the NEW format not being read properly. Edited March 12, 2020 by Happy2Play
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 backups will only work with libraries not created recently as they will not have a collection file Its a massive mess that should have been tested for when brought in - mixed variables are in Luke's control if you have libraries on stable that dont have a content type then thats another bug that should have been covered off if you bring in new options - basic stuff I have a beta server with over 100 libraries - and a quick check shows that none of the options.xml files have been saved since june last year and all appear to have the content type within - dont think this server has been on beta though but interesting that they have the contenttype - was expecting them not to have it
Happy2Play 9814 Posted March 12, 2020 Posted March 12, 2020 backups will only work with libraries not created recently as they will not have a collection file Its a massive mess that should have been tested for when brought in - mixed variables are in Luke's control if you have libraries on stable that dont have a content type then thats another bug that should have been covered off if you bring in new options - basic stuff I have a beta server with over 100 libraries - and a quick check shows that none of the options.xml files have been saved since june last year and all appear to have the content type within - dont think this server has been on beta though but interesting that they have the contenttype - was expecting them not to have it If doesn't matter as required files exist and will alway be backed up. Only thing broken is NEW options.xml with content type. Now if the server were to clear the folder and rewrite a options.xml then that is another story. To recap my findings, all old libraries with new or old options.xml with .collection files restore fine. New libraries with only options.xml w/contenttype fail to restore properly, they restore as Mixed Content.
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 If doesn't matter as required files exist and will alway be backed up. Only thing broken is NEW options.xml with content type. No - if its a new library the collection files dont exist - so backup wont help you!
Happy2Play 9814 Posted March 12, 2020 Posted March 12, 2020 No - if its a new library the collection files dont exist - so backup wont help you! Correct NEW is broke Old is not. But if a collection file exists/add everything works.
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 just tested on Stable - if you create a new library - only options.xml file added and it does have content type in the xml so OLD same as New on that front - all comes down to when you created a library - which is nuts Stable has the same problem as beta in not seeing content type and creating mixed libraries
Happy2Play 9814 Posted March 12, 2020 Posted March 12, 2020 (edited) Okay yes, 4.3.1.0 + is this way, anything older has three files. So all OLDer library backups have the files needed. So all my Emby 3+ libraries are good with 3 files Edited March 12, 2020 by Happy2Play 1
Dibbes 515 Posted March 12, 2020 Author Posted March 12, 2020 Okay yes, 4.3.1.0 + is this way, anything older has three files. So all OLDer library backups have the files needed. So all my Emby 3+ libraries are good with 3 files Unfortunately I only have two version 3.x libraries left... the rest is all newer...
Happy2Play 9814 Posted March 13, 2020 Posted March 13, 2020 I still can not make manual workaround, restoring a new library with manually added contenttype.collection not restore properly.
Dibbes 515 Posted March 13, 2020 Author Posted March 13, 2020 I still can not make manual workaround, restoring a new library with manually added contenttype.collection not restore properly. This is what I meant here: https://emby.media/community/index.php?/topic/80502-backup-plugin-not-restoring-library-properly/page-2&do=findComment&comment=848732
Dibbes 515 Posted March 19, 2020 Author Posted March 19, 2020 Just testing the updated plugin and it seems that the libraries are now properly restored... Obviously it still scanning, but it's looking good! One question though: when restoring to another server that already has a few libraries setup, shouldn't the libraries that are already not be removed?
Luke 42255 Posted March 19, 2020 Posted March 19, 2020 The plugin update wasn't related to this so the loss of content type should still be an issue.
Luke 42255 Posted March 19, 2020 Posted March 19, 2020 when restoring to another server that already has a few libraries setup, shouldn't the libraries that are already not be removed? Not really sure what you're asking, but there's no error handling related to this. Ideally you should only restore libraries when no existing ones are in place.
Dibbes 515 Posted March 20, 2020 Author Posted March 20, 2020 The plugin update wasn't related to this so the loss of content type should still be an issue. I restored to a server that had a bunch of libraries already there and for some reason the libraries from the restore were all recognized properly...
Dibbes 515 Posted March 20, 2020 Author Posted March 20, 2020 Not really sure what you're asking, but there's no error handling related to this. Ideally you should only restore libraries when no existing ones are in place. I don't live in an ideal world... sorry
IkeTaylor11 61 Posted April 2, 2020 Posted April 2, 2020 Is this still actively being worked on for a fix? I have had to restore my Emby server multiple times lately (for reasons not caused by Emby) and all libraries import as "Mixed Content". It defeats the entire purpose of restoring libraries at all.
Happy2Play 9814 Posted May 18, 2020 Posted May 18, 2020 (edited) Still a issue but my work around works in my tests. Make a .collection file per library that reflects the contentype listed in the xml. boxsets.collection playlists.collection movies.collection tvshows.collection music.collection Without these files everything is restored Mixed Content. Edited June 13, 2020 by Happy2Play added music 1 1
dcol 177 Posted May 27, 2020 Posted May 27, 2020 Still a issue but my work around works in my tests. Make a .collection file per library that reflects the contentype listed in the xml. boxsets.collection playlists.collection movies.collection tvshows.collection Without these files everything is restored Mixed Content. Can you give an example as to where to put this collection file and what is in it?
Happy2Play 9814 Posted May 27, 2020 Posted May 27, 2020 Can you give an example as to where to put this collection file and what is in it? In the perspective library folder. It is a empty file. example
