Happy2Play 9814 Posted February 24, 2020 Posted February 24, 2020 (edited) Are you removing library, scanning, then re-adding and scanning? Just placing the file in a already imported library will not change it. What exactly are you doing? Edited February 24, 2020 by Happy2Play
Dibbes 515 Posted February 24, 2020 Author Posted February 24, 2020 (edited) Are you removing library, scanning, then re-adding and scanning? Just placing the file in a already imported library will not change it. What exactly are you doing? I'm not quite that much of a beginner Steps: add the .collection files to the folders run a library scan on the original server run a backup job on the original server install Emby from scratch on the server that is being used for testing, make sure that paths are the same as the original server, create an Emby admin user, no libraries, install the backup plugin and restart Emby restore Emby from the latest backup and restart Emby Edited February 24, 2020 by Dibbes
Happy2Play 9814 Posted February 24, 2020 Posted February 24, 2020 I'm not quite that much of a beginner Steps: add the .collection files to the folders run a library scan on the original server run a backup job on the original server install Emby from scratch on the server that is being used for testing, make sure that paths are the same as the original server, create an Emby admin user, no libraries, install the backup plugin and restart Emby restore Emby from the latest backup and restart Emby Not sure then. Here is what I did. Have a backup with libraries in new format only options.xml restored this backup both Movies and TV library were restored as mixed content. Started over only difference is adding "movies.collection" to Movie library folder and "tvshows.collection" TV library and restored. Both libraries were restored as TV and Movie content type. All tests done on 4.4.0.16 with Server Configuration Backup plugin 1.4.3.0.
Dibbes 515 Posted February 24, 2020 Author Posted February 24, 2020 Not sure then. Here is what I did. Have a backup with libraries in new format only options.xml restored this backup both Movies and TV library were restored as mixed content. Started over only difference is adding "movies.collection" to Movie library folder and "tvshows.collection" TV library and restored. Both libraries were restored as TV and Movie content type. All tests done on 4.4.0.16 with Server Configuration Backup plugin 1.4.3.0. I'll try again later this week... just to see if maybe there's something I overlooked... I'm running 4.4.0.15 with 1.4.3.0 Still, as these .collection files aren't generated anymore (at least AFAIK), shouldn't the plugin take its data from the .xml?
Happy2Play 9814 Posted February 24, 2020 Posted February 24, 2020 I'll try again later this week... just to see if maybe there's something I overlooked... I'm running 4.4.0.15 with 1.4.3.0 Still, as these .collection files aren't generated anymore (at least AFAIK), shouldn't the plugin take its data from the .xml? I would think so as <ContentType> was added. But at the same time I would think this is a server issue not a plugin issues as the plugin is only copying existing information, it only writes users/userdata from databases..
Happy2Play 9814 Posted February 25, 2020 Posted February 25, 2020 (edited) For some reason in the restore process the <ContentType> is stripped from the options.xml when the server does its initial scan of the restored libraries. Since the restored file is being modified after restart this would have to be a server issue. It happens in both stable and beta. @@Luke Edited February 25, 2020 by Happy2Play
Happy2Play 9814 Posted February 25, 2020 Posted February 25, 2020 (edited) @@Luke @@ebr Is any additional info needed? For me all libraries that have "*.collection" in there folder are restored properly and libraries without it are restored as Mixed Content. But really only tested TV and Movies. Edited February 25, 2020 by Happy2Play 1
Luke 42255 Posted February 29, 2020 Posted February 29, 2020 Can you reproduce this with a brand newly created backup?
Dibbes 515 Posted February 29, 2020 Author Posted February 29, 2020 @@Luke @@ebr Is any additional info needed? For me all libraries that have "*.collection" in there folder are restored properly and libraries without it are restored as Mixed Content. But really only tested TV and Movies. Just tested again. If I manually add a .collection file of the relevant name, the library gets restored as Mixed Content still. If I remove the .collection file from a library that had one created ages ago by MB, then it gets restored properly. If I remove that, it gets restored as Mixed Content. If I then put it the file back, it again gets restored properly. Can you reproduce this with a brand newly created backup? Yes
Happy2Play 9814 Posted March 2, 2020 Posted March 2, 2020 (edited) Can you reproduce this with a brand newly created backup? Not sure why I get different results then Dibbes. Just tested again with a new portable beta .19 in wizard created 1 movie library added Premiere key, installed SCB plugin 1.4.3.0, restarted went to plugin and assign backup path ran backup task shutdown server, deleted programdata folder started server, went through wizard without adding anything added Premiere key, installed SCB plugin 1.4.3.0, restarted went to plugin and assign backup path selected previous backup to restore, all options enabled server did not restart so I manually restarted (dashboard showed restart needed, also there was a pop at bottom left of browser saying to restart) went to Library and the restored library was restored as Mixed content shutdown server, deleted programdata folder started server, went through wizard without adding anything added Premiere key, installed SCB plugin 1.4.3.0, restarted went to backup folder and opened the backup, opened library folder, opened the library and added movies.collection file went to plugin and assign backup path selected previous back to restore, all options enabled server did not restart so I manually restarted (dashboard showed restart needed, also there was a pop at bottom left of browser saying to restart) went to Library and the restored library was restored as Movies This was all done on a new installation with new libraries and new backups. Edited March 2, 2020 by Happy2Play
PenkethBoy 2068 Posted March 11, 2020 Posted March 11, 2020 i did a rebuild of my test server a couple of days ago and two libraries - came back as mixed content My music library and the playlists library Had to delete them and recreate - i suspect the playlist library did not have a collection file as its newish as for music cant tell now as new folder which only has the options.xml file
PenkethBoy 2068 Posted March 11, 2020 Posted March 11, 2020 (edited) Ha - just tested without collection files for all libraries and and all bar two are mixed content and getting duplicates this is before trying the backup plugin restore - so i suspect its a server fault not the plugin Edited March 11, 2020 by PenkethBoy
Dibbes 515 Posted March 11, 2020 Author Posted March 11, 2020 @@Dibbes are you sure? @@Luke Sorry, but sure of what exactly?
Luke 42255 Posted March 12, 2020 Posted March 12, 2020 Ha - just tested without collection files for all libraries and and all bar two are mixed content and getting duplicates this is before trying the backup plugin restore - so i suspect its a server fault not the plugin @@PenkethBoy how did you do this test?
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 If you create a new library in beta the only file that gets created these days is an option.xml file. So... When i rebuilt a couple of days ago - when i first came across this - any new libraries (i.e.) created in the last couple of month on the beta cycle - after deleting the library.db - came back as mixed content - my music and playlist libraries So - the above test - i did - by shutting down Emby - deleting the library.db file - then also i went through all the root\default directories and removed all .collection,.mblink files - so the rebuild would see the libraries as if newly created with a beta server the option.xml file has the path in it so should not be a problem I have since the above picture recreated all my libraries and they only have option.xml files I will retry by doing the same test in a bit to see if it does the same 1
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 Ok - did the test again - and its reproducible e.g. three things to note 1. all folders are mixed content - apart from 2. recorded shows/movies - which are duplicated at least 3. new folders are created under root\default notice the 1 folders created just now with the rebuild i just did at 08:44 ish
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 (edited) If you have a path specified in dashboard>dvr>optional path for tv recordings as i do then you always get at least one duplicate of that library as you can see above if you delete one it takes out all of them so you have to remove the optional path>save>re add it and save - then it comes back as a single library of the correct type does not do this for recorded movies even with an optional path - well not every time at least These issues need fixing before the next stable goes out Edited March 12, 2020 by PenkethBoy
Dibbes 515 Posted March 12, 2020 Author Posted March 12, 2020 So - the above test - i did - by shutting down Emby - deleting the library.db file - then also i went through all the root\default directories and removed all .collection,.mblink files - so the rebuild would see the libraries as if newly created with a beta server this is pretty much what I did... putting the mblink or collection file back does not resolved this...
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 i did not put back any mblink or collection files as they are now deprecated (on beta) - so no point testing
Luke 42255 Posted March 12, 2020 Posted March 12, 2020 If you create a new library in beta the only file that gets created these days is an option.xml file. So... When i rebuilt a couple of days ago - when i first came across this - any new libraries (i.e.) created in the last couple of month on the beta cycle - after deleting the library.db - came back as mixed content - my music and playlist libraries So - the above test - i did - by shutting down Emby - deleting the library.db file - then also i went through all the root\default directories and removed all .collection,.mblink files - so the rebuild would see the libraries as if newly created with a beta server the option.xml file has the path in it so should not be a problem I have since the above picture recreated all my libraries and they only have option.xml files I will retry by doing the same test in a bit to see if it does the same and options.xml has the content type inside, right?
Happy2Play 9814 Posted March 12, 2020 Posted March 12, 2020 (edited) In my test the options.xml has content type until it is restored, after restore content type is removed from options.xml make the restore Mixed Content on import. Placing a (contenttype).collections file in the library maintains the content type upon restore, at least for me. Edited March 12, 2020 by Happy2Play
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 and options.xml has the content type inside, right? Yes they do for the half dozen i have just checked options.zip Thats one for a music video library - which became a mixed content library i kept it as a backup
Happy2Play 9814 Posted March 12, 2020 Posted March 12, 2020 Yes they do for the half dozen i have just checked options.zip Thats one for a music video library - which became a mixed content library i kept it as a backup Do you see contentype removed upon restore?
PenkethBoy 2068 Posted March 12, 2020 Posted March 12, 2020 I just copied the Music Video (copy of folder as reference - not via the plugin) to beta .25 test server - with emby server off It did not have a Music Video library before ( although it did have movies, music and Tv - manually created from the UI - not imported) I used the options.xml as attached above and on restarting the server - the library got created as mixed content unlike what H2P reported - so might be a difference using the backup plugin - the content type is still musicvideos in the options.xml file - the date of the file did not change in the root/default/music video directory from the copy i have elsewhere on my system
