Brudertac 18 Posted December 16, 2019 Posted December 16, 2019 (edited) Hey there, looks like Hardware Acceleration for HEVC is broken in latest Release. Emby switch to Software Transcode, but for this my Synology DS918+ is too slow. From reports in this Forum it looks like only 10bit Files are affected. On older Versions this was working fine. Is that a known Problem? Thanks Brudertac embyserver.txt ffmpeg-transcode-c31d7e5e-fa5f-423f-b63e-cc5843194e9d_1.txt ffmpeg-transcode-c92604cc-0f65-4368-ba5f-d854417a52e6_1.txt Edited December 16, 2019 by Brudertac
Luke 42243 Posted December 16, 2019 Posted December 16, 2019 Hi there, let's look at an example. Please attach the information requested in how to report a problem. Thanks.
Brudertac 18 Posted December 16, 2019 Author Posted December 16, 2019 (edited) Logs added to first Post. @@softworkz Edited December 16, 2019 by Luke
rouq 23 Posted December 16, 2019 Posted December 16, 2019 Hi Check out this thread: https://emby.media/community/index.php?/topic/79986-hardware-transcoding-fails-on-hevc-main-10-10bit-profile/ There is a temporary work around. You need to disable the hardware decoding for HEVC. The decoding will be done in software, but at least the encoding will be done in hardware. It should give some slack to the DS918+ processor.
Brudertac 18 Posted December 16, 2019 Author Posted December 16, 2019 Hi Check out this thread: https://emby.media/community/index.php?/topic/79986-hardware-transcoding-fails-on-hevc-main-10-10bit-profile/ There is a temporary work around. You need to disable the hardware decoding for HEVC. The decoding will be done in software, but at least the encoding will be done in hardware. It should give some slack to the DS918+ processor. Already seen this and tested it too. It do not work. If i setup the settings like described the Movie wont play.
processcreative 0 Posted December 17, 2019 Posted December 17, 2019 Already seen this and tested it too. It do not work. If i setup the settings like described the Movie wont play. Same for me. HW acceleration will not work whatsoever with 10bit x265 files, no matter my settings. Makes Emby unusable remotely as 90% of my files are 10bit x265. Getting really frustrated with this as it's been 'broken' for ages and no real fix as yet.
Luke 42243 Posted December 17, 2019 Posted December 17, 2019 @@softworkz is working on this. Thanks. 1
softworkz 5133 Posted December 17, 2019 Posted December 17, 2019 @@Brudertac @@processcreative - Could you please post an ffmpeg log with the HEVC hw decoder disabled as suggested?
stephenk 0 Posted December 17, 2019 Posted December 17, 2019 I just came across this thread. Is this the correct log attached? ffmpeg-transcode.txt
softworkz 5133 Posted December 17, 2019 Posted December 17, 2019 @@stephenk - Thanks for the log. The setup is correct and it appears to be working - just too slow. It's an UHD video with double frame-rate (60 fps) and a total bitrate of 28 Mbps. That's just a bit too much for the device to handle. Could you please try one thing: During playback, click on the gear icon and and 'Quality'. There, choose '480p - 1 Mbps'. It would be great if you could post a log from this test. I'm just curious to see how that compares.
stephenk 0 Posted December 17, 2019 Posted December 17, 2019 @@softworkz Sure, here you go. I'm doing this remotely at present. I can add some logs from local playback when home from work if needed. ffmpeg-transcode.txt
softworkz 5133 Posted December 18, 2019 Posted December 18, 2019 (edited) Thanks. It's only slightly faster. We have reduced the encoding work but added hardware scaling (which is done in hardware, though). But in this case, I think the cpu processing is the bottleneck. It's not only decoding but also color conversion that has to be done by the cpu. We are currently working on doing all of this with hw acceleration, but it will take a few weeks until we'll be able to put this in beta. Edited December 18, 2019 by softworkz
Brudertac 18 Posted December 18, 2019 Author Posted December 18, 2019 @@softworkz Sorry, read to late... Do you need the Logs anymore from my Sys? Is there a way to roll back Emby to the last Version? There it was working fine and when you need some Weeks to fix the complete Process it would be nice to have a Working Server in the meantime. Thanks!
softworkz 5133 Posted December 22, 2019 Posted December 22, 2019 @@Brudertac - Thanks for getting back. So far I haven't seen a confirmed case demonstrating that it has worked before, so if you would be able to help us with that, it would be great. For this, I would need to have logs from the current version and the previous version showing the exact same playback situation (same file, same client, same settings, etc.) With regards to rolling back: It works in many cases when the versions are not too far off, but sometimes it causes problems and you'll need to re-create the library database. Best is to do a backup of all data folders before downgrading. And of course: First, create the logs with the current version before downgrading.
Brudertac 18 Posted December 27, 2019 Author Posted December 27, 2019 @@softworkz, 1. where can i find Info how to Downgrade an Emby Setup on Synology? (No Docker Setup) 2. Are the Logs in the first Post enough for Troubleshooting or do you need more or other Logfiles? (Those are from the not working Version) Thanks and best regards Brudertac
Luke 42243 Posted December 27, 2019 Posted December 27, 2019 They're enough right now. @@softworkz is looking into this. Thanks.
Brudertac 18 Posted December 30, 2019 Author Posted December 30, 2019 Hi @@softworkz, i have setup an Testserver via Docker with Emby Server 4.2.1.0 and there Transcoding is working fine. I have used the same Movie i used in first Post with Emby 4.3.0. Log attached to this Post. best regards Brudertac embyserver.txt ffmpeg-transcode-93d3aead-061e-45df-9800-27ef55c80e77_1.txt
softworkz 5133 Posted December 30, 2019 Posted December 30, 2019 @@Brudertac - Thanks, this log is very helpful for comparison. In case of the failing log (from 4.3.0.30), the client-requested bitrate (6616000) is just a quarter of the value that we can see in the log from the older 4.2.1.0 version. It would be great if we could rule that out as a possible cause (either increase in 4.3 or reduce in 4.2)
Brudertac 18 Posted December 30, 2019 Author Posted December 30, 2019 @@softworkz, Okay, i hope i understand you correct. Have startet Streaming on both Versions with "Auto - 1080p 6mbit" Setting. Logs attached. ffmpeg-transcode-4_2_1_0.txt ffmpeg-transcode-4_3_1_0.txt
Brudertac 18 Posted January 3, 2020 Author Posted January 3, 2020 @@softworkz, any News on this? Do you need more Logs? Greetings
softworkz 5133 Posted January 4, 2020 Posted January 4, 2020 @@Brudertac - Once again, thanks a lot for the logs. Now we have ruled out any possible (significant) differences of the command line, so this must be due to the different ffmpeg version. The current situation is as follows: We already got an updated ffmpeg version in the pipeline. It will first debut in the Windows releases of the upcoming beta (4.4.0.5). As long as there won't be any showstoppers, that new ffmpeg will be included in the Linux beta packages of the subsequent beta release. Please retry as soon as it's released and let us known about the results then. Thanks for your patience, softworkz
Solution seanbuff 1356 Posted January 6, 2020 Solution Posted January 6, 2020 Just thought I'd report that I have done some testing on the latest Windows build (4.4.0.5) and this appears to be working correctly now on HEVC content, especially 10-bit. All transcoding is being performed by the GPU as expected. Thanks @@softworkz 1
softworkz 5133 Posted January 6, 2020 Posted January 6, 2020 (edited) @@seanbuff - as good as it sounds, and as ludicrous it may be to tell a satisfied customer that his satisfaction might be erroneous - I'm afraid, I still have to. The reason is, that we haven't implemented hw color mapping/conversion for QuickSync yet. There's one thing that might be happening in your case: Our latest ffmpeg allows separate hw contexts for QuickSync encoder and decoder. So you might see QuickSync decoding _and_ QuickSync encoding - but what's happening in-between is done in software. So, the 10bit color conversion is probably done in software while decoding and encoding is done in hardware. If I could see a log file, I could confirm.. Edited January 6, 2020 by softworkz
seanbuff 1356 Posted January 6, 2020 Posted January 6, 2020 @@softworkz sure, no worries here are 2 instances, one with 10-bit and one without ffmpeg-transcode-22bbc2e5-a334-4f35-add3-8c08f905fd49_1.txt ffmpeg-transcode-af16dd40-d7c6-4c02-a466-88ab24547ae6_1.txt
