interman 18 Posted December 16, 2019 Posted December 16, 2019 All, I switched from Chrome to ET. Wow, what a difference. Picture is better and ET uses my video card which saves a TON of CPU usage. I have several movies in 4k and 7.1 to play on my TV downstairs. However, when I play on ET, no sound comes out. If I choose any other audio format it works, (5.1, stereo, etc.). In fact sometimes, if the movie only has 7.1, it will not start playing at all. When this happens, I have to kill ET. I cannot find any settings that let it change to the local settings (play a 7.1 on stereo). In particular, AAC 7.1. And the movies play with sound in Chrome. Also, when I play Any help? Thanks Don
Happy2Play 9811 Posted December 16, 2019 Posted December 16, 2019 (edited) Which version of ET? There really needs to be a better way of distinguishing between version though. sepearate topics app store vs desktop Edited December 16, 2019 by Happy2Play
interman 18 Posted December 16, 2019 Author Posted December 16, 2019 Version 1.1.276.0. I just downloaded and installed it. I do not understand :"sepearate topics app store vs desktop" I am on windows 10 pro and downloaded the app from the microsoft store. Was that correct? Don
Solution Luke 42241 Posted December 16, 2019 Solution Posted December 16, 2019 The store app uses the stock windows video player, and although it superior to the browser video player it still has it's limitations. The desktop app embeds a much more robust player, and it can be downloaded from here: https://emby.media/emby-theater.html 1
interman 18 Posted December 16, 2019 Author Posted December 16, 2019 Thank you. That fixed it. This is so much better. Don
