bazzum 0 Posted December 15, 2019 Posted December 15, 2019 Hello there. here Bas from Holland I have a message on my 2017 smart tv to update the emby app. but when i download the install from usb file , it is still the old file I am searching for the 1.0.70 file best regards Bas
Luke 42242 Posted December 15, 2019 Posted December 15, 2019 Hi, did you follow all of the USB instructions?
FrostByte 5453 Posted December 15, 2019 Posted December 15, 2019 Make sure you delete the previous version first, most models can't be upgraded
bazzum 0 Posted December 15, 2019 Author Posted December 15, 2019 The install works fjust fine, but the usb downlink seems to be the previous version , and not the new version. regards Bas
bazzum 0 Posted December 15, 2019 Author Posted December 15, 2019 The tv keeps saying there is a new update available
FrostByte 5453 Posted December 15, 2019 Posted December 15, 2019 I just downloaded it myself. The version on GitHub is from 11/26 which is .70
bazzum 0 Posted December 15, 2019 Author Posted December 15, 2019 Thanks for your reaction do you have a download link, still can't find it on gitHub thanks Bas
Luke 42242 Posted December 15, 2019 Posted December 15, 2019 Thanks for your reaction do you have a download link, still can't find it on gitHub thanks Bas https://emby.media/emby-for-samsung-smart-tv.html
