DTMHibbert 0 Posted June 14, 2014 Posted June 14, 2014 Hi All, I have been searching all over the net for the answer to this. When using using MediaBrowser3 Theatre some TV Shows will not show the "Season" tab but an "Episodes" tab and doesnt show any episodes. i have to search via the "Folder" tab before going into "TV" to find the episodes i want. Any ideas?
jespermart 5 Posted June 14, 2014 Posted June 14, 2014 Indeed they do show up. I have the same problem im MBT, but the seasons are showed correctly in MBC
Erik 124 Posted June 14, 2014 Posted June 14, 2014 Maybe not the same problem...but when I added a new series already populated with metadata (I use metabrowser), MBT didn't show some seasons because the metadata field for season number was blank. When I added those back in using the web interface editor, the seasons and episodes appeared in MBT. Cheers, Erik
jespermart 5 Posted June 16, 2014 Posted June 16, 2014 The metadata field for season number are added correctly
