agottschling 2 Posted December 14, 2019 Posted December 14, 2019 Hey emby team, I was adding some new media and when emby rescanned the library, it failed to detect the multiple versions, instead making two copies of the same movie in the library. When I manually joined them, the version names are the entire filename, rather than the part that differs, emby is also storing multiple copies of the images and metadata. A screenshot is attached. Am I doing something wrong, or did I find a bug? Thanks
ebr 16313 Posted December 14, 2019 Posted December 14, 2019 Hi. Did you follow the naming conventions (exactly) for multi-version movies?
agottschling 2 Posted December 14, 2019 Author Posted December 14, 2019 The only thing that differs on my setup is that I'm using brackets to hold the version info instead of a dash. Is that no longer supported?
ebr 16313 Posted December 14, 2019 Posted December 14, 2019 Can you show us a screenshot from explorer that shows both the folder and file names?
Solution Happy2Play 9806 Posted December 15, 2019 Solution Posted December 15, 2019 (edited) Screenshot attached. Does not meet the number one rule. "Each version must begin with the folder name, followed by" Proper naming works without issue. Edited December 15, 2019 by Happy2Play 1
agottschling 2 Posted December 15, 2019 Author Posted December 15, 2019 Huh, Initially, I had it that way but changed it to an underscore when Emby started doing this nonsense. I'll just fix that up and go from there. Thanks for the help.
Luke 42217 Posted December 15, 2019 Posted December 15, 2019 Hi there, why do you consider it nonsense when the wiki spells out the accepted convention for you?
agottschling 2 Posted December 15, 2019 Author Posted December 15, 2019 Nonsense probably wasn't the right word, However, Emby had never given me a hard time because I used dashes or had left off the year in the filename before. It probably changed during an update, and it was my fault for not reading it carefully enough though.
Luke 42217 Posted December 15, 2019 Posted December 15, 2019 It hasn't gotten stricter with updates, in fact it's actually gotten looser with what it accepts.
