gillmacca01 220 Posted December 14, 2019 Posted December 14, 2019 I have Emby installed on a QNAP, which also has a VPN service running through OpenVPN. Scenario 1: VPN turned off, I can remotely connect to Emby Scenario 2: VPN starts up before Emby has started, so Emby uses the VPN address. Unable to access remotely Scenario 3: Disable VPN, start Emby and then restart the VPN. Emby show normal external address (not running through the VPN), and I can access Emby remotely. Is there a way for my to get Emby to use the non-vpn address only (maybe by locking it or something?) Many thanks for any help
ebr 16313 Posted December 14, 2019 Posted December 14, 2019 Hi. Have you explored the Network settings in your server dashboard?
gillmacca01 220 Posted December 14, 2019 Author Posted December 14, 2019 I have looked in network settings, but I'm not 100% sure what I should be doing in there, Am I suppose to put the IP address in 'Remote IP address filter'
ebr 16313 Posted December 14, 2019 Posted December 14, 2019 You would put it in the "External Domain" field. This used to have a better description than it does now. We should look to re-improve it.
Happy2Play 9806 Posted December 14, 2019 Posted December 14, 2019 You will have to remember, if your WAN address ever changes you will have to update this field to access Emby again.
