letterman 40 Posted December 14, 2019 Posted December 14, 2019 QNAP 4.3.0.30_x86_64 Web App or Android 9 Emby 3.0.87 app. Directory view, subfolder with songs. e.g. \Music \Artist Name \Album Name 1 \Album Name 2 ... When browsing in Artist Name-Folder, all Albums are shown perfectly and it is possible in preferences to select whether title, year or both should be shown within the primary view. "Title" works fine to turn on and off. But year does not work. Year is never shown, independently of selecting it or not. Is it a bug? Can you reproduce this phenomenon?
PenkethBoy 2068 Posted December 14, 2019 Posted December 14, 2019 yep seeing the same - year does not work
Luke 42241 Posted December 15, 2019 Posted December 15, 2019 It works just fine in the Albums tab under the music library. Have you used the metadata editor to check your albums and make sure they have years assigned to them?
PenkethBoy 2068 Posted December 16, 2019 Posted December 16, 2019 yes works in Album tab - all years show up but not in the folder view of an Artist - however if i turn year off the artist name disappears from below the album so the year appears to be confused with Artist name all my albums have a Year assigned The above is with Stable server 2
letterman 40 Posted December 16, 2019 Author Posted December 16, 2019 yes works in Album tab - all years show up but not in the folder view of an Artist - however if i turn year off the artist name disappears from below the album so the year appears to be confused with Artist name all my albums have a Year assigned The above is with Stable server Same same. That's why I reported this bug
Happy2Play 9811 Posted December 16, 2019 Posted December 16, 2019 Yep in folder view it toggles Artistname instead of Year in cardText-secondary. OS is irrelevant, tested in beta server. 1
