acnp77 67 Posted February 19, 2020 Posted February 19, 2020 I could not find anything in the release notes. I which release has this been fixed?
vdatanet 1619 Posted February 19, 2020 Posted February 19, 2020 (edited) I could not find anything in the release notes. I which release has this been fixed? 1.4.4 Fix some initial connection and switch user problems At least it worked on the beta cycle, Can you confirm it works on release version? Edited February 19, 2020 by vdatanet
acnp77 67 Posted February 19, 2020 Posted February 19, 2020 Thanks. I can not test this at my home, but I will try to get some feedback and confirm asap.
peanutbutter509 0 Posted February 22, 2021 Posted February 22, 2021 Unfortunately, still no result. I think it's the seedbox that's causing the problem. Because when I do a local installation with a Home NAS server it works very well. Do you think it's possible to make a seedbox appear on a local server to make a final attempt? Or conversely, for example ask emby to fetch the files on a non-local server (ultraseedbox)?
thedagenais’ 0 Posted April 16, 2022 Posted April 16, 2022 I now have 3 Apple TV’s that I can’t login with the new Emby connect. I am using someone else’s server and they say they do not know the url. All I have is this info: frank.myddns.me port 9115 my username and password When I enter in any info, it gives me an error
Luke 42241 Posted April 18, 2022 Posted April 18, 2022 On 4/16/2022 at 9:36 AM, thedagenais’ said: I now have 3 Apple TV’s that I can’t login with the new Emby connect. I am using someone else’s server and they say they do not know the url. All I have is this info: frank.myddns.me port 9115 my username and password When I enter in any info, it gives me an error @thedagenais’ is their URL http or https? If it should be https, try adding https:// in front of it.
