tigrao 18 Posted August 19, 2020 Posted August 19, 2020 6 hours ago, Luke said: Hi, which screensaver? The operating system screen saver as set in the macOS system preferences. On Windows the screen saver and monitor power saving settings are disabled while watching content with Emby Theater. On macOS these settings are not disabled. Video playback continues but behind the screen saver.
peanut369 0 Posted September 1, 2020 Posted September 1, 2020 Hi there, I have Emby Theatre running perfect on a 2012 MacBook Pro. But, on my Mac mini 2018 (high spec) connected to a 4k monitor the FPS is really bad. If I resize the Emby app window to something small then the FPS comes back to normal, but as soon as I enlarge or go full screen then the FPS lags big time again. Anyone else finding this too? Thanks
Carlo 4561 Posted September 1, 2020 Posted September 1, 2020 I don't have a Mac but can understand how/why this could happen. You have a lot more pixels to update in 4K vs 1080 mode. For those that will be able to help you @peanut369 what version do you have installed? Are you playing back 1080 or 4K material when this happens? What kind of FPS do you see between windowed and full screen?
Luke 42241 Posted September 2, 2020 Posted September 2, 2020 On 8/19/2020 at 1:09 AM, tigrao said: The operating system screen saver as set in the macOS system preferences. On Windows the screen saver and monitor power saving settings are disabled while watching content with Emby Theater. On macOS these settings are not disabled. Video playback continues but behind the screen saver. The system screensaver issue is resolved for the next update to the app. Thanks.
sooty234 266 Posted September 2, 2020 Posted September 2, 2020 22 hours ago, peanut369 said: Hi there, I have Emby Theatre running perfect on a 2012 MacBook Pro. But, on my Mac mini 2018 (high spec) connected to a 4k monitor the FPS is really bad. If I resize the Emby app window to something small then the FPS comes back to normal, but as soon as I enlarge or go full screen then the FPS lags big time again. Anyone else finding this too? Thanks What is the stats for nerds telling you? Post a screenshot of them.
peanut369 0 Posted September 2, 2020 Posted September 2, 2020 43 minutes ago, sooty234 said: What is the stats for nerds telling you? Post a screenshot of them. Thanks. It's just a regular 1080p movie. But it's the whole app itself that lags. When windowed, the FPS is indistinguishable from the average 24fps. But when it's maximized the FPS feels like 5 FPS. I'm not sure the nerdy stats will help too much, because it's the complete interface that lags, even when a movie isn't played. I wonder if it's because it's a native iOS app that's being used on a Mac?
sooty234 266 Posted September 2, 2020 Posted September 2, 2020 They aren't using all of the information available to them. What a pity. The stats are useless. But from what you're saying, it's the UI software that's having the problem. The devs will have to look at that.
Luke 42241 Posted September 3, 2020 Posted September 3, 2020 4 hours ago, sooty234 said: They aren't using all of the information available to them. What a pity. The stats are useless. But from what you're saying, it's the UI software that's having the problem. The devs will have to look at that. We haven't yet integrated mpv data into stats for nerds with this app, but we'll get there.
sooty234 266 Posted September 4, 2020 Posted September 4, 2020 This commit should be an improvement. https://github.com/mpv-player/mpv/pull/7849 https://github.com/mpv-player/mpv/commit/514166242763699633147e7aead31fc7ae16372e
Luke 42241 Posted September 4, 2020 Posted September 4, 2020 15 minutes ago, sooty234 said: This commit should be an improvement. https://github.com/mpv-player/mpv/pull/7849 https://github.com/mpv-player/mpv/commit/514166242763699633147e7aead31fc7ae16372e Yes indeed.
peanut369 0 Posted September 4, 2020 Posted September 4, 2020 Hope you dont mind me mentioning just a couple of things I noted. - The screen dims after say 15-20 minutes (I assume depending on energy saver settings in MacOS) and so you have to move the mouse to wake it back up - The mouse is visible all the time even in full screen Thanks again
Luke 42241 Posted September 4, 2020 Posted September 4, 2020 11 hours ago, peanut369 said: Hope you dont mind me mentioning just a couple of things I noted. - The screen dims after say 15-20 minutes (I assume depending on energy saver settings in MacOS) and so you have to move the mouse to wake it back up - The mouse is visible all the time even in full screen Thanks again Thanks for reporting. We'll take a look.
jmos1277 10 Posted November 7, 2020 Posted November 7, 2020 Just started playing around with Emby Theater for macOS and have a few questions/comments. 1) I'd like to be able to control Emby Theater with a remote control. Currently, I'm just attempting to use my keyboard. However, there doesn't currently appear to be any visual indicator as to which item is selected. In fact, controlling the interface with the keyboard is a bit awkward. Am I missing a setting somewhere? Without keyboard support, I don't suspect I'll be able to get a remote working either. 2) On macOS Catalina, I get some really odd (app breaking) behavior when I attempt to browse the settings menus. When I select the gear icon (with my mouse) and then attempt to edit ANY setting with a drop-down box the app breaks. For example, if I go to the "Transcoding" setting and select the drop-down box for "Enable hardware acceleration when available", the options ("Yes", "No", "Advanced") continually flash and then immediately disappear. This goes on forever. If I click somewhere else on the UI quickly enough I can deselect the box and get it to stop flashing. Otherwise, it will flash forever. I've made a short recording and attached to show this odd behavior. In the video, I'm able to get the menu to disappear by repeatedly clicking in the empty space on the right. Screen Recording 2020-11-06 at 8.18.35 PM.mov
Luke 42241 Posted November 13, 2020 Posted November 13, 2020 On 11/6/2020 at 8:21 PM, jmos1277 said: Just started playing around with Emby Theater for macOS and have a few questions/comments. 1) I'd like to be able to control Emby Theater with a remote control. Currently, I'm just attempting to use my keyboard. However, there doesn't currently appear to be any visual indicator as to which item is selected. In fact, controlling the interface with the keyboard is a bit awkward. Am I missing a setting somewhere? Without keyboard support, I don't suspect I'll be able to get a remote working either. 2) On macOS Catalina, I get some really odd (app breaking) behavior when I attempt to browse the settings menus. When I select the gear icon (with my mouse) and then attempt to edit ANY setting with a drop-down box the app breaks. For example, if I go to the "Transcoding" setting and select the drop-down box for "Enable hardware acceleration when available", the options ("Yes", "No", "Advanced") continually flash and then immediately disappear. This goes on forever. If I click somewhere else on the UI quickly enough I can deselect the box and get it to stop flashing. Otherwise, it will flash forever. I've made a short recording and attached to show this odd behavior. In the video, I'm able to get the menu to disappear by repeatedly clicking in the empty space on the right. Screen Recording 2020-11-06 at 8.18.35 PM.mov Hi, we're looking into this. Thanks for reporting.
